DAquaNut(at)aol.com Guest
Posted: Thu Feb 23, 2006 6:12 pm Post subject: Safety rings |
Group,
A while back someone on the list said that safety rings were better than
safety pins ,especially on the tail feathers. OK Who is the source for the
rings ? I don't seem to be able to find anyone who handles them>
Ed Diebel
Posted: Thu Feb 23, 2006 6:36 pm Post subject: Safety rings |
than
source for the
| Ed Diebel
Hi Ed:
I am fortunate. Do not have to fold. If I did have to fold my Kolb,
I would still use the same system I use now, AN bolts, washers, and
nyloc nuts.
Probably the most vulnerable attachment is the lower tailwires on the
tail post. On other than a manicured airstrip, safety pins and safety
rings are at risk of becoming unfastened. A 3/16 bolt inserted from
right to left, when standing behind the rudder and looking forward,
with washers and a nyloc nut make me feel much more comfortable.
Previously, I inserted the above bolt from left to right from habit.
Had occassion to come very close to losing the nut which was unscrewed
by alder bushed in my first off field landing in Alaska, 1994. From
tht time on, I always insert from right to left with nut on the left.
That way, the nut will be tightened as it is subjected to bushes and
heavy weeds, etc.
Doesn't take much longer to spin off or on the same amount of nyloc
nuts as it does to fumble with safety pins and rings, in my opinion.
Take care,
_________________ John Hauck
Titus, Alabama |
Richard Pike
Posted: Thu Feb 23, 2006 7:12 pm Post subject: Safety rings |
Do not use a safety ring or safety pin on that lower tail wire bolt. Do
what John says, use a real bolt. For the other pins, the easiest way to
get a circle pin is to make your own. Go by Lowes or any hardware store,
get a spring with at least 1/2" to 5/8" ID, and cut out some rings with
a pair of side cutters, or best of all - a Dremel tool using a cut-off
wheel. You can easily make a half dozen of them in 20 minutes. Or spend
an hour doing it and give some to all your friends. They will think you
are a great guy.
Richard Pike
MKIII N420P (420ldPoops)
PeeEss to John: Are you sure about that right to left stuff? You got me
thinkin' (always scary) and I went to the garage and got a nut and bolt,
and if the bolt goes in from the left, and the nut is on the right
(looking from tail to nose) a wiping motion against the bottom of the
nut tightens it. If the bolt comes in from the right to the left, the
nut on the left end is loosened by a wiping motion on the bottom... Or
am I missing something? Again?
John Hauck wrote:
than
source for the
| Ed Diebel
Hi Ed:
nyloc nuts.
heavy weeds, etc.
Take care,
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
WhiskeyVictor36(at)aol.co Guest
In a message dated 2/23/2006 9:36:46 P.M. Eastern Standard Time,
jhauck(at)elmore.rr.com writes:
heavy weeds, etc.
Hi John H,
I am trying to understand how the nut would be "tightened", when mounted on
the left side (as standing behind the tail looking forward). If I then stand
on the left side of the plane and look face in to the end of the bolt and
nut, it seems as though the bushes & weeds, as they pass from front to rear,
would rub against the bottom edge of the nut trying to turn it
counterclockwise, which would in effect screw it off the bolt. Am I misunderstanding
something here.
Bill Varnes
Original Kolb FireStar
Audubon NJ
Posted: Thu Feb 23, 2006 7:45 pm Post subject: Safety rings |
Brother Richard P:
I was backassward. Put the bolt in from left to right. As the nut on
the bolt, not the nut on the control stick (that's me) zips through
whatever it is zipping through, it will tighten rather than loosen.
Hope I didn't screw folks up too badly with the first iteration.
hehehe
john hMKIII/912ULS
Titus, Alabama |
| I am trying to understand how the nut would be "tightened", |
| Bill Varnes
Brother Bill V:
You are absolutely correct. Checking to see if you all are awake out
there.
hauck's holler, alabama
Titus, Alabama |
Richard Pike
Posted: Thu Feb 23, 2006 7:58 pm Post subject: Safety rings |
Hey, that's a good story - I would stick with it... :-!
Richard Pike
John Hauck wrote:
| Quote: | You are absolutely correct. Checking to see if you all are awake out
there.
