jpx(at)qenesis.com Guest
Posted: Mon Nov 12, 2007 11:04 am Post subject: Z-12 Questions |
I have now read my new Aero Electric Connection cover to cover. Even
for someone with a university education in electronics, it was still
fabulously enlightening. Thanks Bob !
One of the things I have already learned is that Bob has designed
everything as it is for a particular and often unapparent reason.
So I have questions before I change anything
I am building a night VFR aircraft which will have a Dynon as the main
instruments and engine monitoring. I will probably have a real ASI
and altimeter, since I find them much easier to read and I can happily
fly without the Dynon then. We take long distance trips, so I am more
concerned with failures that make it difficult to fly 10 hours home
than flight safety to get back on the ground, since I am usually
flying in nice weather.
In my 400 hours of flying, I have already had an alternator failure in
a rental aircraft. Although it was uneventful really, I would not
want to fly a long trip home without any electrics.
So Z-12 looks like a good fit for me, with an SD-8 as the backup
alternator (brilliant idea this product).
Figure 17-4 shows an SD-8 charging the battery directly, whereas Z-12
is like 17-8 with the two alternators are in parallel, and thus the
SD-8 cannot charge the battery with the contactor open. I don't think
the B&C SB1B-14 regulator is intended for the SD-8. So wire the SD-8
like figure 17-4 ?
It is easy to put a long list of items on the endurance bus. However,
maybe that doesn't matter. The likely failure modes need to be
analyzed. In the event of an alternator failure, switches can be used
to turn off unnecessary devices, so it doesn't matter which bus they
are really on (just contactor hold current). In the event of an
electrical fire, the battery contactor will be switched off, so only
the necessary items for an immediate emergency landing need to be on
the endurance bus.
Maybe an electrical fire is far less likely since I will be using
fuses almost entirely. Unlike a circuit breaker that cannot be
trusted to pop, the fuse will likely blow. No fire, smoke or smell,
so usually no need to turn off the battery contactor ??
The diode tying the main bus to the endurance bus seems unnecessary.
The main bus could easily be wired to pin 3 of the e-bus alternate
feed switch. This implies the diode is more reliable than the switch
(which is only switched once to test at each run-up). If it is a
reliability concern, why not wire the switch and keep the diode ? Or
is there another reason I haven't even guessed at ?
I will appreciate everyone's input.
Jeff Page
Dream Aircraft Tundra #10
nuckolls.bob(at)cox.net Guest
Posted: Tue Nov 13, 2007 6:53 am Post subject: Z-12 Questions |
At 02:00 PM 11/12/2007 -0500, you wrote:
Good thinking . . .
| Quote: | I am building a night VFR aircraft which will have a Dynon as the main
Why not 13/8? Z-12 is a standby alternator retrofit
philosophy for airplanes already flying. Not really
intended for new design.
| Quote: | Figure 17-4 shows an SD-8 charging the battery directly, whereas Z-12
like figure 17-4 ?
Let's not mix/match features across architectures.
Concentrate on lowest parts count (which translates
to minimized weight, $time$ to install and cost of
ownership) that meets mission goals.
| Quote: | It is easy to put a long list of items on the endurance bus. However,
the endurance bus.
It does matter . . . you need to set you own
design goals for performance in the endurance mode
of en route flight. With one alternator, battery
capacity is used to support en route loads so we
strive to keep them very low . . . say 2-3 amps
so that there are some reserves in the battery for
approach to landing.
As soon as you add the SD-8, NOW endurance loads
can be up to 8A and hold the battery completely
in reserve for approach to landing.
| Quote: | Maybe an electrical fire is far less likely since I will be using
I've never seen a breaker refuse to open on a
hard fault. But they DO allow more energy to be
driven into the fault condition than their faster
cousins. But yes, circuit protection of either
variety can be expected to avoid bad smells in the
cockpit.
| Quote: | The diode tying the main bus to the endurance bus seems unnecessary.
The diode IS more reliable than a switch. Further,
the modification you suggest runs BOTH power paths
for the e-bus through the single component . . . i.e.
single point of failure for power to the e-bus.
| Quote: | I will appreciate everyone's input.
If I were building an airplane today, Z-13/8 is my
architecture of choice for kind of aircraft I would be
building and the manner in which I plan to use it. I
suspect that Z-13/8 would be most adequate for 98%
of the OBAM aircraft being licensed every year.
Do your load analysis. Decide which devices will
reside on which busses. Then starting with Z-13/8,
deduce what failure mode or design goal is not
being accommodated.
