wcurtis(at)nerv10.com Guest
Posted: Tue Dec 04, 2007 10:38 am Post subject: unused F-1003A instrument panel blank |
Anyone have an F-1003A instrument panel that they will not be using that they would like to sell? I'm looking to have the stock panel waterjet cut by the folks at experimental air (http://www.experimentalair.com/) and would like an extra panel to experiment on. Van's seems to have raised the price of the F-1003A panel to $55. I can get a 2' X 4' X 0.063 sheet of 6061-T6 from Spruce for about $36, but I know some builders are opting for fiberglass or the oversized panel from Stein in place of the stock panel. I can give a home to that leftover stock panel.
William
http://wcurtis.nerv10.com/
dlm46007(at)cox.net Guest
Posted: Tue Dec 04, 2007 10:52 am Post subject: unused F-1003A instrument panel blank |
You might consider using your original panel for the experiment and making
the final panel out of .090. It provides a stiffer panel for big EFIS
cutouts.
david555(at)cox.net Guest
Posted: Tue Dec 04, 2007 3:16 pm Post subject: unused F-1003A instrument panel blank |
I have one you can have. E-mail me (at) david555(at)cox.net. David O Boone
Posted: Tue Dec 04, 2007 7:12 pm Post subject: unused F-1003A instrument panel blank |
Thanks to all who responded and offered me their "left over" F-1003A instrument panel blank. Local builder Bob Newman (http://www.tcwtech.com/RV-10%20construction%20project.htm) has graciously offered me his since he will be going with a composite panel similar to his Glastar (http://www.tcwtech.com/New%20Panel%20N99RN.JPG). While I'm there to pick up the panel, I'll take the opportunity to closely examine his Safety-Trim (http://www.tcwtech.com/Aviation%20Products.htm).
Seems quite a few folks have left over instrument panels. One year at OSH we should have all builders bring their left over parts (panels, crotch strap clip, primer pump mount, door handles, etc) put it in a pile and raffle it all off with the proceeds going to charity. I bet that would be one big pile of parts.
William
