sam(at)fr8dog.net Guest
Posted: Thu Oct 25, 2007 7:00 am Post subject: Fuel Valve Problem |
I've discovered that when the fuel is off, the engine can be started
taxied and a runup completed, with the fuel selector in the off position.
Another nice surprise I discovered, is when the tanks are topped off,
fuel will transfer from one wing to the other, and pump precious fuel
overboard through the vent line, but only on the ground, I think, at
least so far. Has anyone else experienced this?
Sam Marlow
#40157
Van's standard kit.
LloydDR(at)wernerco.com Guest
Posted: Thu Oct 25, 2007 7:27 am Post subject: Fuel Valve Problem |
If you have the fuel transfer between tanks then you have an issue with
your valve, the tanks are isolated from each other, even if you used the
standard Vans fuel valve it should not parallel the tanks and allow
cross transfer. Search the archives because there has been allot of
discussion about cross feeding the tanks for this very reason, if you
are on an angle/hill fuel will run over board through the low side tank.
I think there is a couple of builders out there that did cross feed
their tanks even though it is not recommended.
Dan
N289DT RV10E Flying
Tim Olson
Posted: Thu Oct 25, 2007 7:31 am Post subject: Fuel Valve Problem |
Which valve do you have....that doesn't sound right or good
at all...not even a little. With the Andair in place, mine
will die in short order once the valve is turned off, and
the wing tanks are always exactly where they were when the
last flight ended.
Sam Marlow
#40157
Van's standard kit.
wcurtis(at)nerv10.com Guest
Posted: Thu Oct 25, 2007 7:51 am Post subject: Fuel Valve Problem |
Are we talking about a high wing Cessna or an RV-10? With the standard fuel plumbing there should be no transfer of fuel from one tank to the other. Also, consider the length of tubing from the fuel selector to the engine; this should allow only a few seconds of fuel for the engine to run.
William
http://wcurtis.nerv10.com/
Posted: Thu Oct 25, 2007 8:05 am Post subject: Fuel Valve Problem |
I have the Van's standard valve, V407P-4.....
The aircraft is grounded untill I get this sorted out. I have talked to
Gus at Van's, and he said this is the first he's heard of a problem with
the valve. But that's what I here every time I contact them about any
problem!
last flight ended.
> position.
> Thanks,
> Sam Marlow
> #40157
> Van's standard kit.
Posted: Thu Oct 25, 2007 8:35 am Post subject: Fuel Valve Problem |
RV-10, of course. I'm well aware of the way the system works, I built it, but I'm trying to get the word out, there's a fuel transfer problem that's going to get someone hurt if it's not fixed. I've ordered a new valve from the factory, not Van's, but until it's installed, MY RV10 IS GROUNDED! There's no way enough fuel can be in the lines, on a stock built RV10 airframe to run the engine for 10 minuets.
I contacted the factory, talked to Guss, but he just insults me with redundant silly questions. I'm just the stupid pilot, builder, what do I know about airplanes.
Sorry to dump on you William, I'm just frustrated with support from Van's. I feel it's my responsibly to alert the RV10 builders of this potential lethal problem, even if Van's won't!
Sam
William Curtis wrote: [quote] [quote]--> RV10-List message posted by: "William Curtis" <wcurtis(at)nerv10.com> (wcurtis(at)nerv10.com) Are we talking about a high wing Cessna or an RV-10? With the standard fuel plumbing there should be no transfer of fuel from one tank to the other. Also, consider the length of tubing from the fuel selector to the engine; this should allow only a few seconds of fuel for the engine to run. William http://wcurtis.nerv10.com/ ------
Tim Olson
Posted: Thu Oct 25, 2007 9:04 am Post subject: Fuel Valve Problem |
Once you get a new valve in there, disect the old one and
let us know what you find. It'll be interesting if it's
a valve-related issue with a seal or something like that.
Could prove valuable knowledge for maintenance later for
some people.
Sam Marlow wrote:
[quote] RV-10, of course. I'm well aware of the way the system works, I built
Sam
> William
Posted: Thu Oct 25, 2007 9:18 am Post subject: Fuel Valve Problem |
I'll do that, thanks Tim.
Tim Olson wrote: [quote]--> RV10-List message posted by: Tim Olson <Tim(at)MyRV10.com> (Tim(at)MyRV10.com)
some people.
Sam Marlow wrote:
[quote]RV-10, of course. I'm well aware of the way the system works, I built it, but I'm trying to get the word out, there's a fuel transfer problem that's going to get someone hurt if it's not fixed. I've ordered a new valve from the factory, not Van's, but until it's installed, MY RV10 IS GROUNDED! There's no way enough fuel can be in the lines, on a stock built RV10 airframe to run the engine for 10 minuets.
Sam
William
Posted: Thu Oct 25, 2007 10:41 am Post subject: Fuel Valve Problem |
Sam,
Not a problem, that question was posed with tongue planted firmly in cheek:-)
Do not archive.
William
n8zg(at)bellsouth.net Guest
Posted: Thu Oct 25, 2007 12:34 pm Post subject: Fuel Valve Problem |
Sam -
Yank that valve and throw it under your bench.
