Deems Davis
Posted: Fri Nov 30, 2007 9:57 pm Post subject: Dual battery -CG |
Just be aware, that the -10 is already Nose Heavy, and placing another
battery fwd of the CG is probably not going to help.
Deems
Vernon Smith wrote:
[quote] Bill,
This is exactly what I was looking for or something close to it.
Originally, I was planning on two equal sized batteries behind the
luggage area, but just didn't need that kind of capacity or weight in
an Aux battery. Plus I like the idea of the shorter power leads with
it mounted near the panel.
Vern
Subject: RE: Dual battery
Date: Fri, 30 Nov 2007 20:14:10 -0600
Vern, this is in my 7 but the same concept probably works in the
10. Battery is suspended directly under the AHRS. The bus right
beside it is the Aux Bat which feeds separate switches for the
EFIS which allows it to be powered on before/while starting or in
an emergency but disconnected from the main bus. The Aux Bat also
charges from the main bus during normal operations through a D25
diode. As I remember it, the battery is a Panasonic P212 (7ah)
recommended on the AE list.
Hope this helps.
Bill S
7a finishing
[mailto:owner-rv10-list-server(at)matronics.com] *On Behalf Of
*Vernon Smith
*Sent:* Friday, November 30, 2007 10:43 AM
*To:* rv10-list(at)matronics.com
*Subject:* RE: Dual battery
Has anyone come up with a way to mount a 7ah battery up under the
insturment panel or on the backside of the firewall? One of the
smaller gel cells used in alarm systems seems like a nice backup
battery for the EFIS system.
Vern Smith (#324 doors & cabin top)
> From: william(at)gbta.net
> To: rv10-list(at)matronics.com
> Subject: Re: Dual battery
> Date: Fri, 30 Nov 2007 08:24:58 -0600
<william(at)gbta.net>
> Thanks for the information and pictures on the Battery/trays.
Bob, I really
> like the looks of that accessories tray that you built. If you
get some
> pictures of it please let me know. This would be a good time to
work
> something like that into my build. As for the battery tray
dimensions, I
> think I'll probably go with PC680s. The length is 7.27" and the
width is
> 3.11". Do I need to buy the batteries and build the box to exact
dimensions
> of the 2 batteries or is it acceptable to just build the tray
maybe 1/4"
> larger on each side so that I know the batteries will fit later
on when I
> get them.
> Thanks again for all the input,
> Bill Britton
planesmith(at)hotmail.com Guest
Posted: Fri Nov 30, 2007 11:40 pm Post subject: Dual battery -CG |
The battery up front would weigh only 5 lbs. and will hopefully be counter balanced by the main battery in the tail which will be an Odyssey PC925 weighing in about 3 lbs heaver than the OEM Concord. Also my planned panel is stock Van's and fairly sparse. However, if it need to go in the tail for CG it can go in the tail.
Vern
> Date: Fri, 30 Nov 2007 22:57:21 -0700
[quote] From: deemsdavis(at)cox.net
Subject: Re: Dual battery -CG
--> RV10-List message posted by: Deems Davis <deemsdavis(at)cox.net>
Deems
Vernon Smith wrote:
> Bill,
> Thanks,
> Vern
> do not archive
> From: billschlatterer(at)sbcglobal.net
> Hope this helps.
> Bill S
> 7a finishing
> *From:* owner-rv10-list-server(at)matronics.com
> *Vernon Smith
> > --> RV10-List message posted by: "Bill & Tami Britton"
> Bob, I really
> get some
> work
> dimensions, I
> width is
> dimensions
> maybe 1/4"
> on when I
> > get them.
> > Bill Britton
