Posted: Thu Feb 23, 2006 1:01 pm Post subject: Bings and EGTs |
Hi guys,
I went flying yesterday and noticed something that was interesting for
those of us
with Bing carbs. The EGTs climbed to their normal 1420 at high climb
4800 rpm
and the higher I got (4500 ft), the more the EGTs drifted lower. It
eventually permitted
a high rpm without going above the 1400 deg f. Nice for a good
cross-country
cruise, but as I descended to land, EGTs climbed back up to set limits
on my EIS and the
rpms had to be reduced to keep the EGTs at or below limits. Not something
I'm worried about, but it seemed strange to see EGTs behind the curve
while descending.
On final everything was well below limits, but I was wondering about the
altitude compensating
carbs and if they ever get out of whack or is this normal. Does this
square with anyone else's
experience?
Larry McFarland - 601HDS at 85 hours and still testing.
| | - The Matronics Stratus-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Stratus-List |
frank.hinde(at)hp.com Guest
Posted: Thu Feb 23, 2006 3:01 pm Post subject: Bings and EGTs |
Frank,
The cylinder head temps never get above 195, so I doubt the EGTs are a
problem at 1450 (my set limit).
The aluminum heads at the exhaust are what I'd be worried about, but
those temps have been o.k. I can fly
wide open at 4500 feet or so and hold 130 mph, but it seems weird to
watch the EGTs climb from below
1400 as I was letting off and descending. I can't figure out why.
Ambient temps were in the high 30s,
really cool clear air. It would seem the carbs are still richer at
altitude and become lean during descent.
This would seem to be a reverse of what I'd expect.
Larry
Hinde, Frank George (Corvallis) wrote:
Hmm, Can't say I have noticed this Larry, probably because I have never
looked at the EGT guage except to wonder how a valve could stand all
that heat...
Frank
Subject: Bings and EGTs
--> <larry(at)macsmachine.com>
EGTs climbed back up to set limits on my EIS and the
something I'm worried about, but it seemed strange to see EGTs behind
the curve while descending.
altitude compensating carbs and if they ever get out of whack or is this
normal. Does this square with anyone else's experience?
d3dw(at)msn.com Guest
Posted: Thu Feb 23, 2006 5:26 pm Post subject: Bings and EGTs |
Larry,
It seems that if you put your nose down to descend from an established cruise without pulling back, then your rpm has to increase...more heat? don
Posted: Thu Feb 23, 2006 6:15 pm Post subject: Bings and EGTs |
Don Walker wrote:
I reduce throttle to lose altitude, do tip the nose down a bit, but
found the reduction a little short of what was needed
to keep EGTs from climbing. Coming off 4800 to about 4300 rpm and
descending out of 4500 feet found EGTs
rising to the set limit until 4000 rpm and then backed down well after
cutting rpms to 3000 entering final approach.
Never noticed this from a high of only 3500 feet, but from 4500 ft, it's
curious why EGTs would rise on descent.
Maybe the difference of a 50 degree rise is just delayed cooling or heat
not flowing as fast out the pipes at a slight
reduction of rpm on a descent approach.
Larry
| Quote: | Larry,
Hi guys,
those of us with Bing carbs. The EGTs climbed to their normal 1420 at
high climb 4800 rpm and the higher I got (4500 ft), the more the EGTs
drifted lower. It eventually permitted a high rpm without going above
the 1400 deg f. Nice for a good cross-country cruise, but as I
descended to land, EGTs climbed back up to set limits on my EIS and the
Posted: Thu Feb 23, 2006 6:57 pm Post subject: Bings and EGTs |
In that case your apparent wind may have something to do with it, which affects cowl pressure and air flow. do you suppose you are maintaining a constant cowl pressure though the descent?
Posted: Fri Feb 24, 2006 7:07 am Post subject: Bings and EGTs |
Don,
I guess the cowl air flow would be reduced on descent and that might
allow more heat to accrue at the sensor. I was
thinking the altitude compensation built into the carbs was getting
behind on enrichment. It could be either for the sake
of only 50-60 degrees.
Larry
Don Walker wrote:
Don Walker wrote:
No Don,
Larry
>Larry,
Posted: Fri Feb 24, 2006 8:36 am Post subject: Bings and EGTs |
I dunno, just brainstorming with you. Looks like increased speed would increase cowl pressure to affect the mixture...and vice versa. Rate of descent may have something to do with it, too. I assume you are letting down at three to five hundred fpm?
I am glad you are noting these things, Larry, Helps us all. don
garyk2(at)cox.net Guest
Posted: Fri Feb 24, 2006 9:35 am Post subject: Bings and EGTs |
| Quote: | really cool clear air. It would seem the carbs are still richer at
I agree Larry - they should get richer with descent, and maybe they are. I
just read something that mentioned higher EGT with richer mixture because it
is still burning when it's coming out of the exhaust (just found the
article - Sport Aviation feb 06 p101).
Sorry I can't help - no EGT's yet. I'm still trying to get my homemade
engine monitor working. Right now I'm flying dumb and happy with just the
basic temps and pressure. I'm sure I'll have lot's of questions when I'm
monitoring and recording everything.
gary
Posted: Fri Feb 24, 2006 9:42 am Post subject: Bings and EGTs |
Don,
I spoke with technical support person at Bing and he said that on
descent, sometimes cowl pressure under lowering throttle settings
are still enough to lean out the mixture a bit and temps will go up.
You were right. He also said that the enrichment (choke)
cable could be pulled during the descent while rpms are reduced from
4500 rpm to 3500 rpm and the EGTs should return to normal.
I'll have to try that on the next trip out.
Don Walker wrote:
Don,
Larry
