a.s.elliott(at)cox.net Guest
Posted: Sun Nov 04, 2007 3:16 pm Post subject: Fuel selector location? |
Another finishing detail question:
I have the standard Andair L-R-Off fuel selector from the kit. I have seen most aircraft with the selector mounted on the center console. Since there is no "both" position, we have to change tanks regularly in order to maintain fuel balance. So the selector ought to be in an easily accessible place. Clearly the center console is such a place, but...
In order to conserve valuable console space, and also to avoid an extra high spot in the fuel system, I was thinking of mounting the selector on a raised bracket on the floor, to the left of the center tunnel, forward of the controls (dual stick), and aft of the heel support. The "out" line would then run through a grommet back into tunnel and then forward to the firewall. So my question is for people with flying aircraft:
Would that location be relatively easily accessible in flight? Or would it be an uncomfortable contortion to reach it?
Andy Elliott, Mesa, AZ
N601GE (reserved)
601XL/TD/QB, Corvair, building...
purplemoon99(at)bellsouth Guest
Posted: Sun Nov 04, 2007 3:40 pm Post subject: Fuel selector location? |
Andrew,I thought that Andair made a switch that had off,left,right,and both,I was thinking about getting one . FS20x4 is there number I just looked it up , if it is any help Joe N101HD601XL/RAM
Ron Lendon
Posted: Sun Nov 04, 2007 5:39 pm Post subject: Re: Fuel selector location? |
Please try this at home.
Fill a glass with water. Take two drinking straws and place both in your mouth. Check the seal, place one straw in the water and the other outside the glass. Draw the water up the straw. Doesn't work does it? That is why the low wing doesn't have a both setting on the fuel selector.
_________________ Ron Lendon
CH 601 XLB
N601LT - Flying
Corvair Engine Prints:
archerm
Posted: Sun Nov 04, 2007 6:18 pm Post subject: Fuel selector location? |
I had similar concerns about raising the location of the fuel selector. I moved it down to keep it as low as possible. I wanted to make sure that there is a pressure head on the fuel selector. I then used an extension to keep the selector within easy reach. You can see it on this page of my website.
http://www.zodiacxl.com/Brake%20and%20Fuel%20system.htm
While I understand the need to conserve space. I also look at the functional priority of the systems on the aircraft. Fuel system management rates pretty high in my priority. When we look at accident statistics fuel management is one of the major failures. So in my panel it is where I can get to it.
Good Luck
Matt
www.zodiacxl.com
_________________ Matt
www.zodiacxl.com |
Ron, Couldn't you run off of BOTH with both tanks full for the" top
half ", I only fly from the top half any way,then it's time to re fuel. I
dont see why you couldn't fly off the frist 3/4 of the tanks ,then switch
back and forth between LEFT and RIGHT ? Joe N101HD 601XL/RAM
Posted: Sun Nov 04, 2007 7:17 pm Post subject: Fuel selector location? |
Look'slike It's going to be hard as hell to change that filter after you get the plane built, beatiful with the rest of the work... Joe N101HD 601XL
psm(at)att.net Guest
Posted: Sun Nov 04, 2007 7:57 pm Post subject: Fuel selector location? |
Hi Joe,
I couldn't resist commenting on this topic.
It is one of the "Nature of the Beast" issues that you must directly
control the fuel source in low wing airplanes. It has something to
do with the physics of liquids and the way gravity works as opposed
to the way pumps work.
In a liquid, the pressure increases with the depth of the
liquid. This means that when using gravity feed from high wing
tanks, the tanks will tend to equalize their height so you get
roughly the same amount of fuel from each tank when the lines from
the tanks are connected. This is what you get when you use "Both"
tanks in a high wing plane.
In a low wing plane, a pump must be used to raise the fuel from the
tanks to the engine. If you gave the pump a choice, it would take
its fuel from which ever tank had the lowest pressure. That means
the pump would always take its fuel from which ever tank had the
least fuel. With this arrangement you would never get any fuel from
the tank with the most fuel in it. This is not what you want in an
airplane. The normal solution is a selector switch that allows the
pilot to draw fuel from which ever tank he chooses.
In Piper low wing planes, the normal way to control the fuel is to
start with one tank (usually the left tank for some unknown reason)
and burn around 1/2 hour from it. Then you switch to the other tank
and burn from it for an hour. At this point you should be finished
with your flight, but if not you switch to the first tank and burn
another hour from it. For takeoff and landing you always switch to
the tank with the most fuel.
