jindoguy(at)gmail.com Guest
Posted: Tue Nov 06, 2007 5:56 pm Post subject: Cracking in tubing and welds? |
Grant, My Mk III is serial number 43. I've had it down for quite awhile to rebuild the electrical and fuel system and do a thorough inspection. I've found three spots worth checking.
1. If your fuel tank taps come out of the bottom of the plastic tanks, as mine did, check the rubber grommets for cracking. Mine were just about cracked through to the hole. How they didn't leak was just pure luck. Newer Mk III's have the taps on the top of the tank. Still a good idea to check the grommets.
2. Check how the trim system is hooked up. Mine had a cable that went from the spring all the way back to the elevator bell crank and then back forward again to the cockpit bell crank. When the trim lever was pulled back it caused the return cable to go slack and bang around inside the tail boom and the connection from the pedals went through the trim spring. The current system goes from the trim spring to a tab on the fwd side of the cockpit bell crank, then separate cables go from the cockpit bell crank to the elevator bell crank.
3. Water can gather at the low point of the cockpit right where there is a weld cluster. Mine was rusty and a pain to clean up. I used thin strips of emery cloth and put a matching strip of duct tape on the cloth side so the edges wouldn't abrade the cloth as I pulled it back and forth to get the rust off the bottom of the cluster. Otherwise a Dremel Tool with their little wire wheel took off all the rust on the top, sides and back. Work a piece of plastic between the cluster and the cloth, then space the cloth away from the cluster with something thin, I used tongue depressors, and slobber on some anti rust paint. Let dry and remove the spacers and the plastic.
Install the aileron counter weights, really important. Someday I'll figure out how to upload that few seconds of video I have of the ailerons flapping up and down as I did a fly by of the strip.
I guess that was really four things. No cracked welds, though.
Rick
On 11/6/07, grantr <grant_richardson25(at)yahoo.com (grant_richardson25(at)yahoo.com)> wrote:[quote] --> Kolb-List message posted by: "grantr" <grant_richardson25(at)yahoo.com (grant_richardson25(at)yahoo.com)>
| Quote: | My main concern for safely in our aluminum and chromoly tube structures is cracking of tubes and welds.
They unusually occur in those hidden areas that are hard to inspect.
I saw this posted under the chutes thread. Is this something to be overly concerned with?
Do motorcycles have the same issues? Ive just never heard of this in cycles. I thought metal fatigue was not that prevalent in our light non aerobatic planes.
My plane does not have a chute and my instructors challenger does not have a chute..
I do plan on finding a used one to put on it later just in case.
Grant
Posted: Wed Nov 07, 2007 5:44 am Post subject: Cracking in tubing and welds? |
The most overlooked tube is the lift strut carry-through, -that
single tube passing at the bottom,
beneath your sphincter musckles. That guy connects the total lift of
the struts and could
cause those musckles to contract considerably if it fails.
Seatbelts? yah, I am a firm believer, and I want you motorcycle guys
to buckle up too
BB
jb92563
Joined: 23 Mar 2007 Posts: 314 Location: Southern California
Posted: Wed Nov 07, 2007 1:21 pm Post subject: Re: Cracking in tubing and welds? |
It was me that posted the comment about cracks and welds on the safety & chutes thread.
There are no issues that I know of, just merely pondering the hypothetical modes of failure based on what little experience I have in my Kolb Ultrastar, that would require a deployment.
I was told by others on this list when I was buying my plane, to look for corrosion in the tubes since they are not protected internally.
I was also told to look for weak looking welds that may have resulted from a home repair by a poor welder.
Cracks are more an issue with some types of aluminum parts, as I had a cracked wing rib that failed at a rivet hole on the leading edge of the wing.
It buckled due to overshrinking the fabric at the wing tip.
No need to be overly concerned, just perform good preflights and check some of those high stress areas regularly and make sure the corrosion protection is replaced in those rare areas that start to rust.
_________________ Ray
Moni MotorGlider
Schreder HP-11 Glider
Grob 109 Motorglider
Do Not Archive |
Posted: Sat Nov 10, 2007 10:47 pm Post subject: Cracking in tubing and welds? |
of the wing.
rust.
| Ray
Ray:
I believe cracks are more an issue of both aluminum and 4130 parts,
especially fuselage welds. The nature of a two stroke engine
encourages stress cracks through high frequency vibration.
Personally, I would be more concerned with internal 4130 tube
corrosion than external. External corrosion I can see and fix.
Internal I have no control over unless I use tube seal to prevent.
Nellis AFB, Nevada
Big air show here tomorrow and Sunday. Happened to arrived here this
morning and was surprised by the old War Birds that were flying in
Nellis traffic.
_________________ John Hauck
Titus, Alabama |
Posted: Sun Nov 11, 2007 7:33 am Post subject: Cracking in tubing and welds? |
At 12:25 PM 11/9/07 -0800, you wrote:
Ray,
What causes the shake of the cage is the reaction force caused by engine
power pulse. Since the engine is geared most of the reaction forces
transferred to the cage are caused by the flywheel reaction of the propeller.
The lighter or lower inertia propeller is more easily accelerated and
de-accelerated, therefore there is less reaction force transmitted through
the mounts and on to the cage.
If the vibration amplitude is so low that it does not exceed the cage metal
yield stress, vibration frequency is a non issue. Has anyone any
documentation that a Kolb fell out of the sky because of a cage failure?
If you are really concerned about this go with the lowest inertia propeller
you can find.
Jack B. Hart FF004
Winchester, IN
Wade Lawicki
Joined: 27 May 2007 Posts: 31 Location: Nashville Tn.
Posted: Sun Nov 11, 2007 8:19 am Post subject: Re: Cracking in tubing and welds? |
I believe that the weld quality from the factory welded cages has never been a concern but, where i would be concerned is the older and used Ultrastars that were welded by the builder themselves with unknown credentials. I have seen 2 that were very bad and 1 of them did end up in a fatal crash.
Even though most of us are very competent and conscientious builders, the nature of our small planes attracts builders of all levels of experience , even some with none! Being extra thorough is never a bad thing.
Fly Safe, Wade
herbgh
Posted: Sun Nov 11, 2007 9:16 am Post subject: Cracking in tubing and welds? |
Jack and all
I think an engine mount that places the lord isolators in line with the
crank shaft center would be a great help. Herb
On Sun, 11 Nov 2007 10:42:11 -0500 "Jack B. Hart"
<jbhart(at)onlyinternet.net> writes:
<jhauck(at)elmore.rr.com>
Ray,
engine
propeller.
and
through
cage metal
failure?
propeller
you can find.
Jack B. Hart FF004
Winchester, IN
