exhaust screw tensions
Jim McCormick
PostPosted: Mon Oct 22, 2007 7:30 am    Post subject: exhaust screw tensions Reply with quote
Hi Marvin
Your are correct it's not listed , I would recommend 7 ft-lbs if you want to try to get a torque wrench in there, I personally don't use torque wrench on them go by feel.
Also use so anti-seize on the exhaust bolts when you reassemble it.
Also one other note, your engine doesn't have any exhaust gaskets, it has conical seats on the exhaust pipe.
All 2200 engines after serial 1597 have conical exhaust seats.
Jim McCormick
Jabiru Pacific LLC
255 W Fallbrook 202B
Fresno, CA 93711
Office 559-431-1701
Fax 559-233-3676
www.jabirupacific.com [quote] --
gaman(at)att.net
PostPosted: Mon Oct 22, 2007 3:08 pm    Post subject: exhaust screw tensions Reply with quote
Jim
Have 2200 serial # 1295. Exhaust gaskets?
G Aman
"Jim(at)jabirupacific.com" <jim(at)jabirupacific.com> wrote:[quote] Hi Marvin
Jim McCormick
Jabiru Pacific LLC
Fresno, CA 93711
Office 559-431-1701
Fax 559-233-3676
[quote] --
Jim McCormick
PostPosted: Mon Oct 22, 2007 4:05 pm    Post subject: exhaust screw tensions Reply with quote
Serial # 1295 still use's exhaust gaskets.
Jim McCormick
Jabiru Pacific LLC
Fresno, CA 93711
Office 559-431-1701
Fax 559-233-3676
