n8vim(at)arrl.net Guest
Posted: Mon Feb 20, 2006 8:30 am Post subject: Antenna options./Tailcone Riveting |
John,
On riveting the tailcone, it helps if you have a partner...
I had no help, so here's how I did it:
Put the Clecos in from the INSIDE of the tailcone, then you will
find your back riveting plate can slide in underneath the skin between
the clecos. Then just start Back riveting! Of course, when you get to
the aft top skin, you will need a partner, but other than that back
rivet away!
I even back riveted the curved sections; Get a few pillows or
foam blocks to hold the tailcone in position to back rivet the one you
need to rivet, then adjust positions, and repeat.... (Did I mention it
totally sucks doing it all alone?)
Enjoy it! This is the first piece that is big enough to show friends
what size your plane is! (All my friends thought the Horizontal
Stabilizer was the main wing!!!)
-Jim 40384 (SafeAir/Hotel Whiskey tip tanks are due to arrive
Wednesday!)
John Gonzalez wrote:
Quote: |
Just curious as to whether anyone has tried to use one of those AAE
dipole antennas in their fiberglass wing tips. Using these would make
the plane more aerodynamically sound. Both comm, Nav and Transponder
antennas are available.
On another note, I will hopefully start riveting the tailcone next
weekend. Are there any suggestions on riveting those curved tailcone,
fuselage corners as this will be the first time with a part like
this....all so highly visible.
JOhn G.
Posted: Mon Feb 20, 2006 8:51 am Post subject: Antenna options./Tailcone Riveting |
I hadn't read far enough ahead to realize there was that much back riveting.
I am interested in learning about your wing tip tanks after you install
them.
John G.
DNA
Quote: | From: James Hein <n8vim(at)arrl.net>
Reply-To: rv10-list(at)matronics.com
Subject: Re: Antenna options./Tailcone Riveting
Date: Mon, 20 Feb 2006 11:28:22 -0500
John,
find your back riveting plate can slide in underneath the skin between the
clecos. Then just start Back riveting! Of course, when you get to the aft
top skin, you will need a partner, but other than that back rivet away!
I even back riveted the curved sections; Get a few pillows or foam
blocks to hold the tailcone in position to back rivet the one you need to
rivet, then adjust positions, and repeat.... (Did I mention it totally
what size your plane is! (All my friends thought the Horizontal Stabilizer
Wednesday!)
>Just curious as to whether anyone has tried to use one of those AAE dipole
>antennas in their fiberglass wing tips. Using these would make the plane
>more aerodynamically sound. Both comm, Nav and Transponder antennas are
>available.
>JOhn G.
>http://www.matronics.com/Navigator?RV10-List
Posted: Mon Feb 20, 2006 9:00 am Post subject: Antenna options./Tailcone Riveting |
John,
The plans make no mention on how to rivet the tailcone; It is up to
you. Since I had no help, I had to figure out how I would do it, so I
spent many hours clecoing, moving clecos, removing clecos, putting them
from inside, etc. until I figured out how I could do it.
Enjoy!
-Jim
riveting.
install them.
John G.
DNA
> John,
> will find your back riveting plate can slide in underneath the skin
> between the clecos. Then just start Back riveting! Of course, when
> you get to the aft top skin, you will need a partner, but other than
> you need to rivet, then adjust positions, and repeat.... (Did I
> mention it totally sucks doing it all alone?)
> friends what size your plane is! (All my friends thought the
> Horizontal Stabilizer was the main wing!!!)
> Wednesday!)
>> <indigoonlatigo(at)msn.com>
>> make the plane more aerodynamically sound. Both comm, Nav and
>> Transponder antennas are available.
>> tailcone, fuselage corners as this will be the first time with a
>> part like this....all so highly visible.
>> JOhn G.
Deems Davis
Posted: Mon Feb 20, 2006 10:34 am Post subject: Antenna options./Tailcone Riveting |
I also riveted my tailcone as Jim suggested. One thing that made a BIG
difference was that I got a BIG back rivet plate (16"x20"), I just went
down to the scrap metal dealer and found a piece of 5/16" (1/4"?). It
made it a lot easier as I was able to load more rivets at one time, and
also minimized the risk of getting off the plate.
Deems Davis # 406
Fuse
http://deemsrv10.com/
James Hein wrote:
Quote: |
John,
rivet away!
Wednesday!)
> tailcone, fuselage corners as this will be the first time with a part
> JOhn G.
