Pin Wrench
JBernier(at)dart.org
PostPosted: Tue Feb 21, 2006 6:48 am    Post subject: Pin Wrench Reply with quote
The pin Wrench can be purchased at ET Supply Surplus, P.O. Box 78190, 5055 Exposition Blvd., Los Angeles, Ca. 50016. Request a catalog. You will be amazed at the amount of stuff he has and the low prices.
The wrench that you want is part No. 0609 at $3.50 per wrench.
If you want to call, his number is 323-734-2430 / Fax 323-734-1511.
He does business by credit card mainly.
Since it is a 1 lb. item the highest charge for shipping/handling is $4.90.
You might be able to contact him by phone, not the easiest.
If you are not in a hurry I would ask for a catalog and go from there. I
found him to be an honest man. Dealt with him several times.
I have attached the form and shipping sheets.
If you are a do it yourselfer, this catalog is a must.
Jim
Form.pdf
 Filename:  Form.pdf
 Filesize:  347.41 KB
 Downloaded:  409 Time(s)
06-02-07.pdf
 Filename:  06-02-07.pdf
 Filesize:  363.52 KB
 Downloaded:  491 Time(s)
