egodfrey(at)ameritech.net Guest
Posted: Mon Oct 29, 2007 6:46 am Post subject: Primer preparation question |
Listers,
For all of you who have primed your parts with Akzo, how did you
deal the steel parts, such as the nut plates and the WD-415 Trim Cable
Anchor Bracket?
Ed Godfrey
40717
rv10(at)sinkrate.com Guest
Posted: Mon Oct 29, 2007 7:52 am Post subject: Primer preparation question |
Bad Gas?
Eric_Kallio
Joined: 29 Jan 2006 Posts: 149 Location: Baton Rouge, LA
Posted: Mon Oct 29, 2007 8:30 am Post subject: Re: Primer preparation question |
I roughed the WD-415 with medium grit sandpaper then wiped with acetone then a clean dry cloth before priming. Almost 2 years since completing that section and still have good adhesion. As for the nutplates I have been using the same old scotchbrite scuffing method that we are all SOOOOO familiar with. Good results so far.
Eric Kallio
40518
