Broken ring
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Glasair-List
MPPalmer(at)aol.com
PostPosted: Tue Nov 06, 2007 4:11 pm    Post subject: Broken ring Reply with quote
Well, if the oil temp problem goes away after you re-do the cooler, then it's probably not a broken ring.
I've seen a broken 2nd ring... compression didn't catch it. Lot's of metal in the oil filter would. I should have taken a photo (this was before digital camera, I think) but the ring had worn away a section of the piston in the same way your arms make "snow angels" in the snow.
Mike Palmer <><
***************************** [quote][b]
- The Matronics Glasair-List Email Forum -
http://www.matronics.com/Navigator?Glasair-List
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Glasair-List All times are GMT - 8 Hours
