		tjs22t(at)verizon.net Guest
				 Posted: Wed Dec 05, 2007 12:26 pm    Post subject: What have you got to lose??? |
				I have heard some guys talking about compass's and they have said >the cheapest and most reliable one they found came straight from >the auto parts store. I don't know if this is true or not but with >a dynon and a GPS this is kind triple redundant so I could see how >this might work but for 20 bucks what have you got to lose.
 Jeff, what you have to lose is time if your inspector won't approve it.  The inspector or DAR might pan such a cheapie as regulations require a compass.  Would they allow it if you have an EFIS with compass?  Better ask.
 tj  do not archive
  |  | - The Matronics Zenith-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		Gig Giacona
				 Posted: Wed Dec 05, 2007 12:47 pm    Post subject: Re: What have you got to lose??? |
				Correct but there is no TSO requirement for the type of compass in a EXP-HB. As far as an EFIS as a compass  they should.
  	  | tjs22t(at)verizon.net wrote: |
 tj  do not archive |
601XL Under Construction
				 Posted: Wed Dec 05, 2007 1:06 pm    Post subject: What have you got to lose??? |
				The actual wording is "magnetic indicating device" I believe. I have seen a
 number of (approved and flying) panels with nothing but an EFIS.
 -- Craig
		Afterfxllc(at)aol.com Guest
				 Posted: Wed Dec 05, 2007 2:39 pm    Post subject: What have you got to lose??? |
				The DAR that tells you what to put in your airplane is not doing his  job.... His job is to inspect your aircraft and make sure it is in a "Condition  for safe operation" and if he wouldn't give you an airworthiness certificate  because you had a cheap compass than you my friend have pissed off your  DAR. If you were correct in your assumption then he could also say you  can't fly with that Stewart Warner Tack or that car motor. The Dynon is not  TSO'd either. Just because something costs more doesn't mean it's better or not  worthy of flight.
  Jeff
   In a message dated 12/5/2007 3:28:00 P.M. Eastern Standard Time,  tjs22t(at)verizon.net writes:
   	  | Quote: | 	 		  -->    Zenith-List message posted by: <tjs22t(at)verizon.net>
 tj  do not  sp;             (And Get Some AWESOME FREE   find  you for                          -Matt Dralle,    List  he  es  y       -->                 - MATRONICS WEB FORUMS  ======================
 hottest products and top money wasters of 2007.
				 Posted: Wed Dec 05, 2007 3:39 pm    Post subject: What have you got to lose??? |
				CFRs state that your aircraft must have a "magnetic direction  device".   Doesnt say make or ect....
  SW---
		bryanmmartin
				 Posted: Wed Dec 05, 2007 4:14 pm    Post subject: What have you got to lose??? |
				Exactly, if your DAR refuses to  give you an airworthiness certificate because of your compass, fire the son of a bitch and find someone else. He obviously doesn't know his job. There's no requirement for an aircraft approved compass in a home built.
 On Dec 5, 2007, at 5:27 PM, Afterfxllc(at)aol.com (Afterfxllc(at)aol.com) wrote:
 [quote]  The DAR that tells you what to put in your airplane is not doing his job.... His job is to inspect your aircraft and make sure it is in a "Condition for safe operation" and if he wouldn't give you an airworthiness certificate because you had a cheap compass than you my friend have pissed off your DAR. If you were correct in your assumption then he could also say you can't fly with that Stewart Warner Tack or that car motor. The Dynon is not TSO'd either. Just because something costs more doesn't mean it's better or not worthy of flight.
  Jeff
   In a message dated 12/5/2007 3:28:00 P.M. Eastern Standard Time, tjs22t(at)verizon.net (tjs22t(at)verizon.net) writes:
   	  | Quote: | 	 		  -->   Zenith-List message posted by: <tjs22t(at)verizon.net (tjs22t(at)verizon.net)>
  _________________ --
Bryan Martin
do not archive. |
		zodierocket(at)hsfx.ca Guest
				 Posted: Wed Dec 05, 2007 6:20 pm    Post subject: What have you got to lose??? |
				I find a compass a useless piece of avionics in today cockpits. With my Dynon/Sensornetics and GPS why the heckdo I still need a compass. Oh right the Canadian Government will not give me a flight authority without a “Whiskey Compass” Not a remote compass like my Dynon, not a card compass or a directional gyro but  a Whiskey Compass.
 I think I have finally figured out why!! If I go down in the frozen north wilderness of Canada I can crack open my whiskey compass and drink the contents, blindness would follow shortly. The fine gov officials know that I would not want to see just how screwed I am after they cut spending on our search and rescue resources again.
 Mark Townsend  Alma, Ontario
 Zodiac 601XL C-GOXL, CH701 just started
 www.ch601.org / www.ch701.com/ www.Osprey2.com
		ashontz
				 Posted: Thu Dec 06, 2007 4:15 am    Post subject: Re: What have you got to lose??? |
				I actually use my compass all the time in my boat. I've actually had times where either the LORAN wasn't picking up this last go round, it actually stopped working, while I was in the geographic center of the Delaware Bay, that's 12 miles from anything. 12 miles from anything on a hazy windless flat day at slack tide at 12 noon and you can't see any land, you have no idea which direction is what. Couple that with concentrating on fishing for 2 hours and you definitely don't kow which way you're looking. It's like being in IMC. I've been flying on borderline VFR days and at 1,800 feet, it's like looking down into a fishbowl with a small circular window surrounded by hazy, and that's actually legal VFR. 3 miles of visibility at 1,800 will give you a cone about 135 degrees to see down, and you can't see the horizon. If you're electronics give up even in that kind of legal VFR it's probably good to have a compass onboard. Maybe you don't get that kind of hazy weather up in Canada, but in Jersey it's the norm.
  	  | zodierocket(at)hsfx.ca wrote: | 	 		  I find a compass a useless piece of avionics in today cockpits. With my Dynon/Sensornetics and GPS why the heckdo I still need a compass. Oh right the Canadian Government will not give me a flight authority without a ?Whiskey Compass? Not a remote compass like my Dynon, not a card compass or a directional gyro but  a Whiskey Compass.
		shilcom
				 Posted: Thu Dec 06, 2007 6:09 am    Post subject: What have you got to lose??? |
				<<<His job is to inspect your aircraft and make sure it is in a  "Condition for safe operation">>>
  His job also is to see that the airplane meets FAA regulations.    If regulations require a magnetic compas, some units MAY not meet this  reqirement if it exist.  Bob U.
  [quote]   ---
		shilcom
				 Posted: Thu Dec 06, 2007 6:44 am    Post subject: What have you got to lose??? |
				Do you also find an electric turn and bank  indicator a "useles piece of junk" in todays cockpit.  Bob U.
  [quote]   ---
		pmaxpmax(at)HOTMAIL.COM Guest
				 Posted: Thu Dec 06, 2007 11:38 am    Post subject: What have you got to lose??? |
				My DAR looked at my vertical card compass and must have thought it was lovely.  At that time, that was the only type of direction indicator I had.  This is a non-issue.
 Phil Maxson
  601XL/Corvair
  Northwest New Jersey
  [quote]  From: shilocom(at)mcmsys.com
 Subject: Re: What have you got to lose???
 Date: Thu, 6 Dec 2007 08:07:18 -0600
