CJohnston(at)popsound.com Guest
Posted: Thu Nov 01, 2007 9:56 pm Post subject: Alternate static switch |
Hey all -
a bit of discussion awhile back about ways to do alternate static air, and i promised i'd report back on my findings. The long and short is that the toggle valve from clippard seems to be super cool. seemingly, it works well with the Safeair1 static quick connect kit. i've blathered on about it on my site here:
http://www.perfectlygoodairplane.net/Perfectlygoodairplane/Alternate%20Static%20switch.html
anyway, the part# for the clippard toggle valve is the TV-2SP. I Haven't actually installed it and done a static system leak test or anything, but hopefully when i do it won't leak
cj
flysrv10(at)gmail.com Guest
Posted: Fri Nov 02, 2007 2:38 am Post subject: Alternate static switch |
Thanks for the tip. I went to the site and looked for TV-25P and
could not find it. Are you sure that it is not TV-2SP?
Thanks.
Rob.
On Nov 2, 2007, at 1:55 AM, Chris Johnston wrote:
| Quote: | Hey all -
cj<winmail.dat>
Posted: Fri Nov 02, 2007 4:55 am Post subject: Alternate static switch |
The original e-mail said TV-2SP on my computer.
Jesse Saint
Saint Aviation, Inc.
jesse(at)saintaviation.com
www.saintaviation.com
Cell: 352-427-0285
Fax: 815-377-3694
Posted: Fri Nov 02, 2007 5:38 am Post subject: Alternate static switch |
Thanks. That must be it.
On Nov 2, 2007, at 8:54 AM, Jesse Saint wrote:
<jesse(at)saintaviation.com>
Jesse Saint
Cell: 352-427-0285
Fax: 815-377-3694
Nick Leonard
Joined: 18 Jun 2007 Posts: 35 Location: Sacramento, CA
Posted: Fri Nov 02, 2007 8:38 am Post subject: Re: Alternate static switch |
The switches are readily available at McMaster-Carr (McMaster.com), which is a great store to work with and they have an incredible inventory. I just got the 6791T13 which has the plastic toggle switch. The 6791T11 and 6791T12 have the metal switches.
I was hoping that the plastic switch would look more like the 'standard' electrical "bat" switch. It is similar but the handle is slightly narrower and longer. It will still look good in the panel but will need to be placed out of the way so it isn't accidentally switched on (open).
These are a very cool solution for an alternate static switch and reasonably priced.
_________________ Nick Leonard
RV-10 (40015) Flying |
