jrccea(at)bellsouth.net Guest
Posted: Fri Nov 09, 2007 6:39 pm Post subject: Lycoming EGT, IO 540 |
Have you moved the thermocouples around too, to assure that your 100 degree difference isn't due to a thermocouple difference?
JimC
| - The Matronics Engines-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Engines-List |
mlas(at)cox.net Guest
Posted: Sat Nov 10, 2007 10:04 pm Post subject: Lycoming EGT, IO 540 |
100 deg? EGT or CHT? What you are trying to do is to get each cylinder to peak at the same time. What you�re looking for is the delta between when each cylinder peaks. In a perfect world all the cylinders should peak at the same time at the same temperature. That never happens because of many factors; cooling effect, induction difference, valve opening, ect. It is very common to see on a well setup engine peak deltas around 30~60 deg. between each other. The CHT by itself is for limit purposes and the EGT is to help find when each cylinder peaks. I hope this helps.
Mike Larkin
glcasey
Posted: Sat Nov 10, 2007 10:07 pm Post subject: Lycoming EGT, IO 540 |
First, it would be good to know which version of the IO-540 you have
since the angle-valve and parallel-valve engines have quite different
intake systems. The angle-valve engines have an intake system that
is quite good in that the tubes are well matched, have a reasonable
tuning benefit and don't absorb too much heat from the oil. The
parallel-valve engine, on the other hand, were designed for
carburetion and have much of the intake system buried in the oil
sump, transferring more heat and limiting the freedom of design.
Generally, though, the air distribution of these engines is pretty
good. The first thing to do when sorting out air/fuel distribution
questions is to measure it using the "lean sweep" method. Starting
well rich, record all exhaust temperatures and fuel flow (it's handy
to record CHT's and flight data as well, but it is not necessary for
good results). Lean the engine a step at a time - the finer the
steps the better, although it will start to take too long if done to
the extreme. After all cylinders have peaked continue to go lean
until you get at least 2 or 3 data points on the lean side of the
leanest cylinder. The biggest problem I've had is not waiting long
enough for all the variables to stabilize before recording the data.
It is good to do the exercise a few times to make detection of bogus
data points easier. Plot the temperature of each cylinder against
fuel flow all on the same chart. Pick what appears to be the "best
fit" straight line on the rich side and another on the lean side,
extending them until they cross. That is the fuel flow at which that
cylinder peaks. Do not just pick the highest temperature and call
that the peak as the temperatures have a tendency to round off near
the peak, making the true peak hard to find. Do that for all
cylinders and measure the spread of fuel flow between the leanest and
richest cylinders. Ideally, it should be less than 2%, but 3 or 4%
is probably okay. If the spread is more you should do something
about it. An easier way is to ship all the data off to GAMI and they
will give you an expert opinion.
Back to your questions:
1 - 100 degrees is significant, but there may not be much you can do
about it. The thermocouple readings can be affected by cooling air
flow on the outside of the pipe as well as orientation of the probe
itself. Exhaust flow inside the tube is not uniform around the
diameter - all probes should be the same distance down from the
cylinder and inserted from the same angle. The temperature of the
cylinder itself will affect the measurement. My hottest cylinder
also has the highest EGT reading - does one cause the other, or is it
coincidence? Hard to say. Why, then would one be different that the
other? There are three fundamental factors on EGT - mixture (you're
going to take that out of the equation), Compression ratio (all
cylinders are the same, right?), and spark timing (hard to imagine
the timing for one cylinder being different than the others). That
pretty much brings it back to measurement errors unless the exhaust
valve is leaking a lot.
2 - The temperature of the inlet air won't have much effect on air/
fuel distribution. It's possible that ram air will have a
deleterious effect on smoothness, however. If the manifold pressure
at the intake port becomes higher than the upper plenum pressure it's
possible that some fuel could come out the air bleed vents, although
this usually leaves a tell-tale stain around the injector. I could
also make the atomization of the injector suffer and that in turn
could create a cycle-to-cycle variation in fuel flow, making the
engine feel rough. A good injected engine should be able to be
leaned so much that the power is way down and still be running
smoothly. Not all are that way.
3. - Intake turbulence itself is probably beneficial to mixing the
air and fuel unless one intake runner is different than another.
Lycoming engines are typically pretty good in this regard, but again,
I have no idea which type you have.
Just as an aside, I've messed around trying to figure out the best
air/fuel ratio to run. It all depends on the ratio of your desire
for speed to the size of your wallet. Speed is good, but fuel flow
is bad. As a first shot I used the same equation some people (CAFE,
I think) use - multiply mph by mpg. The peak is the optimum place to
run if speed is just as important as fuel economy (how do you
decide? It's your own choice). This turns out to be TAS^2/GPH. I
found the optimum was just lean of peak. Going as far lean as
possible didn't help, although usually it didn't make it much worse
either. Going rich was like falling off a cliff. Fuel flow goes way
up, but air speed doesn't. What you really want to put into the
equation is ground speed, so that will change the shape of the curve
for every flight. The optimum with a headwind is on the rich side
and with a tailwind it is more on the lean side.
