CZ
Posted: Mon Nov 12, 2007 10:17 am Post subject: fuse |
cJ6
I was having an electrical problem sunday, as in no power, and I found the 50 amp fuse blown in the box to the right of the pilot.
1) does anyone know where to buy the subject fuse or a replacement?
2) has anyone replaced these with circuit breakers?
3) Does anyone have a readable wire diagram?
Thank you
Posted: Mon Nov 12, 2007 10:38 am Post subject: fuse |
Answer:
For the fuse contact Doug Sapp. They work in the 50/52 also.
As for placing a circuit breaker... a 50 amp unit will work fine and solves
the problem of ever having to replace the fuse again.
No, I do not have a wiring diagram for the CJ. Do for a YAK 50 and 52
though.
Doc
rvfltd(at)televar.com Guest
Posted: Mon Nov 12, 2007 10:43 am Post subject: fuse |
CZ wrote:
| Quote: | | Quote: | --> Yak-List message posted by: "CZ" <chriszimmer2002(at)yahoo.com> (chriszimmer2002(at)yahoo.com)
cJ6
| | I have them in stock .
| Quote: | | Quote: | | 2) has anyone replaced these with circuit breakers? | | I have not, but it should be possible.
| Quote: | | Quote: |
| | There are very good fold outs ( first generation copies) of all the CJ6 elect diagrams in the back of the Tech. Spec. For Service and Maint. manual. I have them as well as the other 8 CJ manuals in stock, give me a call (at) 509-826-4610 or drop me a email.
Always Yakin,
Doug
[quote] [b]
Posted: Tue Nov 13, 2007 1:49 pm Post subject: fuse |
One comment. I want to replace that fuse with a circuit breaker myself,
but keep in mind that the "reaction time" of a fuse is faster than the
typical aircraft circuit breaker. Aircraft breakers can easily
withstand 150% of rated load for a few second before blowing. Fuses
react faster than that.
It's not usually anything to worry about... Just to note that there IS a
difference.
Mark Bitterlich
Posted: Tue Nov 13, 2007 1:53 pm Post subject: fuse |
You can unsolder the legs off the actual fuse itself, and go down to
Lowe's and search through their large bus bar type fuse collection and
find one that fits and then solder the legs back on to that, which is
what I did, and sorry, I did NOT write down the exact number off the
fuse. Sorry, my bad.
Better yet, go to Doug Sapp and buy one from him.
Best of all.. Replace it with a 50 amp breaker.
I am not sure how good Doug's bus bar fuses are, but the original
Russian ones are dog crap. They fail internally from vibration.
Mark Bitterlich
brian-1927(at)lloyd.com Guest
Posted: Tue Nov 13, 2007 3:54 pm Post subject: fuse |
On Nov 13, 2007, at 1:49 PM, Bitterlich, Mark G CIV Det Cherry Point,
MALS-14 64E wrote:
Point, MALS-14 64E" <mark.bitterlich(at)navy.mil>
myself,
And the issue is protecting the wiring. Go with a fusible link.
Brian Lloyd 3191 Western Drive
brian HYPHEN 1927 AT lloyd DOT com Cameron Park, CA 95682
— Antoine de Saint-Exupéry
PGP key ID: 12095C52A32A1B6C
PGP key fingerprint: 3B1D BA11 4913 3254 B6E0 CC09 1209 5C52 A32A 1B6C
wlannon(at)persona.ca Guest
Posted: Tue Nov 13, 2007 5:23 pm Post subject: fuse |
I have had to replace only one of these fuses and that was due to my own
#^&*^up. That was 13 years ago and I had a good stock of 12V T6/Harvard
spares which included the virtually identical fuse. It is still working
fine.
No question your best bet is a new one from Doug.
Walt
Posted: Tue Nov 13, 2007 9:07 pm Post subject: fuse |
Correction;
Should read 24V --Brain fart, should read before sending! Don't use 12V.
