		| Author | Message |
		| Fergus Kyle
				|  Posted: Sat Dec 01, 2007 7:47 am    Post subject: Dynon EMS-D10/Rotax914 |   |
				| Cheers,
This is directed to those having the above combination installed:
 I am wondering how you attached the MAP sensor to the engine
 successfully. I particular, if the sensor is on the source of remote and if
 the latter, what material you used to connect the two. I am fussing over
 inherent heat and vibration problems.
 Much obliged in expectation,
 Ferg
		| Back to top |  |
		| Ivor Phillips
				|  Posted: Sat Dec 01, 2007 8:42 am    Post subject: Dynon EMS-D10/Rotax914 |   |
				| Hi Ferg
I fitted the MAP sensor to the interior Firewall, Then used a bulkhead
 pipe fitting to carry the vacuum through the firewall using Silicone
 Vacuum pipe to the cross balance pipe between carburetors, Can send you
 a picture if needed,
 Ivor
		| Back to top |  |
		| davidjoyce(at)doctors.org Guest
				|  Posted: Sat Dec 01, 2007 9:35 am    Post subject: Dynon EMS-D10/Rotax914 |   |
				| Ferg, I have a slightly different combination (914 &Mark's controller) but
the same problem. I have done the same as Ivor and brought the tubing
 through the firewall to mount the sensor within the cabin. One piece of
 advice I would offer is to put a small inline plastic fuel filter in to
 catch the gunge. Until my current panel upgrade I had the same line running
 from the cross balance pipe to a standard manifold pressure gauge on the
 panel. After 5 yrs the pipe had become heavily stained with what looked like
 condensed nicotine and the gauge had suffered heart failure! Regards, David
 Joyce, G-XSDJ
		| Back to top |  |
