nuckolls.bob(at)cox.net Guest
DaveG601XL
Joined: 27 Oct 2006 Posts: 351 Location: Cincinnati, Oh
Posted: Wed Nov 14, 2007 10:42 am Post subject: Re: Fuses and fusible links |
Bob,
The initial electrical schematic for my 20 amp Jabiru alternator main bus and e-bus's included fuse links as their means of protection based on your writings. This post tells me I could go either way with a fuse link or an in-line fuse in my application. Your comments in the lead-in material for your Z-diagrams say that in-line fuse-holders for the 20 amp SD-20 alternator level of loads are "marginal at best." I am a bit confused with this contradiction so if you could please clarify your position, I would appreciate it. I am more familiar with in-line fuse-holders and would like to use them, but not if their reliability in this application is in question.
If I were to use an in-line fuse for the 20 amp alternator output, would I use a minimum 25 amp fuse to ward off nuisance trips?
_________________ David Gallagher
Cincinnati, OH area |
Posted: Wed Nov 14, 2007 12:04 pm Post subject: Fuses and fusible links |
At 10:42 AM 11/14/2007 -0800, you wrote:
<david.m.gallagher(at)ge.com>
Bob,
is in question.
The fuseholders and fuses I cited were the MAXI series
devices that fill applications from 20 to 80 amps
as described in:
http://www.aeroelectric.com/Mfgr_Data/Fuses_and_Current_Limiters/Bussman/MAXI_Specs.pdf
. . . as opposed to the smaller ATC series which I
recommend up to and including 15A circuits. The data
sheet is here:
http://www.aeroelectric.com/Mfgr_Data/Fuses_and_Current_Limiters/Bussman/ATC_Specs.pdf
The full range of in-line fuse holders citing
the fuses they fit is illustrated here:
http://www.aeroelectric.com/Mfgr_Data/Fuses_and_Current_Limiters/Bussman/Bussmann_in_line_Holders.pdf
( -Thomas Paine 1776- )
DaveG601XL
Posted: Wed Nov 14, 2007 12:26 pm Post subject: Re: Fuses and fusible links |
OK, that really helps clear it up for me. I did not initially understand that the Maxi fuses and holders are on a whole different playing field the plain-Jane automotive blade fuses and holders. I see that the maxi specs show fuses starting off at 20 amps and going up in 10 amp intervals to 80 amps. For my 20 amp application, is the 30 amp maxi fuse the appropriate size?
Thank again!
Posted: Wed Nov 14, 2007 1:23 pm Post subject: Fuses and fusible links |
At 12:26 PM 11/14/2007 -0800, you wrote:
Yes. You can get holders and fuses at
most auto parts stores.
