N7092A(at)aol.com Guest
Posted: Mon Feb 20, 2006 7:38 pm Post subject: Starting the -52 in cold weather |
Ok this may have been a topic earlier but I am new to the list and a fairly new Yak owner.
Here is the deal,
When the weather dips below 45 degrees it seems it take several times to start the Yak.
I am priming 7 times and pulling it through and another 3 just before start.
it Kicks over, sputters and then dies, I then have to prime again (not pulling through) about 5 times and then it finally catches and goes after the second to nth time. Then it will cycle about 5 - 10% for the first minute or two after starting.
In hot weather it usually kicks over in the first rotation and runs fine.
Anybody seen this?
Mark Merrill
N7092A YAK-52
KPAO
PHCarter(at)aol.com Guest
Posted: Mon Feb 20, 2006 8:11 pm Post subject: Starting the -52 in cold weather |
Mark
You appear to be priming and such correctly. May I suggest that you make sure you push, AND HOLD, the starter button. In this way, the shower of sparks will continue to help the ignition of the mixture. You should also be prepared to prime quickly as the engine starts to take hold. Also make sure you are pumping up the fuel pressure just before attempting a start.
The real suggestion here is holding the starter button for a while until the engine has really taken hold. You are probably priming as the engine stuggles initially, but it not try it.
I have had my Yak for about a year and a half and initially experienced similar problems with cold weather. More experienced folks explained and demonstrated the starter holding technique. Rarely have problems now. Good luck.
Preston
N6209F
brian
Joined: 02 Jan 2006 Posts: 643 Location: Sacramento, California, USA
Posted: Mon Feb 20, 2006 8:26 pm Post subject: Starting the -52 in cold weather |
N7092A(at)aol.com wrote:
| Quote: | When the weather dips below 45 degrees it seems it take several times to
start the Yak.
This is not unusual for any aircraft engine. Vapor pressure of gasoline
decreases with temperature. That means there are fewer gasoline fumes to
burn (liquid gasoline will not burn).
The solution is to increase the amount of prime. There will be more
liquid fuel in the induction system so even if less of it vaporizes,
there is still enough to make the engine start. I use 50% to 100% more
primer when the temp is down near the temp where you might want to preheat.
But be careful. You have more of a chance for a backfire and possible
induction fire when it is cold.
Brian Lloyd 361 Catterline Way
brian-yak at lloyd dot com Folsom, CA 95630
- Antoine de Saint-Exupery
_________________ Brian Lloyd
- Antoine de Saint-Exupery |
Posted: Mon Feb 20, 2006 10:58 pm Post subject: Starting the -52 in cold weather |
Thanks Brian,
I had a 182 that acted like this and adding more prime was the answer, I just
wasn't sure with the M14.
I also have been holding the starter down for a few turns but it doesn't seem
to help other than drain the air.
I will try it and report back to you guys.
Mark Merrill
N7092A Yak 52
PAO
n a message dated 2/20/06 8:27:33 PM, brian-yak(at)lloyd.com writes:
> start the Yak.
shinden33(at)earthlink.ne Guest
Posted: Mon Feb 20, 2006 11:39 pm Post subject: Starting the -52 in cold weather |
Mark,
I just got my Yak a month ago and have had a similar problem. The trick for
me seems to be to prime it 8 times and, as the other folks have mentioned,
HOLD THE STARTER. I also healthily pump the throttle with my right hand
while holding the start button. Of course being careful to not let it start
with too much RPM.
Scott
N8252
dsavarese(at)elmore.rr.co Guest
Posted: Tue Feb 21, 2006 5:14 am Post subject: Starting the -52 in cold weather |
A couple of things you might want to try Mark.
1- After you pull the prime though and you have reseated yourself in the cockpit and after you pump the second 3 shots of prime, stroke the throttle (MP) twice from full back to full forward to full back. Then move the throttle to approximately 1/4 to 1/3 open.
2- Now pull the primer out and turn to the right.
3- Press and hold the start button until the engine fires and then rotate the mag switch to the 1+2 position
4- DO NOT STROKE THE THROTTLE. Leave it alone.
5- If the engine seems like it is going to die, stroke the primer pump while it is turned to the right.
6- Keep the cooling louvers closed of course to expedite engine warm up.
Dennis
Posted: Tue Feb 21, 2006 5:17 am Post subject: Starting the -52 in cold weather |
Scott,
With all due respect, pumping the throttle is not the proper technique to
solve the lack of fuel problem. Open the throttle to about 1/4 to 1/3 and
leave it alone. Pull the primer out and turn it to the right. Press and
hold the Start button. After it fires, turn the mag switch to 1+2. If the
engine starts to die, do not stroke the throttle. Push the primer pump in
for the additional fuel.
This is the starting technique that I teach all new Yak owners and it really
works.
