RV8a Electric Aileron Trim
japhillipsga(at)aol.com
PostPosted: Mon Oct 22, 2007 12:06 pm    Post subject: RV8a Electric Aileron Trim Reply with quote
Dear Fellow RV-8a Builders, I have the spring type trim setup, but have not installed it yet. Good friend told me that most folks use the manual spring trim if they are installing an auto pilot system and or use the electric trim system if not. I do not plan to install an auto pilot so is the electric system really recommended ? I have electric aileron trim on my present plane and I like how manageable and easy it is. Who has the electric trim without auto pilot in their 8 and how does it compare to spring system ? Advantages/disadvantages? Hope to hear from someone and best regards, Bill of Georgia
groves(at)epix.net
PostPosted: Mon Oct 22, 2007 1:10 pm    Post subject: RV8a Electric Aileron Trim Reply with quote
I have the electric trim and love it, Its very easy to use on stick. You don't have to move your hand off the stick.
go for the electric .
All the best
Kirk RV-8
On Oct 22, 2007, at 4:05 PM, japhillipsga(at)aol.com (japhillipsga(at)aol.com) wrote:
[quote]Dear Fellow RV-8a Builders, I have the spring type trim setup, but have not installed it yet. Good friend told me that most folks use the manual spring trim if they are installing an auto pilot system and or use the electric trim system if not. I do not plan to install an auto pilot so is the electric system really recommended ? I have electric aileron trim on my present plane and I like how manageable and easy it is. Who has the electric trim without auto pilot in their 8 and how does it compare to spring system ? Advantages/disadvantages? Hope to hear from someone and best regards, Bill of Georgia
carl.froehlich(at)cox.net
PostPosted: Mon Oct 22, 2007 2:21 pm    Post subject: RV8a Electric Aileron Trim Reply with quote
Same for me. Get the electric aileron trim.
I have both aileron and elevator trim on an Infinity stick coolie hat, to a homebrew relay system. I’m very happy with the set up.
Carl Froehlich
RV-8A (350 hrs)
Dogwood Airpark (VA42)
From: owner-rv8-list-server(at)matronics.com [mailto:owner-rv8-list-server(at)matronics.com] On Behalf Of Kirk&Laura Groves
Sent: Monday, October 22, 2007 5:10 PM
To: rv8-list(at)matronics.com
Subject: Re: Re: RV8a Electric Aileron Trim
All the best
Kirk RV-8
schad(at)cooke.net
PostPosted: Mon Oct 22, 2007 3:08 pm    Post subject: RV8a Electric Aileron Trim Reply with quote
I have electric aileron and elevator trim on my RV-8. I did something different and mounted the elevator trim switch on the throttle. It has worked out quite well and is in a handy place.
I would really suggest you install a autopilot while you are building. It is much easier now than later. I thought that altitude hold was not necessary until the first cross country. That is when I learned how pitch sensitive the RV is while fighting with maps. I'm now in the middle of adding altitude hold. Talk about one step forward and six backwards.
Tom Schad RV-8 N558TX
Lenleg(at)aol.com
PostPosted: Mon Oct 22, 2007 4:23 pm    Post subject: RV8a Electric Aileron Trim Reply with quote
Bill:
I have electric trim and am very happy with it. Flew the first couple of years without autopilot but now have that also ... still love the electric trim when not flying on autopilot.
Len Leggette, RV-8A
Greensboro, NC N910LL
595 hrs
In a message dated 10/22/2007 4:08:14 PM Eastern Daylight Time, japhillipsga(at)aol.com writes:
-----Original Message-----
From: RV8-List Digest Server <rv8-list(at)matronics.com>
To: RV8-List Digest List <rv8-list-digest(at)matronics.com>
Sent: Mon, 22 Oct 2007 2:57 am
Subject: RV8-List Digest: 2 Msgs - 10/21/07
[quote]* ========================= Online Versions of Today's List Digest Archive ========================= Today's complete RV8-List Digest can also be found in either of the two Web Links listed below. The .html file includes the Digest formatted in HTML for viewing with a web browser and features Hyperlinked Indexes and Message Navigation. The .txt file includes the plain ASCII version of the RV8-List Digest and can be viewed with a generic text editor such as Notepad or with a web browser. HTML Version: willfly(at)carolina.rr.com (willfly(at)carolina.rr.com)> Subject: Re: Aileron pushtube holes in fuselauge There is plenty of room. Should be no need to enlarge. Steve Glasgow-Cappy N123SG RV-8 Cappy's Toy ________________________________ Message 2 _____________________________________ Time: 10:04:28 AM PST US From: "Steve Gregory" <sgregory(at)best.com (sgregory(at)best.com)> Subject: RE: Aileron pushtube holes in fuselauge Yes, I had to enlarge both sides. Used a Dremel. I did it when I was trial fitting the ailerons, before the wings went on. Watch the movement from the bellcrank to where it connects with the aileron. Steve Gregory RV-8QB Livermore, CA --
