faisalasif
Posted: Wed Oct 31, 2007 11:56 am Post subject: :: Flight Testing :: |
Hello everyone,
I hope you all are doing fine.
Now I was wondering if there is a Flight Testing Standard available that addresses all safety issues. (and its free)
If not, I am planning to take up this issue and create a proper Flight testing Plan that addresses all safety issues for any single engine / prop based aircraft. This should be free for all to use and refer too.
Anyone interested in directing me towards a better resource or assisting me in my attempt.
awaiting your valuable comments,
faisal.
faisal (at) scaled.com.pk
and yes not to forget ..... do not archive
jb92563
Joined: 23 Mar 2007 Posts: 314 Location: Southern California
Posted: Wed Oct 31, 2007 12:11 pm Post subject: Re: :: Flight Testing :: |
The EAA website has good information on Flight Testing Experimental Aircraft.
I think this would be a good source of information for you.
www.eaa.org
http://www.eaa.org/home/homebuilders/testing/articles/articles.html
_________________ Ray
Moni MotorGlider
Schreder HP-11 Glider
Grob 109 Motorglider
Do Not Archive |
faisalasif
Posted: Wed Oct 31, 2007 12:20 pm Post subject: Re: :: Flight Testing :: |
They are a list of articles not a complete Flight Test Plan.
I have not seen any plan on EAA that carries Flight Testing Checklists or Flight Testing Cards (As advised for testing by FAA).
normally only a general description is given not the complete procedure to follow.
They normally don't even tend to provide you with possible adverse effects of attempting a maneuver.
I intend to make a Complete. Step by step list that addresses each test, its need, its procedure, its pits and falls, requirements for attempting the maneuver, recording of the result, analyzing it to define limitations.
Comments?
jb92563
Posted: Wed Oct 31, 2007 12:42 pm Post subject: Re: :: Flight Testing :: |
FAA AC 90-89a - Amatuer-Built Aircraft & Ultralight Flight Testing Handbook
has a lot more step by step information as well, also on the EAA website.
Since that has been adequate for Home builders, if you need more, you will probably have to use one of the large aerospace agencies criteria for flight testing.
Not likely that they will make any of that available to a non-staff member.
Moni MotorGlider
Do Not Archive |
possums(at)bellsouth.net Guest
Posted: Wed Oct 31, 2007 1:52 pm Post subject: :: Flight Testing :: |
At 03:56 PM 10/31/2007, you wrote:
Hello everyone,
Anyone interested in directing me towards a better resource. or
assisting me my attempt.
Here's one for free:
http://www.faa.gov/library/manuals/aircraft/media/ac90-89a.pdf
purplemoon99(at)bellsouth Guest
Posted: Wed Oct 31, 2007 2:54 pm Post subject: :: Flight Testing :: |
Are you testing a airplane or a rocket ship ? Joe N101HD
DO not art.
vincenic1(at)embarqmail.c Guest
Posted: Wed Oct 31, 2007 6:30 pm Post subject: :: Flight Testing :: |
faisal,
A book that I have liked that addresses what to test, what to expect
and what to do to fix it is:
<http://www.amazon.com/Flight-Testing-Homebuilt-Aircraft-Vaughan/dp/1560276282/ref=sr_1_1/002-8840113-1392856?ie=UTF8&s=books&qid=1193883942&sr=1-1>
Flight Testing Homebuilt Aircraft
by Vaughan Askue (Paperback - Jul 1, 1992)
Amazon has the book and you can see more detail at:
http://www.amazon.com/s/ref=nb_ss_gw/105-4398161-6985248?url=search-alias%3Dstripbooks&field-keywords=askue+homebuilt+aircraft&x=0&y=0
Vince Nicely
Firestar II
faisalasif wrote:
They area list of articles not a complete Flight Test Plan.
Comments?
http://forums.matronics.com/viewtopic.php?p=142987#142987