Dennis
jsfox(at)adelphia.net Guest
Posted: Tue Feb 21, 2006 6:14 am Post subject: Starting the -52 in cold weather |
Mark- Since I live in New Hampshire where at this time of year 45 degrees is a beach day I can sympathize, all most, with your problem. When I first got my YAK last year, I got it in the dead of the worst winter we had had in quite awhile, below 20 seemed to be the norm. The 7-8 primes are critical when it gets cold
and waiting three to four minutes so the fuel can vaporize. Also make sure you pull the prop through after you prime. I usually pull through one prop for each prime. Finally be ready to prime as the engine fires.
However, I will tell you the fastest way to solve the problem. A heater on your oil tank. At 45 degrees you won't need to plug it in long to get the oil up to a good temp and if you put a blanket over your cowling it will warm the entire engine compartment slightly. I guess the question you have to answer is: are there enough cold mornings/days to make this investment worth while?
I will also say changing over to Dennis Savarese's auto plugs and wires has made a huge difference on how my plane starts in the cold. Much easier and much faster.
Steve Fox
Yak 52
N3043R
http://homepage.mac.com/steve.fox/PhotoAlbum5.html
On Feb 20, 2006, at 10:37 PM, N7092A(at)aol.com (N7092A(at)aol.com) wrote:
| Quote: | Ok this may have been a topic earlier but I am new to the list and a fairly new Yak owner.
Here is the deal,
Anybody seen this?
Mark Merrill
N7092A YAK-52
KPAO
HawkerPilot2015
Posted: Tue Feb 21, 2006 6:19 am Post subject: Re: Starting the -52 in cold weather |
Now this is what this list is for! I have had similar issues and will try the method Dennis mentioned today! Yesterday, I preheated the oil and the engine and gave it some good squitrs...BANG....started right up. OAT 32*
bwalker11(at)charter.net Guest
Posted: Tue Feb 21, 2006 6:26 am Post subject: Starting the -52 in cold weather |
Very correct Dennis,
I would add that the accelerator pump in the carborator will put excess fuel
in the carborator inlet if you over work the throttle which, if a
successful start is not accomplished will result in fuel dripping out of the
carborator throat. Add a little fire from the stacks and you have yourself
a little situation. Someone off to the side yells fire and you hit the
starter button again only to discover that with that cold engine you have
depleted your air supply to the point that the engine won't turn over and
suck or blow the fire out, now you have a bigger problem. Ask Elizabeth
about it at Waycross the year before last, she bailed out of the back seat
of the same plane twice in a row - the second time with amazing speed.
BW
dabear(at)damned.org Guest
Posted: Tue Feb 21, 2006 6:37 am Post subject: Starting the -52 in cold weather |
1) First rule I've found for starting both the M14P and the Housai is
the prime 1 pump for every 10 deg C below 100.
2) I usually pull the prop through, then prime, then start. Except
when cold. Where I'll pull the prop through, Prime/pull blade for 4
blades (2 blade prop) 6 blades (3 blade prop). By the time I'm done
prime/prop, back in the airplane and strapped in, I'm ready to
continue....BTW, any more priming then that and you are venting fuel to
the exhaust since you have completed a full rotation of the engine.
3) I DON"T recommend moving the throttle, but will prime with the rest
of the prime shots required for #1 above.
4) Hit start, as engine fires move mag to 1+2 (M14P), hold only another
revolution or two of the prop after starting...
5) Prime as required to keep it started.
It usually only takes 1-2 attempts to get the engine started. I'm more
worried about over priming and starting an intake fire then having to
start the engine again so I'm conservative on priming.
DaBear
Stephen Fox wrote:
| Quote: | Mark-
Steve Fox
Yak 52
N3043R
On Feb 20, 2006, at 10:37 PM, N7092A(at)aol.com <mailto:N7092A(at)aol.com>
> Here is the deal,
> to start the Yak.
> start.
> Anybody seen this?
> Mark Merrill
> N7092A YAK-52
> KPAO
brian
Posted: Tue Feb 21, 2006 6:56 am Post subject: Starting the -52 in cold weather |
| Quote: | Thanks Brian,
just wasn't sure with the M14.
seem to help other than drain the air.
Nope, it won't. If the engine doesn't fire in three blades, you are just
wasting your air.
If you prime the engine properly it will fire right up. If it is cold
you may need to keep pumping primer in to keep it running. As the engine
warms a little the fuel will vaporize more readily and will keep running
without the additional fuel.
The only time extra cranking will help is if you have flooded the engine
and you are trying to get more air through there in order to get the
over-rich mixture in the cylinders lean enough to burn.
flyncatfish(at)yahoo.com Guest
Posted: Tue Feb 21, 2006 8:01 am Post subject: Starting the -52 in cold weather |
Mark:
You might also want to read Lt. Phil Webb's cold
weather Yak starting story as well. After reading
this story I always check and make sure I have a fire
extinquisher nearby at startup - especially on cold
days.
http://www.safetycenter.navy.mil/media/approach/issues/jun03/Tales.htm
Greg Arnold
Yak 52 N624PT
Do You Yahoo!?
