Re-GPS Antenna Coax Length
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Avionics-List
w_sweet(at)comcast.net
PostPosted: Tue Nov 27, 2007 3:14 pm    Post subject: Re-GPS Antenna Coax Length Reply with quote
When in doubt, go to the front end of the horse.
Straight from the "horse's mouth" (Garmin installation tech rep 913-397-8200); there is no requirement for either the GNS430 or GNS530W minimum or maximum coax cable length.
Wayne
- The Matronics Avionics-List Email Forum -
http://www.matronics.com/Navigator?Avionics-List
schaefer(at)rts-services.
PostPosted: Tue Nov 27, 2007 4:15 pm    Post subject: Re-GPS Antenna Coax Length Reply with quote
There is a required DB loss between the WAAS receiver and the antennae, with good connectors and good coax that works out to a nominal coax length.
I am sure you might be able to meet it with a short cable and poor workmanship … But how long will it stay in specs.
From: owner-avionics-list-server(at)matronics.com [mailto:owner-avionics-list-server(at)matronics.com] On Behalf Of Wayne Sweet
Sent: Tuesday, November 27, 2007 5:13 PM
To: avionics-list(at)matronics.com
Subject: Re-GPS Antenna Coax Length
Wayne
mike(at)ferrer-aviation.c
PostPosted: Wed Nov 28, 2007 4:50 pm    Post subject: Re-GPS Antenna Coax Length Reply with quote
So, I guess we can all agree, there IS a requirement for coax loss (i.e., coax length) although it sounds like they reduced the minimum from 13' to 6.5'.
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Avionics-List All times are GMT - 8 Hours
