mark.j(at)yakuk.com Guest
Posted: Mon Feb 20, 2006 3:16 am Post subject: Tin |
http://www.fuelcat.co.uk/history.html
can Brian or would Ernie like to comment on this subject. About ½ way down the page is the interesting stuff ref Russian a/c. I know there are experts on this list ref Ethanol additives in fuel.
Cheers, mj
brian
Joined: 02 Jan 2006 Posts: 643 Location: Sacramento, California, USA
Posted: Mon Feb 20, 2006 10:14 am Post subject: Tin |
Mark Jefferies-YAK UK wrote:
| Quote: | http://www.fuelcat.co.uk/history.html
I don't see any references to alcohol in your link but will comment
anyway as I suspect that the US is going to go in for ethanol in a big
way here very soon. We have the ability to produce it in quantities that
make it attractive.
Ethanol has two strikes against it as a replacement fuel for aircraft:
1. It tends to be more corrosive. You have to go through your fuel
system and replace things that are prone to attack by alcohols.
2. It has only about 1/2 the energy density of gasoline. Here:
Ethanol: 26.8 MJ/Kg (megajoules per kilogram)
Gasoline: ~45 MJ/Kg
That means, to produce the same horsepower for the same length of time,
you will need to carry almost double the weight of gasoline in alcohol.
Either that or cut your range in half.
The only good thing about alcohol is that it has such a high octane
rating that detonation is almost impossible. This lends itself to very
high power-to-weight ratio high-compression supercharged engines or
engines that are much more efficient.
If you just want an airplane to play with locally, alcohol might be an
acceptable fuel. If you want an airplane to go cross-country with,
alcohol sucks.
Brian Lloyd 361 Catterline Way
brian-yak at lloyd dot com Folsom, CA 95630
- Antoine de Saint-Exupery
_________________ Brian Lloyd
- Antoine de Saint-Exupery |
L39parts(at)hotmail.com Guest
Posted: Mon Feb 27, 2006 7:44 pm Post subject: Tin |
So do you guys have to wear flight suits over there?
Posted: Mon Feb 27, 2006 7:53 pm Post subject: Tin |
3) vapor pressure
brian
Posted: Mon Feb 27, 2006 9:02 pm Post subject: Tin |
On Feb 27, 2006, at 7:53 PM, Ron Davis wrote:
Good point. I was thinking that the RVP of ethanol was lower than
gasoline. Even so, that is just a minor engineering problem. You
can't engineer away lower energy density.
| Quote: | > Ethanol has two strikes against it as a replacement fuel for
> aircraft:
> Gasoline: ~45 MJ/Kg
— Antoine de Saint-Exupéry