It sounds like a lot of work for a pilot used to high wing planes,
but you will get used to it quickly. There just isn't a better way.
Paul
XL fuselage
At 06:14 PM 11/4/2007, you wrote:
| Quote: | Ron, Couldn't you run off of BOTH with both tanks full for the"
top half ", I only fly from the top half any way,then it's time to
re fuel. I dont see why you couldn't fly off the frist 3/4 of the
tanks ,then switch back and forth between LEFT and RIGHT ? Joe
N101HD 601XL/RAM
bryanmmartin
Posted: Sun Nov 04, 2007 8:21 pm Post subject: Fuel selector location? |
If you forget to switch to left or right only and the engine quits because its sucking air instaid of fuel, which tank do you switch to to regain power? You may not get any clue from the guages at that point, so you've got a 50-50 chance. It may take a few seconds to get fuel flowing again even if you guess right, and if you guess wrong you've wasted valuable time that you might not have to waste. It's best not to have a both position at all. That way if you run one tank empty you know which tank to switch to to try for a restart. No guessing.
[quote]--> Zenith-List message posted by: "Southern Reflections" <purplemoon99(at)bellsouth.net (purplemoon99(at)bellsouth.net)>
Ron, Couldn't you run off of BOTH with both tanks full for the" top half ", I only fly from the top half any way,then it's time to re fuel. I dont see why you couldn't fly off the frist 3/4 of the tanks ,then switch back and forth between LEFT and RIGHT ? Joe N101HD 601XL/RAM
_________________ --
Bryan Martin
do not archive. |
Posted: Sun Nov 04, 2007 8:37 pm Post subject: Fuel selector location? |
Hi Paul, It's always good to to get your input,you have a way with words.I
now understand it very clearly ,so it's the Left or Right switch for
me...just didn't know about the pressure aspect,. Thank,s Joe N101HD
Posted: Sun Nov 04, 2007 8:39 pm Post subject: Fuel selector location? |
that's true too Bryan, This list is worth it's weight in gold, most of the time.. Thank's Joe N101HD
Posted: Mon Nov 05, 2007 4:34 am Post subject: Fuel selector location? |
Paul and you guys.
I learned to fly in 1965 in a BeechCraft. I was taught from day one to use
the left tank first because in the "bigger" airplanes the fuel pump would
feed fuel to the engine. Any excess fuel that wasnt needed by the engine
would be returned by the system to the left tank...
Using the right tank first and having excess returned to the left would
allow fuel to overflow out the vent....
I ve always "assumed" that was the straight scoop and never questioned my
instructor. Instructors are experts, now I are one...
SW
archerm
Posted: Mon Nov 05, 2007 9:34 am Post subject: Fuel selector location? |
Actually with the access panel up top. It isn't that bad to change or remove the filter. I considered putting it in the engine compartment but was concerned about heating. With out the removable panel it would be tough.
Matt
www.zodiacxl.com |
psm(at)ATT.NET Guest
Posted: Mon Nov 05, 2007 8:17 pm Post subject: Fuel selector location? |
Hi Steve,
Thanks for adding to the tank choice discussion. I think I have the
whole picture now.
I believe fuel injected aircraft engines require a fuel return
line. This somehow returns excess fuel from the injection pump to
the fuel tank. I guess there is a standard that in small low wing
planes, the left tank is the return location of choice. That makes
the left tank the best choice for first fuel burn.
While there is no necessary relationship between big planes and fuel
injection it is an advanced feature that can often be found on more
expensive planes. I have more hours in the C-172XP than any other
plane. This has a Continental IO-360 installed - a 6 cylinder fuel
injected engine. It is the smoothest running airplane engine I have
ever experienced. I have also flown a Piper Arrow with a Lycoming
IO-360 which has only 4 cylinders and doesn't run nearly as smoothly.
Paul
XL fuselage
At 04:32 AM 11/5/2007, you wrote:
| Quote: | Paul and you guys.
to use the left tank first because in the "bigger" airplanes the
fuel pump would feed fuel to the engine. Any excess fuel that wasnt
needed by the engine would be returned by the system to the left tank...
would allow fuel to overflow out the vent....
questioned my instructor. Instructors are experts, now I are one...
