Useable Fuel verification on the RV-10
Tim(at)MyRV10.com
PostPosted: Mon Feb 20, 2006 5:22 pm    Post subject: Useable Fuel verification on the RV-10 Reply with quote
I have always heard that the useable fuel in the RV-10 was basically
ALL of it.
A couple days ago I had the opportunity to do a controlled test
of this.
After initially calibrating my fuel float sensors using FORWARD
sensing on the GRT EIS 6000 with my Chelton, and finding that they
really needed to be done with REVERSE sensing, I needed to drain
my tanks to get an empty and full reading from the EIS.
So I flew at 4000' AGL above the airport for what I figured
was the last few gallons of my left tank, until it ran out.
It was very interesting as my Chelton started barking at
me to "check engine" before the engine started to run rough,
because it noticed the fuel pressure dropping below limits.
I switched the valve over and everything was well. I landed,
drained the sumps into a gas can and only got out maybe 1/2
to 1qt at most. I filled the tank and calibrated it. I
then did the same flight on the right tank with the same results,
and filled that one and calibrated that one as well.
So yes, all fuel is basically useable fuel in the RV-10.
In addition, today I checked my calibration and found that the
reading on my instruments for remaining gallons was dead-nuts-on
when I topped off the tanks.
It's VERY nice to know exactly how much fuel you have. Amazing
that with float sensors I can actually say I have readings I
can trust.
Tim
jesse(at)itecusa.org
PostPosted: Mon Feb 20, 2006 5:49 pm    Post subject: Useable Fuel verification on the RV-10 Reply with quote
Do your tanks fit 30 gallons from empty? We put 32 gallons in per side
based on the pump we were using. Anybody else see this?
Jesse Saint
I-TEC, Inc.
www.itecusa.org
Fax: 815-377-3694
I am in Ecuador until May, 2006. If you have questions regarding I-TEC,
please call the office at 352-465-4545. If you would like to talk to me,
please call me at 352-505-1899. This number won't always be on, but it has
voicemail that will get to me in Ecuador.
Tim(at)MyRV10.com
PostPosted: Mon Feb 20, 2006 6:09 pm    Post subject: Useable Fuel verification on the RV-10 Reply with quote
Mine top of at almost exactly 30 gallons each side too.
Also, regarding calibration, I find the floats stop changing
value at right around 24 gallons during a fillup. So, I set
my fuel reading to max out at 24. I can verify fuel on
the Chelton at 60 total, and use the totalizer, and the
float levels read 24/24 for the first part of the flight.
Then once they start coming down from there, they're accurate
all the way to zero. That's the recommended calibration
practice by GRT. That's funny you get 32 gallons when
you fill up. I can't imagine the tanks would vary that much
in construction. Do you trust the fuel pump you're using?
Maybe someone is gouging you. ??
Jesse Saint
I-TEC, Inc.
www.itecusa.org
Fax: 815-377-3694
LIKE2LOOP(at)aol.com
PostPosted: Mon Feb 20, 2006 7:29 pm    Post subject: Useable Fuel verification on the RV-10 Reply with quote
In a message dated 2/20/06 9:11:50 P.M. Eastern Standard Time, Tim(at)MyRV10.com writes:
you fill up.� I can't imagine the tanks would vary that much
in construction.� Do you trust the fuel pump you're using?
���� Fill a KNOWN 5 gallon gas can at several gas stations, and then at the airport fuel pump and see if you get the same results.�Best to do this when your car needs gas!!!�� Alternately, you can fill the�5 gallon gas can with water from 1 gallon milk jugs and note the level when 5 have been added.�� Don't use a�1 gallon can�for the test, the�larger 5 gallon volume will give more reliable data.� �Calibrate the pump first, then your tanks, or calculate the error and ask for a refund for all the gas they charged you for, and never delivered.... if that is the case.
DO NOT ARCHIVE �
Stephen Blank RV-10 Builder #40499 / C-170B flyer
766 SE River Lane
Port St. Lucie, FL 34983
772-475-5556 cell
