Terry Phillips
Joined: 11 Jan 2006 Posts: 346 Location: Corvallis, MT
Posted: Wed Nov 21, 2007 6:55 am Post subject: Tefzel cables and d-sub connectors |
I am have reached the point in my building where I have to address some electrical design issues. I need to install the servo for the R.A. Allen electric elevator trim tab. The servo has 5 leads, and is supplied with a length of 5-conductor Belden 8445 cable to connect to the controls in the cockpit. A check on the Internet shows that this cable is PVC insulated with 5 22AWG wires. I have a several questions.
1. I was planning to use Tefzel insulated cable as much as possible. Is it worthwhile to replace R.A. Allen's PVC insulated cable with Tefzel insulated cable?
2. For this application cable would be better than 5 individual wires, because the wires must pass outside the skin from the elevator to the fuselage. After looking around on the Internet, I was unable to find a 5-conductor cable with Tefzel wire insulation and a Tefzel jacket. I did find a company, TPC Wire,
http://www.tpcwire.com/tpc/pdf/03_TrOxCable_6.pdf,
that sells 100 ft lengths of shielded cable with Tefzel wire insulation and a polyurethane exterior cover that should work (part no. 61506). They don't have 5 conductor cable, but the 6 conductor cable would not be much heavier. Does such a cable look like a reasonable substitute? Are there other sources for Tefzel insulated cable that I should consider?
3. The servo instructions suggest soldering the cable conductors to the servo leads and wrapping the joints with electrical tape. I was originally planning to use butt splice crimp connectors instead of soldering. I'm now considering using a 9 conductor d-sub plug. Are the d-sub plugs a good choice for a remote location, like the elevator?
4. If one uses a d-sub, should the plug itself be secured to the elevator (how?) or would cable ties or an adel clamps on the cable provide adequate support.
5. Also, since TPC Wire has a $100 minumum order, it behooves me to buy cable for other uses in the airplane in this one order. E.g., power for the nav lights, headlights, etc. One use that I'm considering is to buy some 24 conductor cable to pass through the firewall to carry engine instrument signals. Which brings me back to the d-sub connectors. Would d-subs be reasonable replacement for the terminal strips that I have seen used to connect engine instruments to wires passing through the firewall? Can d-subs handle engine compartment temperatures? Will thermocouple leads crimped into d-sub pins work OK? Are d-subs robust enough to endure the correction of wiring goofs?
_________________ Terry Phillips
Corvallis, MT
ttp44<at>rkymtn.net
Zenith 601XL/Jab 3300 slow build kit - Tail feathers done; working on the wings. |
rv10(at)sinkrate.com Guest
kuffel(at)cyberport.net Guest
Posted: Wed Nov 21, 2007 4:46 pm Post subject: Tefzel cables and d-sub connectors |
Terry,
I have a small amount of Belden 89503 plenum cable. 3-pair
twisted with overall foil shield & drain wire, 24 AWG and Teflon
FEP insulation. Flame and smoke resistant, good to 200 degrees C.
If this is acceptable for your use let me know the length from
your trim motor to your trim switch. I'll add 5 feet, cut off a
hunk and drop it off in Corvallis. I am driving through Hamilton
Wed Dec 5 and coming back the next day.
Tom Kuffel
Whitefish, MT
nuckolls.bob(at)cox.net Guest
Posted: Wed Nov 21, 2007 7:44 pm Post subject: Tefzel cables and d-sub connectors |
insulated cable?
See:
http://aeroelectric.com/articles/macservo/macservo.html
Quote: | 2. For this application cable would be better than 5 individual wires,
Run individual 22AWG wires from the connector forward.
The connector as described is light enough to simply
be covered with heat shrink and supported by the cable
assembly, no need to mount it separately. There's no
good reason to treat your trim actuator wires any
differently than a bundle of wires that carry nav,
strobe and antenna wires to the back of the airplane.
Quote: | 3. The servo instructions suggest soldering the cable conductors to the
It was my first view of a behind the panel rat's nest
of odd pieces of wire and way too much electrical tape
that prompted me to write the first edition of the
'Connection 21 years ago.
Quote: | I was originally planning to use butt splice crimp connectors instead of
Yup, that works. There are some smaller, classier
connectors you could consider too . . . but they're
more expensive, take special tools and don't do
any better job than a d-sub.
Quote: | 4. If one uses a d-sub, should the plug itself be secured to the elevator
support.
Float it on the cable.
Quote: | 5. Also, since TPC Wire has a $100 minumum order, it behooves me to buy
instrument signals.
Please don't do this. In over 30 years of
systems design and integration I've never seen
a practical need for multi-conductor bundles
other than those called out as shielded
for the purpose of protecting a signal path.
Build your bundles one wire at a time.
Quote: | Which brings me back to the d-sub connectors. Would d-subs be reasonable
Sure.
Quote: | Can d-subs handle engine compartment temperatures?
Yes.
Quote: | Will thermocouple leads crimped into d-sub pins work OK?
Yes. Been doing it for years.
Quote: | Are d-subs robust enough to endure the correction of wiring goofs?
Depends on how clumsy you are. I've got connectors
in my data acquisition systems where some pins have
been removed/replaced over a dozen times. Be nice to
them and they'll do well for you for a long time.
Terminal strips are labor intensive, drive up
parts count, use threaded (ugh) fasteners. Crimped
joints into machined pins/terminals are far less
troublesome for maintenance and cost of ownership.
Terry Phillips
Posted: Sun Nov 25, 2007 4:39 pm Post subject: Re: Tefzel cables and d-sub connectors |
Thanks to all who responded both on and off line. I have a much more clear picture of what to do now. I will definitely be using d-subs extensively. I think they can really save some precious space in the engine compartment, while providing a reliable connection.
I do have 2 questions about using the DB-9 in the elevator.
It seems to me that it would be easier to fab a nice little mount for the DB-9 inside the elevator than it would be to modify the DB-9 to Bob's ultralight configuration (that could be more easily supported by the wiring.) Would a std DB-9 with a shrink cover provide adequate protection from moisture?
Bob's write up uses soldered pins. I have ordered a crimp tool and a supply of crimp pins from SteinAir. Would crimp pins be adequate in the elevator?
Thank you again for the help.
Terry
Corvallis, MT
ttp44<at>rkymtn.net
Posted: Sun Nov 25, 2007 5:56 pm Post subject: Tefzel cables and d-sub connectors |
from moisture?
elevator?
Two things. It depends on what size holes that
the terminated cable needs to pass, the "minaturized"
d-sub is optimized to go through the smallest possible
hole. Obviously, you can forego trimming if you'd
rather mount the connector on some form of bracket.
The solder cup connector is recommended for the actuator
side . . . Ray-Allen (and MAC before them) is/was
really pedantic about their tefzel covered cat hair
wires.
I hit them up in the booth at OSH several years running
to suggest that the motor wires should be different
colors so that I could publish drawings that would
let a builder wire it up right the first time by
knowing in advance which wire was (+)extend and
(+)retract. Finally, the stuff was too small
for the neophyte and really too small as an "airframe"
wire. Even if you choose to use crimped pins, double
the strip length to increase amount of wire inside the
pin -AND- support at the back with E6000 to give these
small wires extra support.
I've put several Ray-Allen actuators into test
fixtures and the first thing I do is install
a "soldered and glued" connector as shown to
give me a robust interface to 'real' wires
on the other side of the mated connectors.