Walt
l39parts(at)hotmail.com Guest
Posted: Mon Nov 19, 2007 4:57 pm Post subject: fuse |
Fuses generally protect equipment. They come in fast-blow for electronics, slow blow for things with a powerup surge, and normal. Wires are very tolerant of short duration surges and are generally protected by circuit breakers
| Quote: | From: brian-1927(at)lloyd.com
Subject: Re: fuse
Date: Tue, 13 Nov 2007 15:53:21 -0800
To: yak-list(at)matronics.com
--> Yak-List message posted by: Brian Lloyd <brian-1927(at)lloyd.com>
MALS-14 64E wrote:
> --> Yak-List message posted by: "Bitterlich, Mark G CIV Det Cherry
> myself,
&g=======================
Connect and share in new ways with Windows Live. Connect now! [quote][b]
Posted: Mon Nov 19, 2007 6:11 pm Post subject: fuse |
On Nov 19, 2007, at 4:56 PM, Ron Davis wrote:
Well, actually no. Fuses and/or breakers are there to protect the
wiring. Some people want them to do double duty and protect the
equipment too but that is not their primary purpose. Devices are
supposed to have their own protection internally.
And just because that is what is *supposed* to happen doesn't mean
that is what really happens.
FWIW, when I wire up an aircraft, I normally install only one circuit
breaker -- the alternator field circuit. The OV circuit is a crowbar
across the field circuit thus forcibly shutting down the alternator
by shorting the field to ground and popping the breaker. This is
pretty hard to ignore. For everything else, there are fuses.
Far and away the most reliable devices are automotive fuses and fuse
blocks. These are much simpler and more reliable the circuit
breakers. In addition to using fuses I put the fuse block where the
pilot can't get to it. This removes the temptation to dick around
with things until you impact the ground. By placing the fuses out of
reach the pilot just has to accept the fact that this circuit is out-
of-service until (s)he lands.
BTW, if a circuit being OOS causes panic and chest constriction then
you need to rethink how that circuit works and perhaps install some
sort of backup.
Posted: Mon Nov 19, 2007 6:26 pm Post subject: fuse |
| Quote: | BTW, if a circuit being OOS causes panic and chest constriction
then you need to rethink how that circuit works and perhaps install
some sort of backup.
And before someone points out that resetting the circuit breaker may
restore service to the critical circuit I want to add that being able
to reset the circuit breaker is not likely to make the circuit work
again unless the reason was a nuisance trip due to an undersized
breaker. If a breaker trips off or a fuse blows it means something is
wrong and you shouldn't be fiddling with it in flight. If a circuit
is so critical that you can't do without it, having a circuit breaker
doesn't make it better. Rethink the circuit so that you can
comfortably complete a flight no matter which circuit fails.
Oh, and use fusible links for the bus feed from the battery and for
the alternator output. They are a LOT more reliable than either fuses
or breakers. That is why the automotive industry switched to them.
And for those of you wondering what a fusible link is, it is a piece
of ordinary wire two wire gauges smaller than the wire it is supposed
to protect. If something shorts your big circuit to ground the
fusible link will burn instead of the rest of the wiring. They are
easy to fabricate and dead-nuts reliable.
Posted: Tue Nov 20, 2007 12:51 pm Post subject: fuse |
And for some reason the Russians put big fuses in the main electrical panel, and then used switched circuit breakers to come off the main and feed the actual equipment. Go figure.
And for Brian.... Just sitting here wondering what the electrical difference was between a fusible link and an actual fuse. I guess the only real difference is one has a holder and thus is USUALLY easy to swap out while the fusible link requires a wire cutter and new crimps to repair?
Actually most fuse holders I have seen go bad before the actual fuse ever fails! Either corrosion attacks them, or the internal springs of some models causes the structure to fail. This is true except for the very best types of military models used in Govt. aircraft.
Some other things to ponder:
1. Some fuse holders are prohibited from being used in military aircraft since they are made from PVC. Something to consider.
