schaefer(at)rts-services. Guest
Posted: Wed Nov 14, 2007 9:55 am Post subject: Thermo-Couples through pressure bulkhead |
Folks,
What is the effect of running EGT, and CHT thermocouples through a bulkhead connector?
I believe these are all “K” type thermo couples and I believe that if they are extended need to be done
with thermo couple wire. But can I have a connector with gold contacts joining two pieces of thermo couple wire?
r.t.s.
Richard T. Schaefer E-mail: schaefer(at)RTS-Services.com (schaefer(at)RTS-Services.com)
RTS Services Inc Web: http://www.RTS-Services.com
7330 Cave Hollow ___ Voice: (512) 923-2755
Austin, TX 78750 | Fax: (830) 798-9644
ainut(at)hiwaay.net Guest
Posted: Wed Nov 14, 2007 12:33 pm Post subject: Thermo-Couples through pressure bulkhead |
Not if you can help it. Try your best to use the TC wire and ground in one solid strand from the sensor to the instrument, if at all possible. You'll vastly improve your error rate that way.
David M.
nuckolls.bob(at)cox.net Guest
Posted: Wed Nov 14, 2007 12:47 pm Post subject: Thermo-Couples through pressure bulkhead |
I've run stranded and solid thermocouples through
ordinary machined pins in connectors with insignificant
effects on accuracy. While connector pins of material
"foreign" to the thermocouple wire alloy is inserted
into the Seebeck signal path and while each new joint
introduces error, the joints are paired in opposite
polarities and over the small space of a connector
mass, are very close in temperature to each other.
I'd recommend using a connector that puts a 4-quadrant
crimp on machined metal pins
http://www.aeroelectric.com/Pictures/Connectors/D-Subminature/D-Sub_Machined_Pins.jpg
http://www.aeroelectric.com/Pictures/Connectors/D-Subminature/D-Sub_4-quad-crimp.jpg
as opposed to soldering or using sheet metal, b-crimp pins.
( -Thomas Paine 1776- )
