ron.mcgann(at)baesystems. Guest
Posted: Sun Oct 28, 2007 2:41 pm Post subject: Flap Positioning System - Epilog |
Ok, I think I have this puppy nailed.
If you have Showplanes FPS installation instructions (Iss A 2003) from their website, it contains NO info on the 10 - throw it in the bin.
If you have Showplanes FPS installation instructions (Iss C 2004) from Vans, it contains WRONG info on the 10 - throw it in the bin.
In the -10, flaps are retracted when the actuator is fully extended. This is the RV-8 configuration (as correclty pointed out by Rick S.), so measure the Positioning Rod Clamp to 5 15/16". Connect the Motor P1 to red, and Motor P2 to black as for the 4,6,7 and 9 models. This installation works as advertised for me.
I was wrong about the fusible links in the controller - they were actually the PC tracks that had completely lifted from the board!! (they certainly behaved like fusible links!). A replacement controller module is $45 for those interested.
I would highly recommend the use of a Molex style connector between the FPS and and flap motor, and make sure you disconnect the motor from the FPS if you need to drive it manually.
Cheers,
187
Ron - one problem solved 4,867,164 to go! [quote]"Warning:
The information contained in this email and any attached files is
confidential to BAE Systems Australia. If you are not the intended
recipient, any use, disclosure or copying of this email or any
attachments is expressly prohibited. If you have received this email
in error, please notify us immediately. VIRUS: Every care has been
taken to ensure this email and its attachments are virus free,
however, any loss or damage incurred in using this email is not the
sender's responsibility. It is your responsibility to ensure virus
checks are completed before installing any data sent in this email to
your computer."
