mogas vs 100LL
vectorwarbirds(at)aol.com
PostPosted: Mon Nov 12, 2007 8:13 pm    Post subject: mogas vs 100LL Reply with quote
According to Aeroshell:
72 octane is the highest grade of gasoline that can be manufactured without [additives].
80/87 has 0.50 ml TEL [tetra-ethyl lead] per gallon and is dyed RED
91/96 2.00 ml TEL per gallon BLUE
100LL 2.00 ml TEL per gallon BLUE
100/130 3.00 ml TEL per gallon GREEN
115/145 4.60 ml TEL per gallon PURPLE
That makes the lead content of 100LL only 4 times higher than 80/87 octane not 8.
As for the idea that all gasoline is gasoline that it not true.
What is true that 80/87 produces more power than 100LL given the engine does not require a higher octane for anti knock reasons. The reason for this is that 80/87 has a higher volitility rating than 100LL, so in simple terms it burns faster. In engines made to burn lower octane fuel the timing and other engine parameters were set for this factor. It might seem odd that fuels with higher octane ratings burn less easily, yet are popularly thought of as more powerful. This misunderstanding is caused by confusing the ability of the fuel to resist compression detonation as opposed to the ability of the fuel to burn (combustion). A simple explanation is that carbon-carbon bonds contain more energy than carbon-hydrogen bonds. Hence a fuel with a greater number of carbon bonds will carry more energy regardless of the octane rating and 80/87 carries a greater number than 100LL.
[b]If you take that same fuel that worked well in a high compression engine and use it in a low compression engine with it's lower cranking compression and lower combustion chamber temps, it will, without a doubt, burn much too slowly at those lower temps and pressures and reach maximum cylinder pressure too far after TDC for best power.[/b]
[b]Things generally burn slower when they are cooler and vice versa. Peak cylinder pressure will occur much past TDC - decreasing the power produced if you keep the same ignition timing.[/b]
[b] You can advance ignition timing to try to recover power, but that will cause the air/fuel mixture to burn earlier in the crank stroke and spend, percentage wise, more of the energy produced by the expanding, burning mixture, pushing back down, trying to prevent the piston from rising up to the power stroke - robbing power.[/b]
[b]If you MUST use a slow burning fuel, which USUALLY has a high octane rating, advancing the ignition timing will lessen the power loss, but the best results are usually obtained with the quickest burning fuel obtainable, that, of course, doesn't "knock".
All other factors being the same, except for burn rate - use the quickest burning fuel that doesn't "knock", light the spark in the middle of the combustion chamber, adjust ignition timing to reach peak cylinder pressure ~TDC and keep your mixture correct. When the ignition timing is correct, the engine will make best power for that fuel.
[/b]
[/b]
[b]Also according to the EAA Peterson STC you can put mo-gas in the tank 75% (TEL 0.002 ml) and 25% av-gas (100LL at 2.00 ml TEL) and you have the same 0.50 ml TEL that 80/87 had. Another way is to run about three tanks of mo-gas and the fourth is a tank of av-gas (100LL)[/b]
So I think the bottom line it this, our engines were designed and built to burn 70 octane Chinese or Russian fuel not 100LL Avgas. And until someone can show me the stats on the lead content in Chinese 70 oct I will continue to use mogas and avgas at the shows in mine.
One thing I do know, its cheaper!!
Thanks for your thoughts.
GBunn
Vector Aviation USA
Email and AIM finally together. You've gotta check out free AOL Mail!
brian-1927(at)lloyd.com
PostPosted: Mon Nov 12, 2007 9:12 pm    Post subject: mogas vs 100LL Reply with quote
octane not 8.
Well, I said, "about six times". I didn't look it up before
commenting. Shame on me.
Hmm, my understanding is different. I was under the impression that
octane rating does not affect the speed of combustion, only the
resistance to detonation.
Reference: http://en.wikipedia.org/wiki/Octane_rating
To quote:
"Octane rating has no direct impact on the deflagration (burn) of the
air/fuel mixture in the combustion chamber. Other properties of
gasoline and engine design account for the manner at which
deflagration takes place. In other words, the flame speed of a
normally ignited mixture is not directly connected to octane rating.
Deflagration is the type of combustion that constitutes the normal
burn. Detonation is a different type of combustion and this is to be
avoided in spark ignited gasoline engines. Octane rating is a measure
of detonation resistance, not deflagration characteristics."
Hmm, most gasoline comes from the same base stock at the refineries.
Again, I was under the impression that the differences mostly stem
from the additive packages that go into the base gasoline after
refining.
As for carbon-carbon bonds vs. carbon-hydrogen bonds: it seems to me
that we would have a different reaction requiring a different amount
of O2 to ensure complete combustion. Since all these fuels operate at
the same mixtures by mass, it seems to me that the gasoline is
therefore inherently the same.
best power.
This also seems odd. If so, we would notice a difference in
performance between mogas and avgas with performance suffering from
the use of avgas. I am not aware of anyone noticing this. I am also
not aware of any warnings that an engine designed for 72 or 80 octane
fuel will produce less power when operated on 100LL. I suspect that,
were this so, the EAA and the FAA would let us know.
Hmm, another interesting point would be EGT. If what you are saying
is true, there would be a general increase in EGT with 100LL as the
combustion endpoint would be later leading to less heat transfer to
the cylinder and resulting in higher absolute exhaust gas
temperatures. I certainly have never noticed a difference in absolute
EGTs when operating on mogas vs. 100LL.
Hmm, the airframe and engine manufacturers do not specify different
ignition timings for different fuels. If what you say is true, I
would expect them to require a change in spark timing if different
fuels are being used.
Wouldn't two points of ignition result in two flame fronts and more
complete combustion? Isn't that why we get more power and lower EGTs
with both mags on?
I could be wrong but I was under the impression that you want peak
cylinder pressure to occur substantially after TDC where the crank
position provides more favorable mechanical advantage.
I agree with that.
(100LL)
Yes.
Also, a tiny amount of 100LL added to mogas results in a substantial
increase in octane/AKI (anti-knock index), more than one would expect
by the amount of TEL introduced.
in mine.
Yup, I agree with that.
GBunn
Vector Aviation USA
www.matronics.com/Navigator?Yak-List _-
Brian Lloyd 3191 Western Drive
brian HYPHEN 1927 AT lloyd DOT com Cameron Park, CA 95682
� Antoine de Saint-Exup�ry
PGP key ID: 12095C52A32A1B6C
PGP key fingerprint: 3B1D BA11 4913 3254 B6E0 CC09 1209 5C52 A32A 1B6C