FWIW,
Gary Casey
Quote: |
Time: 03:20:57 PM PST US
From: "Bob & Toodie Marshall" <rtmarshall(at)osbtown.com>
Subject: Lycoming EGT, IO 540
Hi all, At overhaul I had the cylinders flow balanced, the engine runs
very well, very smooth. Considering the rising fuel costs, I have been
considering attempting to run the engine LOP, I have been unsuccessful
as the richest cylinder peaks last and by then the other cylinders are
running rough. I use the AFP fuel injection system which performs
flawlessly and have moved nozzles around to effect egt changes which
have been effective to a point, where cyl #6 runs 100 degrees cooler
than the others. My question? Is 100 degrees a significant number when
compared to the other five cylinders?The engine builders out there who
are making real HP see the different relationships on cooling effects
and cylinder balancing and the induction system. Question #2 does
cold
air induction help to make the lycoming run more evenly balanced in
respect to temps. #3 Is it possible that the stock lycoming intake
system generates to much internal turbulence which effects the
individual cylinder performance? Thanks for any info and taking the
time
to answer. Bob
_________________ Gary Casey |
Bob Buckthal
Posted: Sat Nov 10, 2007 10:47 pm Post subject: Lycoming EGT, IO 540 |
First read John Deakins series of articles on engine operation on the Avweb.com site. Differences in EGT are likely more to do with temp probe instalation. Your goal is to get all the EGT's to peak(regardless of the temp) at the same throttle position. It one cyl has not peaked and the others are in lean missfire, Your FI may not be flawless. The induction system is well designed. Unless your engine builder left a tool or a rag in there, that is not your problem. Go back and redo the nozzles. DO NOT try to achieve an even temp. Once they all achieve their peak temp at the same throttle position you should be able to get as much as 150 degrees lean of peak before missfire.
w_sweet(at)comcast.net Guest
Posted: Sun Nov 11, 2007 5:59 am Post subject: Lycoming EGT, IO 540 |
glcasey
Posted: Sun Nov 11, 2007 6:03 am Post subject: Lycoming EGT, IO 540 |
Bob's comment brings up a question I have. I've got a parallel-valve
IO-540 with 10:1 compression and electronic ignition on the top
plugs, mag on the bottom, timing set at 22. The cylinders are very
closely matched for air/fuel, within about 1.5%. When I lean the
engine LOP the temperatures drop just a little before it goes rough
and sometimes go flat or back up, so I typically operate just barely
LOP. I don't have a good explanation for this behavior unless my
ram air induction is working so well that the injectors have no air
flow in them to atomize the fuel. However, I don't see any fuel
stains around the injectors, so there apparently isn't any fuel
coming out the vents. There is no way the engine would run 150 LOP
as Bob suggests below. Any ideas on why this engine seems to operate
different than the norm?
Gary Casey
get
apilot2(at)gmail.com Guest
Posted: Sun Nov 11, 2007 6:44 am Post subject: Lycoming EGT, IO 540 |
I run an IO-360 angle valve engine. It will run nicely lean of peak to about 60-70 lean of peak. At that point EGT can start back up or the engine start to quit. You are right...you only need 10-20 LOP if you are running 70% or less power. As your power goes up, you need to be leaner, maybe 30-40 LOP at 75% or higher. Unless you have a turbo, you are unlikely to run much over 85% LOP, so forget about much leaner. The turbo guys will cruise up to 90 LOP on a big Continental. The Lyc turbo 540, at least as used in the Mooney TLS Bravo generally won't run LOP without turbine inlet temps going above redline. It is one of the few engines that simply doesn't like LOP.
On Nov 11, 2007 7:02 AM, Gary Casey <glcasey(at)adelphia.net (glcasey(at)adelphia.net)> wrote:
[quote] --> Engines-List message posted by: Gary Casey <glcasey(at)adelphia.net (glcasey(at)adelphia.net)>
Gary Casey
get
Posted: Sun Nov 11, 2007 8:41 am Post subject: Lycoming EGT, IO 540 |
Gary,
One problem I see with your setup is the electronic ignition with a
fixed timing mag. I see why you went this way but you should be aware
that when both systems fire, the first one is more or less the only one
that counts. So in order to get optimum performance you must know
exactly when you electronic ignition fires and it must be the same as
the mag at cruse and higher power or your working against yourself. In
other words for performance a single ignition system.