2. When a fusible link lets go, it means that the wire inside has MELTED. An actual fuse has some kind of cover to protect that melting metal. A fusible link has just the standard insulation. When using a fusible link vice a fuse, placement of this link is critical as it is possible to achieve an open flame for a split second when it fails. What is your view on that aspect Brian?
Mark Bitterlich
Posted: Tue Nov 20, 2007 5:58 pm Post subject: fuse |
On Nov 20, 2007, at 12:49 PM, Bitterlich, Mark G CIV Det Cherry
Point, MALS-14 64E wrote:
It makes sense. Protect the main feed from a gross overload and then
protect the individual circuits (you have to do that anyway). I am
talking about doing exactly the same thing but cheaper and more
reliably. An automotive fuse block that is protected by a fusible
link with individual fuse-protected circuits that are switched by
ordinary switches is both cheaper (by a LONG shot) and more reliable.
| Quote: | And for Brian.... Just sitting here wondering what the electrical
Yes. Oh, and it won't fail in-flight for mechanical reasons. And how
often have you had to replace a fuse because it has blown to protect
the circuit and how often have you had to replace it because it has
failed, "I don't know why?"
| Quote: | Actually most fuse holders I have seen go bad before the actual
aircraft.
Precisely. That is the advantage of a fusible link and the automotive
type fuse. The old 3AG-type fuseholder has very low pressure contacts
and is prone to failure from corrosion. The automotive ATO/ATC-type
fuse uses a high-pressure gas-tight contact (referring to the metal-
to-metal contact) that is unlikely to fail during a normal lifetime.
(Meaning, it will last longer than the rest of the parts in your
airplane.)
Consider that this is a different environment. We aren't flying
military aircraft in combat so there is less chance of having to deal
with in-flight fire.
| Quote: | 2. When a fusible link lets go, it means that the wire inside has
MELTED.
Same with a fuse.
| Quote: | An actual fuse has some kind of cover to protect that melting metal.
And so does a fusible link.
| Quote: | A fusible link has just the standard insulation.
No. The fusible links we use/make for aviation use are covered with a
glass-fiber high-temp covering that prevents any flame from escaping
and provides thermal insulation to prevent igniting nearby
components. The fusible link burns through without damaging anything
around it.
Here are pictures of how to fabricate a high-rel, high-safety fusible
link:
http://www.aeroelectric.com/Pictures/Fuses/Fusible_Links/
| Quote: | When using a fusible link vice a fuse, placement of this link is
It doesn't happen for the reasons listed above. A fusible link is
just as safe in its failure mode as is a fuse, perhaps more safe.
Fusible links aren't damaged by impact and are completely insulated.
You can drop a wrench on it and not have someone give you the
callsign "sparky". Fusible links are impervious to vibration and
moisture. I could go on and on but the bottom line is that a fusible
link is better and cheaper than a fuse.
And consider one other thing -- most standard (3AG) fuses and
breakers don't end up failing by doing their job of protecting the
circuit to which they are attached. They usually fail for
environmental reasons. Corrosion causes a high-resistance contact
which causes the fuse to get hot and fail at a lower current.
Breakers get "weak" with time. Going to automotive fuses and fusible
links reduces this type of failure to a very low level, resulting in
a more reliable electrical system over time. Add to that lower cost,
better availability, and greater simplicity, it is difficult to see
why anyone would want to keep going with more expensive, less
reliable components.
OTOH, a side panel filled with $50 circuit breakers sure looks cool!
But I can think of better ways to spend $750 than to protect 15
circuits and look cool.
There is still one place to use a breaker: use it in a circuit where
you might need to disable that circuit such as the alternator field
or the power feed to your autopilot servo. Other than that ...
brianl AT lloyd DOT com Cameron Park, CA 95682
aircraft.
airplane.)
MELTED.
Same with a fuse.
around it.
link:
Posted: Wed Nov 21, 2007 1:33 pm Post subject: fuse |
Good info as usual Brian.
Mark
