Fuel sender gasket
lwinger
PostPosted: Fri Nov 23, 2007 6:10 pm    Post subject: Fuel sender gasket Reply with quote
My VDO fuel sender from ZAC came with a sealed bag of parts, which included the mounting ring, paper washers, screws and a rubber gasket. An extra gasket, identical to the one in the bag, was also included in the box. Is that just a replacement? The photo guide and plans only show one rubber gasket, and that is how I installed it.
I'm installing the fuel sender on the end of the tanks, per the plans. No mention was made of any kind of sealant.
Any of you guys who are already flying with a similar configuration (end mount, no sealant) could really help me out by sharing your experiences re: leaks or no leaks.
Thanks.
Larry Winger
Tustin, CA
Plans building 601XL/650 with Corvair
Installing fuel system
www.mykitlog.com/lwinger
dgardea(at)gmail.com
PostPosted: Fri Nov 23, 2007 6:39 pm    Post subject: Re: Fuel sender gasket Reply with quote
Larry,
Upon reading some advice posted by others on the list, I used only one of the rubber gaskets on the external surface of the fuel tank. When mounting the sender to the tank, I liberally applied fuel lube to the outside of the perimeter of the hole, to the both sides of the rubber gasket, and to each of the screws. The excess is mostly easy to wipe off after you compress the gasket with the screws (don't overtighten) but you may want to wear some latex gloves when applying the fuel lube. The fuel lube is available from Aircraft Spruce under the name EZ Turn, but a search there for fuel lube works.
Dave Gardea
601XL - finishing wings
 Filesize:  60.06 KB
 Viewed:  473 Time(s)
Dave Gardea
CH650 - Corvair - flying!
http://n631dg.t15.org/home.html
Ron Lendon
PostPosted: Fri Nov 23, 2007 8:14 pm    Post subject: Re: Fuel sender gasket Reply with quote
Larry,
I bought some of the Flame Master (3oz) (Proseal) from Vans Aircraft. Gasket on the outside of the tank. 1/8" bead of proseal on the tank around the hole and also around the sending unit flange. Made sure to seal around the bolt holes on the flange.
http://mykitlog.com/users/display_log.php?user=rlendon&project=113&category=1683&log=42660&row=15
Ron Lendon
CH 601 XLB
N601LT - Flying
Corvair Engine Prints:
cgbrt(at)mondenet.com
PostPosted: Tue Nov 27, 2007 6:12 am    Post subject: Fuel sender gasket Reply with quote
You need to seal the screws but be careful. Too much on the treads and the
screws will form little balls of sealant on the end when you drive them and
those little critters end up in your tank. The only thing that saved me from
embarrassment was the fingerscreens.
Carl
701/912/amphibs/480hrs