SW
Posted: Tue Nov 06, 2007 5:45 am Post subject: Fuel selector location? |
Paul
I guess my early training was just to get me used to procedures for
"furture" flying.
When I switched to Cessna it seemed soooo easy to transition to less complex
designs.
SW
John Bolding
Posted: Tue Nov 06, 2007 6:05 am Post subject: Fuel selector location? |
Hi Joe,
In a low wing plane, a pump must be used to raise the fuel from the tanks
to the engine. If you gave the pump a choice, it would take its fuel from
which ever tank had the lowest pressure. That means the pump would always
take its fuel from which ever tank had the least fuel. With this
arrangement you would never get any fuel from the tank with the most fuel
in it. This is not what you want in an airplane. The normal solution is
a selector switch that allows the pilot to draw fuel from which ever tank
he chooses.
Paul
XL fuselage
Paul, Maybe I need to learn something here, WHY would the pump draw fuel
from the tank with the lowest pressure (emptiest)??
That has not been my experience (2000 hrs in an RV3) , my tanks empty
equally with one pump sucking on both tanks at the same time.
LOW&SLO John Bolding
Posted: Tue Nov 06, 2007 6:31 am Post subject: Fuel selector location? |
I wonder why they dont tie the two tanks together with an "equalizer"
pipe... Then both tanks would keep the same level of fuel....
Actually thats how a high wing airplanes works. The two tanks tie together
and you dont need to swap left/right tanks...
sw
----- Origin
al Message -----
To: <zenith-list(at)matronics.com>
Sent: Tuesday, November 06, 2007 7:03 AM
Subject: Re: Re: Fuel selector location?
<jnbolding1(at)teleshare.net>
> Hi Joe,
> from which ever tank had the lowest pressure. That means the pump would
> always take its fuel from which ever tank had the least fuel. With this
> he chooses.
> Paul
> XL fuselage
lrm(at)skyhawg.com Guest
Posted: Tue Nov 06, 2007 7:09 am Post subject: Fuel selector location? |
Sometimes you want to burn off one side or the other to offside a heavy side
or wing. Makes it fly more gooder. Larry
Tim Juhl
Joined: 21 Mar 2006 Posts: 488 Location: "Thumb" of Michigan
Posted: Tue Nov 06, 2007 8:25 am Post subject: Re: Fuel selector location? |
Older Cessna I72's are placarded requiring flight on a single tank above 5000 feet. Apparently there is a greater risk of vapor lock in such aircraft that was due to the unvented caps and single vent line running between the two tanks. Later models are not placarded but I'm not sure exactly what they did to correct it besides the AD requiring use of a special cap that would vent in case of a vacuum in the tank.
I'm not big on doing a lot of experimenting on the fuel system.... keep it simple and go with what is known to work. In my experience, seemingly inconsequential changes can sometimes lead to unintended consequences.
_________________ ______________
CFII
Champ L16A flying
Zodiac XL - Jabiru 3300A
Almost done! It'll fly in spring! |
Posted: Tue Nov 06, 2007 9:19 am Post subject: Fuel selector location? |
Hi John,
I stand corrected.
Your message got me to do an experiment in my kitchen. I took two
identical glasses and put 2 ounces of water in one and 6 ounces in
the other one. I then took a big suck on two identical
straws. Measuring the remaining water in the glasses I discovered
there was one ounce taken out of each one. So, as you suggested the
water was not taken from the lower level "Tank" but taken equally
from both tanks.
You will notice this is not the same as the behavior of two gravity
fed tanks which will tend to equalize their levels. I started with 6
and 2 ounces and ended with 5 and 1. In a high wing model I would
have ended with 3 and 3.
So, I was wrong, but the "Both" solution still doesn't work for low
wing planes.
Paul
XL fuselage
At 06:03 AM 11/6/2007, you wrote:
| Quote: | Paul, Maybe I need to learn something here, WHY would the pump
draw fuel from the tank with the lowest pressure (emptiest)??
empty equally with one pump sucking on both tanks at the same time.
Trainnut01(at)aol.com Guest
Posted: Tue Nov 06, 2007 9:41 am Post subject: Fuel selector location? |
Hey Paul
If you keep sucking you'll find that when the lower level "tank" runs dry you will no longer be able to get "fuel" from the higher level "tank" even though it still will contain about 4 ounces.
Carroll
See wh [quote][b]
