		| Author | Message |
		| fklein(at)orcasonline.com Guest
				|  Posted: Sat Nov 24, 2007 9:08 am    Post subject: LG mounting frame |   |
				| Gentle Monowheelies,
In the midst of Chapter 21 M, last evening I got myself in a bit of a
 jamb by the ever so slightest deviation from the build manual w/ regard
 to the mounting of the LG01A bushes in the large diameter tube of the
 LG mounting frame. Having become accustomed to press fitting and
 loctiting the smaller bushes, I didn't hesitate to loctite the first of
 the two LG01A bushes by gently tapping it in place with a rubber mallet
 after a minimal scouring of the tube and the requisite cleaning and
 degreasing...but lo and behold, I was surprised to find that the shaft
 LG09 no longer rotates freely within the bushing; rather, the shaft has
 but a very tight interference fit within the bushing.
 So.....what to do?
 I see my options to be (1) to hone the bushing carefully til the shaft
 freely rotates, or (2) heat up the frame and bush to break the loctite
 bond, remove the bush, and scour/sand the inner circumference of the
 tube until the bush slides in neatly and then re-loctite.
 Have any of you had to deal with this problem?... if so, how did you
 solve it?
 Any comments would be much appreciated.
 Fred
 A194
 believed to be clean.
		| Back to top |  |
		| rlborger(at)mac.com Guest
				|  Posted: Sat Nov 24, 2007 10:10 am    Post subject: LG mounting frame |   |
				| Fred,
Went back to read Chapter 21M to refresh myself on the operation.  From my understanding of your installation, you tapped the LG01A bushings into place without the LG09 to maintain alignment.  It's a tough call, but I'd guess you'd be best to remove the two LG01A bushings, clean it all up and re-bond as per instructions with the LG09 in place.  That best ensures that the bushings are aligned properly with the shaft.
 Just my 2¢ and probably not worth all that.
 Good building and great flying,
 Bob Borger
 Europa Kit #A221 N914XL, XS Mono, Intercooled 914, Airmaster C/S
 http://www.europaowners.org/N914XL
 (90%) tail kit done, wings closed, cockpit module installed, pitch system in, landing gear frame in, rudder system in, outrigger mod in, Fuselage Top on, lift/drag/flap pins in, wing incidence set, tie bar in, flap drive in, Mod 70 done.  Baggage bay in.  Flaps & Main Gear complete.  Mod 72 complete.  Instrument panel complete, except for testing.  Rotax 914 installed (for the 3rd time).  Airmaster Prop installed.  Electrical complete, except for testing.  Fuel system complete except for testing.  Working in - 32 Tail, 34 Door Latches & 35 Doors, 37 Interior & Finishing.  Airmaster arrived 29 Sep 05.  Seat arrived from Oregon Aero.  E04 interior kit has arrived and is being installed.
 3705 Lynchburg Dr.
 Corinth, TX  76208
 Home:  940-497-2123
 Cel:  817-992-1117
 On Nov 24, 2007, at 11:06 AM, Fred Klein wrote:
  	  | Quote: |  	  | --> Europa-List message posted by: Fred Klein <fklein(at)orcasonline.com (fklein(at)orcasonline.com)> Gentle Monowheelies,
 In the midst of Chapter 21 M, last evening I got myself in a bit of a jamb by the ever so slightest deviation from the build manual w/ regard to the mounting of the LG01A bushes in the large diameter tube of the LG mounting frame. Having become accustomed to press fitting and loctiting the smaller bushes, I didn't hesitate to loctite the first of the two LG01A bushes by gently tapping it in place with a rubber mallet after a minimal scouring of the tube and the requisite cleaning and degreasing...but lo and behold, I was surprised to find that the shaft LG09 no longer rotates freely within the bushing; rather, the shaft has but a very tight interference fit within the bushing.
 So.....what to do?
 I see my options to be (1) to hone the bushing carefully til the shaft freely rotates, or (2) heat up the frame and bush to break the loctite bond, remove the bush, and scour/sand the inner circumference of the tube until the bush slides in neatly and then re-loctite.
 Have any of you had to deal with this problem?... if so, how did you solve it?
 Fred
 A194
		| Back to top |  |
				|  Posted: Sat Nov 24, 2007 11:15 am    Post subject: LG mounting frame |   |
				| On Saturday, Nov 24, 2007, at 10:08 US/Pacific, rlborger wrote:
  	  | Quote: |  	  | From my understanding of your installation, you tapped the LG01A bushings into place without the LG09 to maintain alignment.  It's a
 Bob,
 Thanks for your comment and for taking the time to go back thru the
 manual. Your understanding is correct except that I have only loctited
 one of the LG01A bushes.  I don't believe I have an alignment
 problem...I think my problem results from the bush being compressed
 just enough to make for an interference fit between bushing and shaft
 rather than for the shaft to freely rotate.
 Looking at the Loctite specs, I find that the bond dissolves at 250
 degrees C (wow...that's 482 degrees F.!). I guess I can put a propane
 torch into the LG mounting frame and heat the puppy up to free the
 bushing...but am wondering what that will do to the powder
 coat...(?)...and I don't want to exacerbate the situation.
