georgerace
Posted: Fri Oct 26, 2007 12:33 pm Post subject: Tachometer for Jabiru 2200A |
I Need some advise from the group.
I am going to have a Grand Rapids System EIS, which I know will show the engine RPM.
I also want to have a "steam gauge" Tachometer as well in the panel in front of me.
Can someone please give me the manufacturers name and part number of a suitable 3 1/8 inch Tach that will work with the 2200A. Would really like one that has a maximum range of 3500 RPM, but any up to 5000 RPM would probably work OK as well.
George
Building CH701 (N73EX Reserved)
_________________ Check out my CH-701 project at:
http://www.mykitairplane.com |
Posted: Fri Oct 26, 2007 3:32 pm Post subject: Tachometer for Jabiru 2200A |
Hi George,
I've a GRS EIS system and use a 3-1/8-inch VDO tachometer as well. I
had a UMA that couldn't be made to work
so I went with VDO. The instant read on the GRS is faster on the draw
than the VDO tachometer, but they are about 50 rpm
of agreement with each other almost all of the time. (It's in a Subaru,
but the ignition read should be the same if wired correctly)
http://www.macsmachine.com/images/completion/full/panelatcruise.gif
George Race wrote:
| Quote: | I Need some advise from the group.
the engine RPM.
front of me.
George
dave.thompson(at)verizon. Guest
Posted: Sat Oct 27, 2007 4:55 pm Post subject: Tachometer for Jabiru 2200A |
Try the following link, very well made instruments for the price.
http://autometer.com/cat_gaugeop.aspx?sid=12
pete(at)usjabiru.com Guest
Posted: Mon Oct 29, 2007 5:16 am Post subject: Tachometer for Jabiru 2200A |
Try a UMA 19-819-105. They work very well. www.umainstruments.com
Pete
From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of George Race
Sent: Friday, October 26, 2007 3:33 PM
Subject: Tachometer for Jabiru 2200A
George
| Quote: | | http://www.matronics.com/Navigator?Zenith-List | 01234
