Posted: Mon Oct 29, 2007 8:49 am Post subject: Coolant Temperature Control |
At 04:04 PM 10/29/07 GMT, you wrote:
........ I have learned lately that to fly my Kolb in cold weather, it is a good idea to cover about a third of the old Geo Metro radiator. Otherwise, the water temp gets too low and it does not produce peak power. It would be nice to invent something like a cowl flap to control the amount of outside air to the radiator.
Vic,
Here is my solution. It has been working for about six years with no
problems. Check out:
http://www.thirdshift.com/jack/firefly/firefly67f.html
and
http://www.thirdshift.com/jack/firefly/firefly68.html
The rub bars proved to be unnecessary.
Very light and inexpensive.
Jack B. Hart FF004
Winchester, IN
Posted: Mon Oct 29, 2007 12:42 pm Post subject: Coolant Temperature Control |
Jack H:
I have several 71 year old tractors that use the same curtain system to increase coolant heat. My 1960 Volvo PV544 also had a radiator curtain to help the coolant thermostat.
I use a little gaffer's tape in the winter to keep engine oil and cyl head temps in the green.
Wendover, Utah, headed for Moab, Utah
_________________ John Hauck
Titus, Alabama |
biglar
Posted: Mon Oct 29, 2007 2:23 pm Post subject: Coolant Temperature Control |
Nice. I like that better than my idea. Lar.
Jack B. Hart wrote: [quote] | Quote: | --> Kolb-List message posted by: "Jack B. Hart" <jbhart(at)onlyinternet.net> (jbhart(at)onlyinternet.net)
| Quote: | --> Kolb-List message posted by: "Vic Gibson" <apilot(at)webtv.net> (apilot(at)webtv.net)
Vic,
and
Jack B. Hart FF004
Winchester, IN
| [b]
_________________ Larry Bourne
Palm Springs, CA
Building Kolb Mk IIIC
"Vamoose" |
Steven Green
Posted: Mon Oct 29, 2007 6:27 pm Post subject: Coolant Temperature Control |
I must be missing something. Does the coolant system not have a thermostat?
Steven
_________________ Steven Green |
Posted: Mon Oct 29, 2007 6:52 pm Post subject: Coolant Temperature Control |
Steven,
No, it does not.
Jack B. Hart FF004
Winchester, IN
Steven Green
Posted: Mon Oct 29, 2007 7:11 pm Post subject: Coolant Temperature Control |
Jack,
I was referring to the original message about the Geo Metro engine.
Steven
apilot(at)webtv.net Guest
Posted: Mon Oct 29, 2007 8:00 pm Post subject: Coolant Temperature Control |
Yes, my kolb with the geo engine has a 195 degree thermostat. Why does the water temp read about 160 intstead of 140 when I add a piece of cardboard to the radiator? I don't know.
Sent: Monday, October 29, 2007 7:24 PM
Subject: Re: Coolant Temperature Control
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
Steven
://www.matronics.com/Navigator?Kolb-List
cs.com
Posted: Tue Oct 30, 2007 3:41 am Post subject: Coolant Temperature Control |
OOPs!
Jack B. Hart
Winchester, IN
At 11:11 PM 10/29/07 -0400, you wrote:
Jack,
Steven
