		fstringham
				 Posted: Thu Oct 25, 2007 5:32 am    Post subject: EMag wrong ??? |
				Bob and others
 I believe I asked the wrong question in yesterdays post.
 I have wired my aircraft (rv7A) according to the scheme Z13-8. I sure hate
 to rewire .....so after meeting with the good folks from E-mag is the Z13-8
 no longer viable or am I still OK to go with it!
 What I should have asked is:
 1. Who out there is using Z13-8 or Z33 with Emag products and have either
 had good luck with no problems to the mags or tragedy?
 2. If Tragedy to the mags can the problem be traced to the wiring scheme of
 Z13-8?
 3. Has there been anyone with any wiring scheme....Emag suggested or
 otherwise that has a mag problem and can definitly say it was because of the
 wiring (loose wire or poor connections excluded)
 I believe that there may be a precieved problem with how these mags are
 wired that may or may not becausing problems with the mags where in fact
 actual use may not bare this out.
 Thanks for your imput from those of you with expience in the field.
 Frank (at) SGU   RV7A    Wiring Done.....maybe
 Help yourself to FREE treats served up daily at the Messenger Café. Stop by
 today!
 http://www.cafemessenger.com/info/info_sweetstuff2.html?ocid=TXT_TAGHM_OctHMtagline
		nuckolls.bob(at)cox.net Guest
				 Posted: Thu Oct 25, 2007 6:02 am    Post subject: EMag wrong ??? |
				At 07:31 AM 10/25/2007 -0600, you wrote:
 <fstringham(at)hotmail.com>
 Bob and others
 Z13-8 no longer viable or am I still OK to go with it!
   There's nothing wrong with it . . . for P-Mags.
   Obviously, you don't want to "preflight" the
   power supply to an E-Mag, you KNOW that the
   device won't run with power removed.
  	  | Quote: | 	 		  What I should have asked is:
     No. . .
  	  | Quote: | 	 		  2. If Tragedy to the mags can the problem be traced to the wiring scheme
 of Z13-8?
     No . . .
  	  | Quote: | 	 		  3. Has there been anyone with any wiring scheme....Emag suggested or
 the wiring (loose wire or poor connections excluded)
     No . . .
  	  | Quote: | 	 		  I believe that there may be a precieved problem with how these mags are
    While visiting Emagair two weeks ago, we had some
    discussions about design goals and risks. I was
    also made privy to some of changes to their design
    goals that will make the P-mag replacement of magnetos
    still more transparent to the owner/operator.
    I have been and continue to be skeptical of the
    rumors circulating the 'Net concerning dual failure
    of Emagair products resulting in a forced landing.
    None of these stories were accompanied with a detailed
    failure mode effects analysis of events leading up
    to the unintentional arrival with the earth.
    Z-13/8 is going to be revised to suggest that
    P-mags be permanently powered from the E-bus
    and that operational control of the P-mag be
    accomplished with the simple, single pole
    switch used for magnetos. This architecture
    will still allow for the occasional verification
    of P-mag self powered operations because it's
    a simple matter to power the electrical system
    down during ground ops for the purpose of
    conducting tests. Further, drain on the E-Bus
    during battery-only ops will be eliminated
    because future plans for P-mags call for
    switching to internal power full time once
    the engine is started.
    But as a day-to-day operational concern for
    preflight and operation of the aircraft, the
    wiring in Z-13/8 goes to the design goals
    stated for pre-flight testing of internal
    P-mag power and presents no special concerns
    for abnormal behavior of or damage to the
    ignition system.
    If you're already wired per Z-13/8, there
    is no imperative for revising it as long
    as you personally embrace the design goals
    that drove the architecture. In the revised
    drawing, we will suggest that internal power
    supplies for the P-mag are so robust and
    reliable that likelihood of pre-flight
    testing revealing a deficiency is too small
    be concerned with on a flight-by-flight basis.
		frank.hinde(at)hp.com Guest
				 Posted: Thu Oct 25, 2007 7:33 am    Post subject: EMag wrong ??? |
				Oh really?
 A dual failure maybe not..But failures, almost certainly.
 My engine temps suddenly went through the roof to the degree that it was
 likely an engine teardown was in order.
 Every potential cause was eliminated which put it down to the timing
 going beserk.
 Yes I was one of those but fourtunatly made it to the airport...It
 happened on two separate occasions, once in IMC.
 In fact Emagair themselves will tell you that they had a problem with
 the units resetting their own timing. So while it was probably not a
 dual failure the fact that the effective timing comes from the first one
 to fire then unless that mag is shutdown the consequential detonation
 can bring the airplane down....it did once (reported on Vans airforce
 website) and I don't think I was dreaming at the time either...More like
 a nightmare!
 Now several improvments have been made since and no further problems
 have been encountered. It is also fair to say that in both of the near
 forced landings (one actual and mine was a near miss) IF the pilot had
 been savvy enough to shut down one of the Emags we could have probably
 found which mag it was and probably saved what must have been
 considerable stress on our brand new engines. But alas we didn't....So
 we take some of the blame there.
 So while there is no concrete proof the evidence is highly compelling
 that these units used to loose their timing with almost disasterous
 results (to our pocket books if not to our lives).
 Having said that. The units have performed very well..I have had a lot
 of problems (more than most according to Brad). The folks at Emagair
 have however worked very hard to rectify issues in a timely manner and I
 would say I have at least 150 hours of fault free flying behind them
 since.
 Yes I do believe in E/Pmags now but they have most certainly not got a
 blemish free track record. Lets hope those days are firmly behind us.
 Frank
 RV7a 225 hours
