		pbuttles(at)charter.net Guest
				 Posted: Fri Nov 30, 2007 8:13 am    Post subject: 701 ,801 struts |
				What if anything has anyone done about corrosion protection on701 and 801 stuts?
 they are open on top and bottom ,that can easilly lead to rusting on the inside on the tubing ,not easilly seen or inspected !
  |  | - The Matronics Zenith-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		billmileski
				 Posted: Fri Nov 30, 2007 8:51 am    Post subject: Re: 701 ,801 struts |
				After installation (a bad time to do this) I plugged the bottom of the struts with sticky electrical putty sealer and filled the struts with warmed linseed oil, then drained it out at the bottom.  Made a terrible mess. To do over, I'd probably (before installation), liberally pour a good metal primer inside, turn them to ensure coverage, let it drip out and dry.  Seems like a more permanent solution. This is one of the reasons I'm not a fan of outside storage for these light aircraft.
 Bill Mileski
 701 912S 114hrs
				 Posted: Fri Nov 30, 2007 10:45 am    Post subject: 701 ,801 struts |
				Bill,
 The warm linseed oil solution is excellent and a reason many Stinson
 aircraft are still flying.  Common primers, other than fish-oil-base or
 epoxy primers, are not water-proof, but will hold water and wick to the
 metal. Go with the linseed oil.
 billmileski wrote:
  Bill Mileski
  701 912S 114hrs
  http://forums.matronics.com/viewtopic.php?p=149652#149652
		ifly4fun2(at)sbcglobal.ne Guest
				 Posted: Fri Nov 30, 2007 1:50 pm    Post subject: 701 ,801 struts |
				Plug the lower end with duct tape, fill it with warm linseed oil, let it set for a couple hours
 repeat every annual or sooner depending on geographical location.
 Art
 --- Tracy <pbuttles(at)charter.net> wrote:
		zodierocket(at)hsfx.ca Guest
				 Posted: Fri Nov 30, 2007 1:55 pm    Post subject: 701 ,801 struts |
				I also use the warmed Linseed oil, it is a worthy practice.
 Mark Townsend  Alma, Ontario
 Zodiac 601XL C-GOXL, CH701 just started
 www.ch601.org / www.ch701.com / www.Osprey2.com
