503 Questions...
david(at)davidlehman.net
PostPosted: Thu Jan 05, 2006 10:23 am    Post subject: 503 Questions... Reply with quote
I have a 503 with a belt drive on my Firestar...
Questions:
1. May I run the engine without the prop installed?...
2. What grease should I use in the two drive shaft bearings (fortunately
they have zerks)...
Thanx...
DVD
ul15rhb(at)juno.com
PostPosted: Thu Jan 05, 2006 4:47 pm    Post subject: 503 Questions... Reply with quote
Dave,
I'm wondering why you decided to go with a belt drive over the reliable Rotax gear box?
I don't check the list that often and maybe you explained this a while ago.
Ralph
Original Firestar
19 years flying it
Questions:
they have zerks)...
Thanx...
DVD
PostPosted: Thu Jan 05, 2006 5:07 pm    Post subject: 503 Questions... Reply with quote
Ralph...
It's kinda like "run what you brung"...
I just bought this Firestar and that's what's on it...
David
On 1/5/06, Ralph <ul15rhb(at)juno.com> wrote:
Dave,
Rotax gear box?
ago.
Ralph
Original Firestar
19 years flying it
Questions:
they have zerks)...
Thanx...
DVD
richard(at)bcchapel.org
PostPosted: Thu Jan 05, 2006 6:43 pm    Post subject: 503 Questions... Reply with quote
Don't know about the grease. But be careful if you give it any gas, it
will go past the redline quicker than you could imagine.
Richard Pike
MKIII N420P (420ldPoops)
Questions:
they have zerks)...
Thanx...
DVD
ElleryWeld(at)aol.com
PostPosted: Thu Jan 05, 2006 7:39 pm    Post subject: 503 Questions... Reply with quote
Dave I wouldnt even think of starting that engine without a prop on it if
your carb is just cracked open a bit it could race beyond red line Be a sharp
pain and a Puff of smoke then you could be looking at purchasing another engine
as far as the Grease for your bearings I would use RED Tacky if you can get
it in your area if not any Premium RB quality grease would be ok
Ellery in Maine
PostPosted: Fri Jan 06, 2006 5:46 am    Post subject: 503 Questions... Reply with quote
Thanx Richard and Ellery...
I know better than to try and run a "big airplane" engine without a prop,
but I wasn't sure about a "snowmobile" engine...
I'll start looking for the grease...
Thanx again...
DVD
sharp
engine
get
Ellery in Maine
gtalexander(at)att.net
PostPosted: Fri Jan 06, 2006 6:05 am    Post subject: 503 Questions... Reply with quote
David:
Had two Quicksilvers with flex drives. On the recommendation of an expert, used white lithium grease. Would also grease it without the prop. Would warm the engine with the prop on, remove the prop and back the idle adjustment (slide stop) out so that the slide would go down as far as it could reducing the idle speed. As I recall, my R503, single carb, pts ign, would run at around 4k rpm under these conditions. Don't over do the grease and don't forget to adjust the idle stop when you put it all back together.
My .02 worth. May not work for you. Take your own chances.
George Alexander
http://gtalexander.home.att.net
DO NOT ARCHIVE
-------------- Original message from David Lehman <david(at)davidlehman.net>: --------------
donghe(at)one-eleven.net
PostPosted: Fri Jan 06, 2006 6:25 am    Post subject: 503 Questions... Reply with quote
David,
For a long time fellas have be starting Rotax 503's without a prop...and
nothing but a centrifical clutch hooked to a varible sheave torque convertor
with no probs...just make sure the throttle slide is down and you are
operateing on the idle circuit. Not a big deal to anybody who understands a
snowmobile.
Don Gherardini
OEM.Sales / Engineering dept.
American Honda Engines
Power Equipment Company
CortLand, Illinois
800-626-7326
PostPosted: Fri Jan 06, 2006 7:23 am    Post subject: 503 Questions... Reply with quote
Thanx Don...
I'm in "Lovely" Fresno so I'm not very conversant with snowmobiles...
I have to remove my prop to get the Firestar in and out of my garage (wings
folded), but it sounds like I better install it to run the engine in my
driveway...
Thanx...
DVD
On 1/6/06, Don Gherardini <donghe(at)one-eleven.net> wrote:
David,
convertor
a
snowmobile.
Don Gherardini
CortLand, Illinois
800-626-7326
PostPosted: Fri Jan 06, 2006 8:38 am    Post subject: 503 Questions... Reply with quote
One more thing David....withn no load on the 503, the 6500 redline could be
exceeded alot with no damage....it is under load and cylinder pressure that
you need to be careful. So dont be afraid to hit the throttle a tad to see
if it will take. But remember this...it will give you no indication of a
correct carb setup running it this way. Once you put the prop on it and you
have a load, it will be all different.
Don Gherardini
CortLand, Illinois
800-626-7326
PostPosted: Fri Jan 06, 2006 8:54 am    Post subject: 503 Questions... Reply with quote
Excellent advice, thanx Don...
