brad(at)rv7factory.com Guest
Posted: Thu Jan 05, 2006 2:50 pm Post subject: Ideal Crimpmaster Dies??? |
While I am not yet at the wiring stage of my project, I am starting to
accumulate the needed tools. I have an Ideal Crimpmaster from a prior
project, but I need new dies for it and I am confused by which to buy.
I am hoping one of you can set me straight.
Ideal lists two dies which look from the diagram and specs to be
identical, but which is the right one for my needs?
30-579 Die Set, Insulated Terminals
http://www.idealindustries.com/IDEAL-EZ/products.nsf/ItemMasterLookup/p30-579?OpenDocument
or
30-594 Die Set, Insulated Slide-On Connectors
http://www.idealindustries.com/IDEAL-EZ/products.nsf/ItemMasterLookup/p30-594?OpenDocument
On the coax side, I found this die for the Crimpmaster, but I am not
sure if it is the one I need... comments?
30-587 Die Set, RG-58, RG-174, RG-8218
http://www.idealindustries.com/IDEAL-EZ/products.nsf/ItemMasterLookup/p30-587?OpenDocument
Thanks in advance for your assistance!
Cheers,
Brad Oliver
RV-7
Livermore, CA
www.RV7Factory.com
nuckollsr(at)cox.net Guest
Posted: Thu Jan 05, 2006 6:46 pm Post subject: Ideal Crimpmaster Dies??? |
or
This may very well be suited to installation of PIDG terminals
but wouldn't know without trying it. Odds are favorable but as
we've discovered with several tools in the past here on the
list, not all tools are made the same.
Don't know what this is: If you're installing PIDG terminals, then
the crimp tool to apply them is the same as for the ring terminals.
I'm unable to deduce from the description as to the applicability
of this die set mostly because it doesn't define the matching terminals.
If you buy your connectors from B&C, then the .213 and .068
inch pockets will install their connectors . . . along with
many others which you'll have to try. It would be nice if the
connector manufacturers would put the die sizes for installation
on their connectors. But .213 and .068 are very popular sizes
and the odds are in your favor.