Just a thought,
Mike Larkin
s_korney(at)hotmail.com Guest
Posted: Sun Nov 11, 2007 3:49 pm Post subject: Lycoming EGT, IO 540 |
Gary...
What brand of electronic ignition do you have....? I would think the EI would have a lot more advance then the mag at almost any manifold pressure other then maybe sea level...
Best... Steve
Quote: | From: glcasey(at)adelphia.net
Subject: Re: Lycoming EGT, IO 540
Date: Sun, 11 Nov 2007 06:02:45 -0800
To: engines-list(at)matronics.com
--> Engines-List message posted by: Gary Casey <glcasey(at)adelphia.net>
Gary Casey
> get
&========================Climb to the top of the charts!� Play Star Shuffle:� the word scramble challenge with star power. Play Now! |
frank.hinde(at)hp.com Guest
Posted: Mon Nov 12, 2007 7:44 am Post subject: Lycoming EGT, IO 540 |
Not at all, The EI's will have both less and more advance depending on manifold pressure. Mags are set at 25deg which is a compromise between poor starting, high power operation and economy cruise.
Pretty much all EI's run at about 25 DEG at full power but can advance to 40deg plus at low manifold pressure.
I wonder if this engine is truly running balanced...what does "withing 1.5%" mean?....If it means the cylinders flow the same amount of air on the bench then this is meaningless as far as blancing the injectors.
Each cylinder needs to get to peak EGT at the same fuel flow (mine is about 0.5GPH between richest and leanest)....Nothing else matters...If the cylinder don't all peak at the same fuel flow (or close to it) the engine will not run LOP very well.
I think what we have here is some cylinders running ROP while the others are runnin so LOP that the flame is going out...I.e well LOP.
Frank RV7a IO360
From: owner-engines-list-server(at)matronics.com [mailto:owner-engines-list-server(at)matronics.com] On Behalf Of steve korney
Sent: Sunday, November 11, 2007 3:49 PM
Subject: RE: Re: Lycoming EGT, IO 540
Gary...
Best... Steve
Gary Casey
> get
Climb to the top of the charts! Play Star Shuffle: the word scramble challenge with star power. Play Now! [quote]
href="http://www.matronics.com/contribution">http://www.matronics.com/chref="http://www.matronics.com/Navigator?Engines-List">http://www.matronics.com/Navigator?Engines-List
glcasey
Posted: Tue Nov 13, 2007 6:42 am Post subject: Lycoming EGT, IO 540 |
Thanks for the replies. The ignition is the Lightspeed Plasma III,
which I'm sure you all know is a capacitive discharge wasted-spark
system. The "III" as far as I know is sort of a double polarity
system that presumably strikes the arc twice, once in each
direction. I'm not a fan of CD systems, but I think they work ok -
they're just much more electrically complex than an inductive
system. I haven't had any luck extracting the advance curve from
Claus and I'm not sure why it seems to be a secret. He sells a
monitor system that provides a panel readout of advance, but I don't
have that.
My timing settings were static. I set the mag (no impulse coupling)
at 22 degrees and attempted to set the Lightspeed at about the same
value. During runup the rpm drops are about equal, confirming that
the Lightspeed timing is about the same as the mag. I had no luck
trying to rig a timing light to check the advance. I understand that
at rpms below something like 2000 there is no "vacuum" advance in the
Lightspeed, so it should be producing a spark at the base timing. I
should have done mag checks at altitude, but I haven't. My
assumption is that at higher rpm and the low manifold pressures at
altitude the Lightspeed provides a more advanced timing. Does anyone
have information about the advance characteristics of the Lightspeed
unit?
The "1.5%" I was talking about is the difference in fuel flow between
when the leanest and richest cylinders peak. Frank says that his is
within 0.5GPH - assuming the fuel flow of the IO360 is about 10GPH
that works out to 5% difference, significantly worse that what my
engine data indicates. The 1.5% number I stated actually ranged from
0.8% to 3% depending on which of the 10 or so tests I look at. The
standard deviation hangs around 0.7% indicating the data is
reasonably well behaved. And, while the cylinders were presumably
"ported and flow balanced" I have no idea as to whether the air
distribution is precise. However, it is unlikely that the air
distribution would be poor AND the injectors mismatched to exactly
compensate. Therefore, I am reasonably confident that both air and
fuel distribution are very close.
My next test will be one to determine if the injector atomization
plays a part. I plan to do a lean sweep at full throttle followed by
another with the throttle closed enough to reduce the manifold
pressure by 1 inch. That should be enough to induce at least some
air flow through the injectors.
Gary
On Nov 12, 2007, at 11:56 PM, Engines-List Digest Server wrote:
Quote: |
Time: 07:44:22 AM PST US
From: "Hinde, Frank George (Corvallis)" <frank.hinde(at)hp.com>
air on
others
Frank RV7a IO360