DVD
be
that
you
Don Gherardini
CortLand, Illinois
800-626-7326
jhauck(at)elmore.rr.com
PostPosted: Fri Jan 06, 2006 2:35 pm    Post subject: 503 Questions... Reply with quote
could be
| Don Gherardini
Hi Don G/Gang:
You need to explain this exception to exceeding the red line please.
First, the red line on all the Rotax two strokes is 6,800 rpm for 5
minutes, and 6,500 max continuous.
This may be something new, but all I have ever been taught and know of
red lines is just that, do not exceed the red line. Nothing has ever
been mentioned of loaded or unloaded exceptions.
I know there are exceptions for the four strokes and probably the two
strokes also, but can not recite them off the top of my head. This
applies to rpm, egt, cht, oil temp, and for the 582, water temp.
If any of you have any specific questions you would like me to ask
Erick Tucker, instructor for Rotax two and four strokes schools,
please let me know. I will do my best to get him to answer them for
me and report back when I get the answers.
Paul Petty, his pappy-in-law Charley, and I will be attending the 912
course at South Mississippi Light Aircraft the end of this month, in
Lucedale, MS. This will be the third time around for Paul and I.
Reckon we will ever get it right?
Wink
One of the best advantages of attending one of these schools is the
additional info one picks up from Erick that is not in the manuals.
Erick is a good instructor and has been the Rotax from the very
beginning. I remember an article in one of the magazines about Erick
and how he was starting up a new company to use Rotax engines for
little airplanes in Vernon, BC. I have been looking for this old mag
during my sorting and throwing operation, but have not been able to
put my finger on it. This would have been in the 1983 time frame.
BTW: Richard Swidersky, I have not forgotten (entirely) about the
Experiment with you and the Flying Stork (his Ultrastar with very long
legs) on the back cover. It will be mailed to you pretty soon, I
hope.
Take care,
MKIII
link(at)cdc.net
PostPosted: Fri Jan 06, 2006 4:12 pm    Post subject: 503 Questions... Reply with quote
John,
Could you scan that picture and put it on photoshare. (Ultra stork) Some
of us ultrastar owners and others would find it interesting.
Steve Garvelink
PostPosted: Fri Jan 06, 2006 4:34 pm    Post subject: 503 Questions... Reply with quote
Steve/Gang:
Be glad to. Hang on for a few minutes until I can find and scan it.
john
DO NOT ARCHIVE
PostPosted: Fri Jan 06, 2006 5:22 pm    Post subject: 503 Questions... Reply with quote
HI John....and gang...
Sure I will explain this seemingly wild comment about redline on the 503.
First..I stand corrected on the redline as John mentions...6800...not 6500.
A piston ported 2 cycle...such as the 447/503 Rotax engine has no moving
parts other than the crank, rod, and piston. Unlike rotary valve 2 cycle, or
a reed valved engine or 4 cycle engines there are no valves to float,
pushrods to disengage from rockers or lifters, oil pumps to cavitate or
shear pins to break, worm gears to strip and so on. Much experience in the
snowmobile world with raiseing the exhaust ports and stuffing crankcases ,
expansion chambers and the like have shown us for a long time that these
piston ported Rotaxs will take a lot more RPMS than 6800....I can attest to
snowmobilers running them at 8K all the time, WOT out across the Frozen
lakes and feilds.
This However does not happen under the load factor that a propellor put on
them.
They also cool better when running at the typical ambient temps of
snowmobiling sport.
I also know...from experience...that sitting on a sled and rapping the
throttle of a machine with an souped up torque-convertor that the rpms come
easy before the load is large enough to pull rpms down below redline and ill
effects seldom manifest themselves. Also I might add, the running of these
engines with nothing at all hooked up to the crank never bothered them when
they were in sleds...dont know why it would hurt them now. The Rotax
gearboxs with clutch assemblies and the sprague clutchs many run simulate
the same thing.
Hence, my advice to David that if he wants to attempt to start his engine
with out a prop on it...no damage will occur, and if he slapps throttle to
it once or twice because he wants to hear the pipes rattle...and it goes
above redline with no load on it, not to be bothered too much. IT might not
be all the good for it...but I would bet a years salary that a 503 will run
at 8000 rpms with no load on it alot longer than it will at 6800 loaded to
the max.
Just so no one misunderstands what I am saying here. IF one attempts to do
this with a pitched prop on it, thereby increaseing BMEP to levels and
crankshaft torsion entirely above the design limits...he will likely need an
overhaul in short order.
David.Lehman
PostPosted: Tue Jan 10, 2006 10:35 am    Post subject: Re: 503 Questions... Reply with quote
Thanx for all the help...
New carb. bowl gasket should be here from Air Tech today so I can make airplane noise this weekend...
DVD
ô¿ô
"Both optimists and pessimists contribute to the society. The optimist invents the aeroplane, the pessimist the parachute."
--- George Bernard Shaw
