allanwright(at)comcast.ne Guest
Posted: Sat Dec 01, 2007 12:23 pm Post subject: On-board battery charge controller |
Recently, a friend and I bought an RV4, which had been built in 2001 but
not flown much since. Almost immediately, we had to replace the battery
(Gill G25S). I've been looking into battery chargers and desulfators to
try to prolong the life of our new battery. I also read the excellent
chapter on batteries in the AeroElectric Connection.
Based on my reading and online research, it seems like we can buy a
smart charger with a desulfator for somewhere between $80 and $160,
which should do a pretty good job of maintaining the battery when it is
on the ground. However, since our alternator voltage is on the high side
(14.8 to 15.0 volts), the battery will be overcharged every time we fly
the airplane, particularly when it is hot outside which is a lot of the
time in California. Our voltage regulator is not adjustable, and I
really don't want to replace it.
Since I have quite a bit of experience with electronic design (digital
and analog but not power circuits) I thought I might try to design a
circuit that would control the charging of the battery both in-flight
and on the ground. Conceptually, it would work like this:
- the battery would still connect to the main bus through the master
relay, but with a series diode so that current could only flow from the
battery to the bus.
- my circuit would also connect between the battery and the main bus,
and would control the charge current flowing into the battery when the
engine is running
- initially, it would apply the full bus voltage to the battery, and
monitor the charging current as well as the battery temperature
- when the current drops below an adjustable limit such as 0.5 amps, it
would lower the voltage to the temperature-compensated float voltage
recommended by the battery manufacturer
- on the ground, it could be connected to an external power supply to
keep the battery charged
- optionally, an on-board desulfator such as the one from Battery Minder
could be added to the system, which would function both in-flight as
well as on the ground
- optionally, an LCD display could be added which would show the battery
voltage, bus voltage, charge current and battery temperature.
If it works, I could publish the circuit and maybe provide a PCB so that
others could build it if they wanted to.
I wonder if anyone has any comments on this idea? If it has been done
before, I don't want to re-invent the wheel.
Thanks.
Allan
schaefer(at)rts-services. Guest
Posted: Sat Dec 01, 2007 5:50 pm Post subject: On-board battery charge controller |
It seems it would be a lot simpler to replace the Voltage regulator with one
that works. Get a B&C with temp compensation.
Then just put the relatively inexpensive battery tender on when you are in
the hanger.
Batteries really like to get brought back to nominal charge with a good
supply of current. Your circuit would need to control a wide range of
currents (large for recharging [Constant Current, Floating Voltage], low
[Constant Voltage, Variable Current] for maintenance). A alternator with a
good voltage regulator, will handle battery charging just fine!
Another negative of your approach is you take the battery out of the system
as a device to overcome transients of over voltage. Now your main bus needs
to handle ALL of the transients on the buss. A good battery is very good at
absorbing transients that might otherwise eat up some of your electronics.
rjquillin
Posted: Sat Dec 01, 2007 6:39 pm Post subject: On-board battery charge controller |
At 14:37 12/1/2007, you wrote:
| Quote: | It seems it would be a lot simpler to replace the Voltage regulator with one
that works. Get a B&C with temp compensation. |
Is anyone aware of a similar product for certified aircraft?
Ron Q.
BobsV35B(at)aol.com Guest
Posted: Sat Dec 01, 2007 7:26 pm Post subject: On-board battery charge controller |
Good Evening Ron,
I have had excellent results with products purchased from Zeftronics. They also seem to have very helpful customer service personnel.
B&C does have some products for a certified aircraft. I have one of their standby alternator systems that is certified on my V35B Bonanza.
