dogsbark(at)comcast.net Guest
Posted: Tue Nov 20, 2007 6:41 am Post subject: nose wheel |
Does anyone have the torque settings for the replacement Matco nose wheel, for the the three bolts that hold the wheel halves together? My mains have it printed on the sticker, but not on the nose wheel. Looks like most of their wheels are 50 in/lbs.
Sean
#40225
Tim Olson
Posted: Tue Nov 20, 2007 6:59 am Post subject: nose wheel |
I don't have a conclusive number on the front wheel, but the mains
I believe are not 50, but are 150 in/lbs DRY. You may want to
call Matco on the nose wheel. I think I used 150 like the mains,
but it's been too long to remember if I had a sticker on them or
not. Give Matco a call though and I'm sure they'll tell you.
Then you can report here and we'll all know.
dogsbark(at)comcast.net wrote:
Sean #40225
Posted: Tue Nov 20, 2007 7:48 am Post subject: nose wheel |
I called Matco and got the following:
Torque for the replacement nose wheel (3 assembly bolts) is 98 in/lbs dry.
Tim, I believe you are correct about the torque settings on the mains at 150 in/lbs dry. I will double check what I did there, and it is printed on the label of the wheel.
Since I'm learning and don't know otherwise, I asked about the tube installation. Hand tight the nut and washer next to the tube/valve stem and discard the nut at the end of the valve stem. Follow Van's directions otherwise.
It does not matter which orientation the nuts/bolts are installed (keep them symmetrical of course) to connect the wheel halves in the nose wheel, but they recommended installing the nuts opposite the calipers on the mains for visibility on inspection. The mains are not Matco, but this idea still applies.
I am using Aeroshell 22 (Matco liked this) for the nose wheel bearing. This is a different seal than the mains and is not to be removed (more new guy stuff) like the seals in the mains. Just work the grease into the bearings as it is constructed. A thin film of grease is helpful on the seal to assist in seating.
Hope this helps.
Everyone have a Great Thanksgiving. We are blessed!
Sean Blair
#40225
-------------- Original message ----------------------
> Thanks,
> Sean #40225
Tim Olson
Posted: Tue Nov 20, 2007 8:47 am Post subject: nose wheel |
Now that is good service Sean!
Now you've got me wondering if I over-torqued those nosewheel
nuts, or if there was a sticker when I did it and I caught
it. Hmmm. Well, it's time for a tire balance so I'll just
have to check it.
dry.
Hope this helps.
Sean Blair #40225
-------------- Original message ---------------------- From: Tim
Olson <Tim(at)MyRV10.com>
> not. Give Matco a call though and I'm sure they'll tell you. Then
> Tim Olson - RV-10 N104CD - Flying do not archive
>> Thanks,
>> Sean #40225
