fvalarm(at)rapidnet.net Guest
Posted: Sat Oct 20, 2007 12:31 am Post subject: TurboCad symbols |
Bob,
OK, where does one obtain the symbols you use in your drawings so that I can
import and customize my wiring diagrams? I just bought Turbo Cad 14 but it
doesn't include much for symbols. At least for what I can find.
Bevan
TurboCad rookie
RV7A waiting for wires
Posted: Sat Oct 20, 2007 12:46 am Post subject: Turbocad symbols |
There must be a way to copy and move symbols already on the drawing but I
cannot find it if it's there. There must be others that are or will be on
the steep part of the "learning Cad" curve. Any advice as to how to quickly
get some drawings done. I'm beginning to think about just hand drawing
these suckers and getting on with it. Not very professional looking but
hey, this Cad stuff is adding a lot of time.
Bevan
RV7A waiting for wire and getting frustrated
andrewbutler(at)ireland.c Guest
Posted: Sat Oct 20, 2007 5:51 am Post subject: Turbocad symbols |
Hi Bevan,
I used Visio. Much easier to learn than AutoCad and it will import CAD drawings. That is what I did and a couple of days ago I posted my design for comments (having saved it to PDF), so you can see the results are just as good as doing it in CAD.
If you end up using Visio, I can send you my visio's if you wish to help you along. There are some idiosyncrasies in the the conversion process.
Don't know how much it costs.
Andrew.
RV71700, Galway Ireland.
[quote]---
nuckolls.bob(at)cox.net Guest
Posted: Sat Oct 20, 2007 11:17 am Post subject: Turbocad symbols |
Bevan
I took some time today to sift through the symbol library,
rename files for better organization, correct errors
and delete some junk. The "clean" library is posted at:
http://www.aeroelectric.com/PPS/ACAD_Symbols_Library/Symbols_5.zip
( "Problems are the price of progress. )
( Don't bring me anything but trouble. )
( Good news weakens me." )
( -Charles F. Kettering- )
Posted: Sat Oct 20, 2007 12:04 pm Post subject: Turbocad symbols |
Thanks Bob,
I've downloaded them, unzipped them but cannot open them with Turbo Cad.
Without wasting your time on this , is there a simple off the top of your
head explanation how to get the symbols into a usable format inside the
symbols library?
Bevan
Posted: Sat Oct 20, 2007 12:07 pm Post subject: Turbocad symbols |
When I try to open a symbol, it says the .DWG file is not a win32
application. Any thoughts on this?
My computer is a PC if that makes any difference
Bevan
bob(at)bob-white.com Guest
Posted: Sat Oct 20, 2007 1:16 pm Post subject: Turbocad symbols |
On Sat, 20 Oct 2007 13:07:20 -0700
Bevan
Hi Bevan,
You have to associate .dwg with TurboCAD. I haven't used Windows in
quite a while so I don't know the procedure. For a symbol library, run
TurboCAD and see what settings they have for libraries. There should be
a way to set the path to the library file. You may just have to set
the path to the directory where the symbol .dwg files are located, or
there might be an import function of some sort. While in TurboCAD, you
should be able to open a .dwg file without the association. That just
lets you run the application by clicking on the data file. Clicking on
a .doc file runs Word for example.
Bob W.
N93BD - Rotary Powered BD-4 - http://www.bob-white.com
3.8 Hours Total Time and holding
Cables for your rotary installation - http://www.roblinphoto.com/shop/
klehman(at)albedo.net Guest
Posted: Sat Oct 20, 2007 2:25 pm Post subject: Turbocad symbols |
I seem to recall opening two files and just copying symbols one at a
time from Bob's drawing to my drawing as needed.
Ken
>Bevan
Hi Bevan,
Bob W.
jlatimer1(at)cox.net Guest
Posted: Sat Oct 20, 2007 4:33 pm Post subject: Turbocad symbols |
>> When I try to open a symbol, it says the .DWG file is not 'a win32
Right click on the file icon. Select properties and then select "open with" then select turbocad from the list of programs. There will be a box that you check that makes sure that Windows associates .dwg files with turbocad everytime you try to open a .dwg file. Hope that works for you.