Tired of spam? Yahoo! Mail has the best spam protection around
http://mail.yahoo.com
rvfltd(at)televar.com Guest
Posted: Tue Feb 21, 2006 8:05 am Post subject: Starting the -52 in cold weather |
Steve Fox is correct about the benefits of a insulating cover for the cowl and a small heat source, even something as small as a "Easy Heat" pad. I recently purchased several of the stock Chinese insulated cowl blankets which are sewn to form fit over the cowl, blocking off the entire gill area and covering all the cowls. The temp gains inside with just the small heat pad on the oil tank were remarkable. The only down side is that if your aircraft is a greasy mess the fabric will soon soak up the oil.
Always Yakin,
Doug Sapp [quote] --
Posted: Tue Feb 21, 2006 9:20 am Post subject: Starting the -52 in cold weather |
WRT adding prime during start - I have tried this method and it just does
not work. Maybe my airplane's just cranky but it has zero effect mainly
because there is not enough time for the primer to fill before the start
attempt is over. The only option would be to fill the primer prior to
start. I don't think that's the best plan. As far a as putting excess full
into the carb, I would not recommend flailing on the throttle. I
essentially use it as a the primer.
S
Posted: Tue Feb 21, 2006 10:18 am Post subject: Starting the -52 in cold weather |
On Feb 21, 2006, at 11:04 AM, doug sapp wrote:
| Quote: | | The only down side is that if your aircraft is a greasy mess the fabric will soon soak up the oil. |
This is not a problem for the Fox boys. Our mother taught us - never put it away dirty!
Posted: Tue Feb 21, 2006 10:42 am Post subject: Starting the -52 in cold weather |
Possibly another reason for having a fire guard as you did (at) Waycross after
the first time. Or atleast have an extinguisher avialable nearby.
Doc
| Quote: | [Original Message]
To: <yak-list(at)matronics.com>
Date: 2/21/2006 8:35:43 AM
Subject: Re: Starting the -52 in cold weather
fuel
| Quote: | in the carborator inlet if you over work the throttle which, if a
the
| Quote: | carborator throat. Add a little fire from the stacks and you have
yourself
| Quote: | a little situation. Someone off to the side yells fire and you hit the
seat
[quote] of the same plane twice in a row - the second time with amazing speed.
BW
Posted: Tue Feb 21, 2006 11:03 am Post subject: Starting the -52 in cold weather |
| Quote: | stock Chinese insulated cowl blankets which are sewn to form fit over the cowl, blocking off the entire gill area and covering all the cowls. The temp gains inside with just the small heat pad on the oil tank were remarkable. The only down side is that if your aircraft is a greasy mess the fabric will soon soak up the oil.
Always Yakin,
Doug Sapp | Quote: | Another thing that can aid in warming the engine is a $25 hair dryer hung inbetween the gills infront of the oil sump for 20-30 min.
Doc
Posted: Tue Feb 21, 2006 11:57 am Post subject: Starting the -52 in cold weather |
After being in the aircraft salvage business for over 20 years and personally recovering hundreds of aircraft from just every conceivable position and environment, some of the ones that stick in my mind the most were the fires caused by a el cheapo heat sources. It seems wondrous to me that anyone would heat a 100K aircraft with a questionable heat source unless they were standing by with an extinguisher close at hand (as I as sure you were). I once salvaged what was left of a brand new Cessna 185 on floats which burnt to the floor pan because of a hair dryer left in the engine compartment while the owner went for coffee while it warmed the engine. It turns out that a hair dryer is designed to live in free air, the air around it cools the plastic housing. Left in a enclosed space the plastic soon melts and the whole thing ignites. I'm not saying don't do it, I am say that if you do use household heating units of any kind they need to be watched VERY carefully. Heck in -50 F, up in northern Saskatchewan we put diesel (gelled because of the temps) and avgas in a 5 gallon can with sawdust. This whole thing was placed under the canvas draped cowl of the Norseman on skis. The oil was drained after each flight and kept in the heated line shack, when added to the pre heated engine, she fired up every time. By the way, this same aircraft, CF-SAM now hangs in the museum in Moose Jaw Saskatchewan, on her original skis, complete with artic cabin heater and cold weather gear. A true icon of the early days of bush flying in Northern Canada.
Always Yakin,
Posted: Tue Feb 21, 2006 12:42 pm Post subject: Starting the -52 in cold weather |
Doug,
I stand corrected to a degree.
I personally place the unit not all the way into the front cowling, but where the warm air can blow thru the louvers into the arear around the oil sump. It only gets cold enough down here in lower Alabama a few days out of the year to really need to warm the engine. I do not wonder to far off will it is running. Generally all it takes is running it while I'm adding oil, MMO, ect.
I would never walk off an leave a device like that unattended.
Thanks for the concern,
Doc
