		Dave Nixon
				 Posted: Tue Oct 23, 2007 12:03 pm    Post subject: Right and Left Hand Turnbuckles |
				I saw on the CH601XL plans for the adjustable turnbuckles for the elevator to mounted at the elevator horn on the dual stick configuration between the seats. How gross is that?  The bottom one would never be accessed without a 5 year old's size hands in a contortionist position.  So I ordered from Aircraft Spruce the correct threaded turnbuckle eye (P/N AN 170-22RS Cable Eye) and installed my adjustable elevator turnbuckle just above and slightly aft of my rear bottom access hole. Not only is it easier to adjust and safety wire (Single Spiral with .041 wire) but I can check cable tension right there and make adjustments in the future as necessary.
  I am using Push/Pull control rods for the ailerons.  Each rod has a right hand and left hand threaded fitting and jam nut for minute adjustment.  That way, if one of my ailerons is out I can bring it back in with minimal effort.  Once locked, it will stay for ever.
  Hope this helps someone out.
  Dave Nixon
  CH 601XL  N107R
  (90% Done / 90% To Go)
  |  | - The Matronics Zenith-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		Gig Giacona
				 Posted: Tue Oct 23, 2007 1:12 pm    Post subject: Re: Right and Left Hand Turnbuckles |
				Dave, do you have any photos or drawings of how you modified for push/pull rods.
  	  | Dave Nixon wrote: |
  Dave Nixon
  CH 601XL  N107R
601XL Under Construction
		GLJSOJ1
  Joined: 18 Aug 2007 Posts: 82 Location: Chesapeake, Virginia
				 Posted: Wed Oct 24, 2007 7:26 am    Post subject: Right and Left Hand Turnbuckles |
				THANKS FOR THAT HINT.  I HAVE BEEN DREADING SAFETING THAT TURN BUCKLE.  IF I HAVE A HARD TIME I'LL DO JUST THAT. THANKS
  GLENN
   	  | Quote: | 	 		    Date: Tue, 23 Oct 2007 16:00:38 -0400
 Subject: Right and Left Hand Turnbuckles
  Dave Nixon
  CH 601XL  N107R
          | 	  Boo! Scare away worms, viruses com/standard/en-us/purchase/trial.aspx?s_cid=wl_hotmailnews' target='_new'>Try now!  [quote][b]
  _________________ 601XL N676L  FLYING PHASE I
CHESAPEAKE VA |
		dredmoody(at)cox.net Guest
				 Posted: Wed Oct 24, 2007 7:39 am    Post subject: Right and Left Hand Turnbuckles |
				The up elevator cable turnbuckle could also be located back at the elevator horn under the fiberglass fairing. Most of us have made that fairing removable and mine is easier to remove than opening up the belly hatch. I prefer to locate the turnbuckles near the end of cable rather than in the middle where the weight of the turnbuckle adds more energy to the oscillation of the cable inflight. It's not a big deal but the added mass of the turnbuckle isbetter supported near the end of the cable.
 Dred
 ---- GLENN JOHNSON <gljno10(at)HOTMAIL.COM> wrote:
  GLENN
  Date: Tue, 23 Oct 2007 16:00:38 -0400From: adnasap(at)bellsouth.netTo: zenith-list(at)matronics.comSubject: Right and Left Hand Turnbuckles
  Dave Nixon
  CH 601XL  N107R
  ilnews
		Dave Nixon
				 Posted: Wed Oct 24, 2007 11:42 am    Post subject: Re: Right and Left Hand Turnbuckles |
				Regarding the push/pull aileron control rods, and for those that are interested, I am about 3-4 weeks away from finalizing my wing installation.  I am hanging the engine next week.  When I do hang the wings, I will take good pictures of my push/pull rod for others.
 Dave Nixon
 90/90