It will make a very nice spider habitat.
Get yourself an Andair FS20X7-T.
Neal
MauleDriver(at)nc.rr.com Guest
Posted: Thu Oct 25, 2007 1:34 pm Post subject: Fuel Valve Problem |
For reference, minutes ago, I placed an order for an Andair EFS20B7-T.
It has the 2 90deg elbows oriented downwards so the valve fits within
the width of the tunnel and an extension so the SCAT can go over the
valve.
Thanks to all for the help.
Neal George wrote:
Quote: |
Sam -
Neal
coop85(at)cableone.net Guest
Posted: Thu Oct 25, 2007 1:35 pm Post subject: Fuel Valve Problem |
That brings up a good question. Has anyone done the standard to Andair fuel
valve conversion with a finished airplane? I've thought about doing it but
wonder what might be involved in changing the plumbing around.
Different note for Sam, I found if my machine is topped off I'll vent some
fuel so I always stop about 1" from a full top-off. Fuel transferring from
one side to another is the sign of a big problem in my opinion.
Marcus
VHMUM(at)bigpond.com Guest
Posted: Thu Oct 25, 2007 2:26 pm Post subject: Fuel Valve Problem |
Sam just wondering did all the basic tests , did you test your fuel selecter
for correct fuel flows etc. I mean fill one tank then time the fuel flow
switch to the other nothing shoud come out? Off position , nothing comes
out.Empty the tank repeat other side?
Time the fuel flows. Just wondering if its just your valve only. I didnt
want to go a spend more money if not needed. I am not at the point were I
can test the valve.
I am probably missing something as usual so feel free to point me in the
right direction
regards Chris
AV8ORJWC
Posted: Thu Oct 25, 2007 3:54 pm Post subject: Fuel Valve Problem |
Sam, you are the kind of pilot we should all strive to emulate. Fuel Shutoff is exactly that. Good luck returning safely to the air soon.
John Cox
#40600
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Sam Marlow
Sent: Thursday, October 25, 2007 9:35 AM
Subject: Re: Fuel Valve Problem
Sam
William Curtis wrote: [quote]--> RV10-List message posted by: "William Curtis" <wcurtis(at)nerv10.com> Are we talking about a high wing Cessna or an RV-10? With the standard fuel plumbing there should be no transfer of fuel from one tank to the other. Also, consider the length of tubing from the fuel selector to the engine; this should allow only a few seconds of fuel for the engine to run. Williamhttp://wcurtis.nerv10.com/ ------
Posted: Thu Oct 25, 2007 5:02 pm Post subject: Fuel Valve Problem |
Thanks again, this list has been very gracious.
Sam
William Curtis wrote: [quote] [quote]--> RV10-List message posted by: "William Curtis" <wcurtis(at)nerv10.com> (wcurtis(at)nerv10.com) Sam, Not a problem, that question was posed with tongue planted firmly in cheek:-) Do not archive. William http://wcurtis.nerv10.com/ ------
Posted: Thu Oct 25, 2007 5:07 pm Post subject: Fuel Valve Problem |
I may end up doing just that, but in all fairness, I have to give Van's
a chance to make it right.
Neal George wrote:
Quote: |
Sam -
Neal
bob.kaufmann(at)cox.net Guest
Posted: Thu Oct 25, 2007 5:13 pm Post subject: Fuel Valve Problem |
Not that far along but did you expect anything less from Van’s. It’s not a Lycoming so no help from the factory, and wish that I was that far along. Bob K
Sent: Thursday, October 25, 2007 5:02 PM
Sam
William Curtis wrote: [quote]--> RV10-List message posted by: "William Curtis" <wcurtis(at)nerv10.com> Sam, Not a problem, that question was posed with tongue planted firmly in cheek:-)Do not archive. Williamhttp://wcurtis.nerv10.com/ ------
Posted: Thu Oct 25, 2007 5:17 pm Post subject: Fuel Valve Problem |
Not exactly to that extent, but I did use compressed air to verify
integrity of the valve.
Chris and Susie McGough wrote:
<VHMUM(at)bigpond.com>
selecter for correct fuel flows etc. I mean fill one tank then time
the fuel flow switch to the other nothing shoud come out? Off
position , nothing comes out.Empty the tank repeat other side?
didnt want to go a spend more money if not needed. I am not at the
point were I can test the valve.
the right direction
regards Chris
Posted: Thu Oct 25, 2007 5:19 pm Post subject: Fuel Valve Problem |
Thank's John, I'll get to the bottom of of it yet.
You guy's are great, that's the reason I'm on this fourm, so we all can
learn and stay safe!
John Cox
#40600
[mailto:owner-rv10-list-server(at)matronics.com] *On Behalf Of *Sam Marlow
*Sent:* Thursday, October 25, 2007 9:35 AM
*To:* rv10-list(at)matronics.com
*Subject:* Re: Fuel Valve Problem
minuets.
Sam
William
Posted: Thu Oct 25, 2007 5:42 pm Post subject: Fuel Valve Problem |
Sam would you think this might help to verify the source of the problem if
you did it.
regards Chris