Jerry
Posted: Sat Oct 20, 2007 9:15 pm Post subject: Turbocad symbols |
At 06:23 PM 10/20/2007 -0400, you wrote:
Quote: |
I seem to recall opening two files and just copying symbols one at a time
Ken
I'm not a TurboCAD user so I'm fishing in the dark here
a bit. The process for using symbols is to first begin
with a blank drawing. Open TurboCAD then within TurboCAD
say File_Open and then click on say Wirebook_A_Border.dwg.
Once the border is brought in, do a File_SaveAs and give
it a name for a diagram you want to create, say Landing_Lights.
Save it to a directory OTHER than were your symbol library
is stored.
Now, you can Insert_File and pick pieces from the symbol
library. You'll need a Bus_Tap_Fuse, a switch, a lamp symbol,
etc. You arrange these blocks on a page and hook them up with
wires. Then add descriptive text like reference designators,
part numbers, etc.
Suggest you begin with one of the Wire Books published on
the website. Download:
http://www.aeroelectric.com/PPS/ACAD_Wirebook_Samples/SEMINAR.DWG
into the directory where your wirebook is going tor reside.
Then open TurboCAD before using TurboCAD to open SEMINAR.DWG.
Do an immediate SAVEAS under the name for your own wirebook.
On the pages within this drawing, the majority of what you'll
need is probably already drawn. Edit this drawing to delete
features you don't need and add features you will need. You
"insert" items from the symbol library as needed.
When I'm teaching AutoCAD, I start with this list of basic
drawing commands:
AR, *ARRAY
B, *BLOCK
WB, *WRITEBLOCK
BR, *BREAK
CI, *CIRCLE
C, *CHANGE
CH, *CHAMFER
CO, *COPY
D, *DIMSTYLE
DI, *DIST
DO, *DONUT
DT, *DTEXT
E, *ERASE
ED, *DDEDIT
EL, *ELLIPSE
XT, *EXTEND
EXIT, *QUIT
F, *FILLET
H, *HATCH
I, *INSERT
IP, *ISOPLANE
L, *LINE
LA, *LAYER
LI, *LIST
LT, *LINETYPE
M, *MOVE
MI, *MIRROR
OF, *OFFSET
OS, *OSNAP
P, *PAN
PE, *PEDIT
PL, *PLINE
PG, *POLYGON
P, *PAN
R, *REDRAW
RG, *REGEN
RT, *RECTANGLE
REN *RENAME
RO, *ROTATE
S, *STRETCH
SC, *SCALE
SCR, *SCRIPT
T, *TRIM
V, *VIEW
XP, *EXPLODE
Z, *ZOOM
Additionally, you'll need to explore and grasp
the use of object snap commands like
Intersection
Center
End
Tangent
Perpendicular
Nearest
and
Insertion.
I think you'll find it much easier to modify an existing
array of pages as opposed to starting from scratch. Do you
have a TurboCAD tutorial? I just opened my TurboCAD version
10 that I purchased off Ebay some months ago. It sees to open
and/or insert items from the symbol library just fine. TurboCAD
also recognizes the AutoCAD views I assigned to each page
in the composite drawing . . . I'm pretty sure this software
will let you do anything needed to craft your own wirebook
but you'll have to become familiar with the basic drawing
and editing commands unique to TurboCAD. I was able to copy
and edit text and print one view at a time to the printer.
Posted: Sat Oct 20, 2007 10:05 pm Post subject: Turbocad symbols |
Bob and all,
Thanks for all the help here. I worked on it until 3:30 this AM and again
today after a long nap. I'm doing much better now. The plan at the moment
is to begin with existing drawings and moving, copying symbols to get it to
be what it needs to be. So far so good. A few more hours and I'll be on my
way. Thanks again for all the input received. This list is a great
resource.
Bevan
Wires are beginning to know where they are supposed to go.
