avidfox
Posted: Fri Nov 16, 2007 10:47 pm Post subject: transponder kt76 tso |
On Nov 16, 2007 11:26 PM, jerry evans <kitfox555(at)sbcglobal.net> wrote:
| Quote: | Has anyone have experience in hooking up the wires from this transponder I
have a black ground and a red power and a yellow ? when it goes I don't
know I put continuity tester on it, it is grounded but it is in dimmer pin
on the plug in the diagram the red is on pin 5 black is in pin 12
yellow in pin 11 anyone know thanks Jerry
http://www.aeroelectric.com/Installation_Data/KT76-78.pdf
Float Flyr
Posted: Sat Nov 17, 2007 12:12 pm Post subject: transponder kt76 tso |
Red. B+ Pin 5
Black Ground Pin 12
Dimmer ( pin 11) is powered from the instrument lights (14V system) The
dimmer is what it connects to. No instrument lights?... one less connection.
Noel
[quote] --
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