 While still pondering what to do, I'm certainly open to additional
 counsel from any source!
 Fred
 A194
		| Back to top |  |
				|  Posted: Sat Nov 24, 2007 1:02 pm    Post subject: LG mounting frame |   |
				| Fred,
OK, I understand the issue.  I really don't have a good recommendation.  Only can say that you need the LG09 to fit snugly in the LG01A bushing with no slop allowed.  The over-center is tenuous enough as it is.  Any slop at all certainly would aggravate any problems there.
 Perhaps someone out there with more machine shop experience can come up with a better solution or a means to lap the bushing to size while maintaining proper alignment.
 Good luck,
 Bob
  	  | Quote: |  	  | From my understanding of your installation, you tapped the LG01A bushings into place without the LG09 to maintain alignment.  It's a tough call, but I'd guess you'd be best to remove the two LG01A bushings, clean it all up and re-bond as per instructions with the LG09 in place.  That best ensures that the bushings are aligned properly with the shaft.
 Bob,
 Thanks for your comment and for taking the time to go back thru the manual. Your understanding is correct except that I have only loctited one of the LG01A bushes.  I don't believe I have an alignment problem...I think my problem results from the bush being compressed just enough to make for an interference fit between bushing and shaft rather than for the shaft to freely rotate.
 Looking at the Loctite specs, I find that the bond dissolves at 250 degrees C (wow...that's 482 degrees F.!). I guess I can put a propane torch into the LG mounting frame and heat the puppy up to free the bushing...but am wondering what that will do to the powder coat...(?)...and I don't want to exacerbate the situation.
 While still pondering what to do, I'm certainly open to additional counsel from any source!
 Fred
 A194
		| Back to top |  |
		| grahamsingleton(at)btinte Guest
				|  Posted: Sat Nov 24, 2007 1:13 pm    Post subject: LG mounting frame |   |
				| Fred
if you can find a lump of round bar the right size to slip into the
 bush, heat that to around 300C, wait a couple of minutes, then tap the
 bush out with another lump of bar (same OD as the bush)
 That should do it without overheating the powder coating.
 The expansion of the bush will tighten it until the LG heats up a bit
 too then it should loosen.
 Get a second opinion about this!
 When you get it out you need to find out why the bust went tight!?
 Can't have been the loctite. The proper thing to do would be to ream the
 bush with a long hand reamer. Can you rent an expanding reamer long
 enough? They may exist.
 Graham
 Fred Klein wrote:
  	  | Quote: |  	  |
 Bob,
 Fred
 A194
 size  color="#000000" face="courier new,courier">
 href="http://www.matronics.com/Navigator?Europa-List">http://www.matronics.com/Navigator?Europa-List
 Graham Singleton
 Tel: +441629820187
 Mob: +447739582005
		| Back to top |  |
				|  Posted: Sat Nov 24, 2007 3:24 pm    Post subject: LG mounting frame |   |
				| Thanks Graham and Bob for your thoughts. I'm quite mindful of the need
for a close tolerance fit of the shaft within the bushings, hence my
 query and head-scratching. I believe the bush "went tight" because of
 my failure to scour out the powder coat overspray from the interior of
 the LG frame tube; when I tapped the bushing in place w/ a rubber
 mallet it compressed just a tad but enough to keep the shaft from
 rotating freely.  I believe I've solved my problem satisfactorily as
 follows:
 I mentioned that I'd only loctited one of the bushes. In order to not
 repeat my problem, I happened to have an 80 grit flap wheel for my
 Dremel which was about 1/8" dia. smaller than the tube, and I used it
 to hone the interior of the tube, removing all overspray from the
 powder coating and brightened it up. This allowed the second bush
 (which turned freely...while mounted on the shaft) to slide
 effortlessly into the LG frame tube.
 After taking another look at the bush which had been previously
 loctited in the tube, I used the flap wheel to lightly hone or dress
 (not sure of the proper term here) the inside surface of the
 bush...after several iterations (including sequential greasing and
 degreasing w/ solvent), this seemed to be doing the trick. The shaft
 now rotates freely without slop, and I've now loctited the second bush
 in place.
 Onward and upward,
 Fred
 A194
 On Saturday, Nov 24, 2007, at 13:12 US/Pacific, Graham Singleton wrote:
  	  | Quote: |  	  | When you get it out you need to find out why the bust went tight!?
		| Back to top |  |
				|  Posted: Sat Nov 24, 2007 4:39 pm    Post subject: LG mounting frame |   |
				| glad you're out of trouble Fred!
Graham
 Fred Klein wrote:
  	  | Quote: |  	  |
		| Back to top |  |
		| r.collings(at)onetel.net Guest
				|  Posted: Sat Dec 01, 2007 4:52 am    Post subject: LG mounting frame |   |
				| Hi, relax you have in effect shrunk the bush into the hole and made a good
engineering fit. What you need to do now is ream out the bush to the size of
 the shaft that fits it. If you don't have a reamer that size use a drill bit
 that mics up to the correct size. Don't use a power drill just a hand tee
 bar.To check the drill size is correct do a trial on a piece of aluminium
 first.
		| Back to top |  |