Happy Skies,
Old Bob
AKA
Bob Siegfried
Ancient Aviator
Stearman N3977A
Brookeridge Air Park LL22
Downers Grove, IL 60516
630 985-8503
In a message dated 12/1/2007 8:41:39 P.M. Central Standard Time, rjquillin(at)gmail.com writes:
Ron Q.
hottest products and top money wasters of 2007.
handainc(at)madisoncounty Guest
Posted: Sat Dec 01, 2007 8:33 pm Post subject: On-board battery charge controller |
Ron -
I have had excellent service with a Zeftronics Voltage regulator on my 125 HP Pacer. The first two years I owned the airplane, I was having nothing but trouble with the voltage regulator - got two bad ones in a row, if you can believe that. Found Zeftronics on line, and they didn't have the Pacer on their certification, but had the 0290 Lyc certified in another airplane, so they applied and got it certified. I put in on my Pacer and have had absolutely NO trouble since that date, and it's now been 10 or 11 years. Great customer service and great service from the unit.
M. Haught
BobsV35B(at)aol.com (BobsV35B(at)aol.com) wrote: [quote] Good Evening Ron,
Happy Skies,
Old Bob
AKA
Bob Siegfried
Ancient Aviator
Stearman N3977A
630 985-8503
In a message dated 12/1/2007 8:41:39 P.M. Central Standard Time, rjquillin(at)gmail.com (rjquillin(at)gmail.com) writes:
Ron Q.
| [b]
Posted: Sun Dec 02, 2007 8:24 am Post subject: On-board battery charge controller |
Thanks for your comments.
The problem with the voltage regulator is not just the lack of
temperature compensation. It's that the regulator can't tell whether it
is bulk charging or float charging the battery, which require different
voltages. Typically, the regulator is set to a voltage that is good for
recharging but too high for float charging. Since our airplane usually
starts immediately, the actual time required to recharge the battery is
pretty minimal.
I believe that the Battery Tender product is not recommended for Gill
batteries, it has been known to boil off the electrolyte. There is a
warning on the Aircraft Spruce website not to use them for these batteries.
You make a good point about losing the battery's ability to absorb
transients.
Allan
the hanger.
rjquillin
Posted: Sun Dec 02, 2007 9:12 am Post subject: On-board battery charge controller |
At 08:23 12/2/2007, you wrote:
| Quote: | I believe that the Battery Tender product is not recommended for
Gill batteries, it has been known to boil off the electrolyte. There
is a warning on the Aircraft Spruce website not to use them for
these batteries.
The BatteryMINDer folks discontinued selling and no longer recommend
their non-temperature compensated unit for aviation AGM usage, and
now sell one that is temperature compensated.
http://www.thebatteryminder.com/12vaircraftbatteryminder-p-75.html
I spoke to them a few months ago, and for owners of the older unit,
the new compensated unit may be purchased at 50% off retail.
Ron Q.
simon(at)synchronousdesig Guest
Posted: Sun Dec 02, 2007 10:13 am Post subject: On-board battery charge controller |
Ron,
This is a pretty good unit. Battery Minder sells the 12248-AA-S1 for
$159.95, and Battery Mart sells it for $139.95. Go figure (literally).
Here's their link:
http://www.batterymart.com/c-batteryminder-battery-chargers.html
Simon
Copyright C 2007
klehman(at)albedo.net Guest
Posted: Sun Dec 02, 2007 10:49 am Post subject: On-board battery charge controller |
I would suggest that the difference in battery life between a
sophisticated charger and a cheap automotive regulator is pretty much
negligible for most of us that fly less than 100 hours per year.
Certainly I'd like a bit less than the 15 volts mentioned. Yes I like
the minimal temperature compensation that most automotive regulators
have. Even with an RG battery I believe that temperature compensation is
more important than fancy charging profiles for most of us. Different
story for marine batteries and standby batteries. My recommendation is
fly it at least every two weeks and charge it if left more than a month
or two or just float it to minimize sulphation. But choose the simplest
and most reliable regulator that is available for reasonable money to
get the least cost of ownership. An extra year of battery life is going
to seem very unimportant if a one of a kind regulator dies far from home...
Ken
Allan Wright wrote:
<allanwright(at)comcast.net>
it is bulk charging or float charging the battery, which require
different voltages. Typically, the regulator is set to a voltage that
is good for recharging but too high for float charging. Since our
airplane usually starts immediately, the actual time required to
recharge the battery is pretty minimal.
batteries.
transients.
Allan