Kingsport, TN 3TN0
Denny Rowe
Joined: 10 Jan 2006 Posts: 89 Location: Leechburg, PA
Posted: Thu Feb 23, 2006 10:16 pm Post subject: Safety rings |
Denny Rowe
Posted: Thu Feb 23, 2006 10:28 pm Post subject: Safety Rings |
Anyone interested,
Just checked out McMaster-Carrs web sight for Safety Rings.
They call them "Cotter rings" so that is what you want to search for on their sight. They sell them Dirt cheap and have them in Steel and Stainless steel and two differant finishes. Also have several differant sizes.
If you have never ordered from these fine folks you are in for a treat, they are the fastest, best service in the world and the shipping is very reasonable.
Check their sight for just about anything you might want to buy, they probably have it.
Denny Rowe
vicsvinyl(at)verizon.net Guest
Posted: Fri Feb 24, 2006 5:28 am Post subject: Safety rings |
Hey John H.
Speaking of nuts, does size (prop) matter. You said your runing a 72" on
your 912S I'll be using a 70" Warp Drive with a 912ul. Is that a good combo
to start with.
Vic
Maine
MKIIIX
n79rt(at)kilocharlie.us Guest
Posted: Fri Feb 24, 2006 6:01 am Post subject: Safety Rings |
<SNIP>
reasonable.
probably have it.
Denny Rowe
<SNIP>
Hey Denny...your right about McMaster-Carr. Funny story....my office
used to be in Phenix City, Al. (approx. 1.5 hours southwest of Atlanta,
Ga.)
I called in an order about noon for a couple of things I needed and went
back to working at my desk...'bout 3 oclock the doorbell rings and it is
a delivery guy. This is an everyday thing (getting a package...work
related at least) but when I look at the "from who" on the package it
was McMaster! I asked the guy how it got here the same day and he
grinned and said. "I drove it down from Atlanta!"
Turns out one of their main warehouses is in Atlanta and they do enough
business in my area to run a delivery route direct from their warehouse!
Was the fastest delivery ever for me...
Jeremy
Posted: Fri Feb 24, 2006 6:16 am Post subject: Safety Rings |
Agreed. Their catalog is one you can't put down once you start leafing
through. -includes obscure stuff you never knew existed.
-BB do not archive
On 24, Feb 2006, at 9:00 AM, Jeremy Casey wrote:
<SNIP>
very
reasonable.
probably have it.
Jeremy
Denny Rowe
Posted: Fri Feb 24, 2006 7:37 am Post subject: Safety rings |
72" on
good combo
| to start with.
| Vic
Yes, I put a lot of hours on a 912UL with 70" Warp. Also flew the
912ULS with a 70". Last flight to Alaska was with that prop. Paul
Petty will be flying my old prop on his 912UL Kolbra.
Titus, Alabama |
Posted: Fri Feb 24, 2006 8:43 am Post subject: Safety Rings |
In a message dated 2/24/2006 12:29:19 A.M. Central Standard Time,
rowedl(at)highstream.net writes:
reasonable.
probably have it.
Thanks Denny,
I will be getting some.
Ed Do not archieve
Posted: Fri Feb 24, 2006 8:51 am Post subject: Safety rings |
Why the switch to a 72"
just curious Vic
dpaule(at)frii.com Guest
Posted: Fri Feb 24, 2006 9:07 am Post subject: Safety Rings |
Don't use them on airplanes!
I've got an F-27 sailboat and the email forum for these trimarans has
reported several instances of the rings coming out. I've caught a couple
just before they came undone on my own boat.
When I do use them, I wrap rigging tape (vinyl tape is fine) around the ring
and the pin that the ring is holding and that whole joint. Then it's an easy
inspection of the tape, which I generally change every time I launch the
boat, once or twice a year. When the tape is wrapped around them they are
fine.
But to reiterate, it's not an aircraft device... far too dangerous.
Dave Paule
Kolb Firestar II for sale
Cessna 180 Big Hammer
F-27 Second Chance
Dennis.Kirby(at)kirtland. Guest
Posted: Fri Feb 24, 2006 9:25 am Post subject: Safety Rings |
At Ralph Burlingame's recommendation, I bought some stainless steel safety
rings at the local sailboat store. They are one inch in diameter, and have
an offset end to make them easy to thread into the hole in the clevis pin.
And as John H suggests, I do not use a clevis pin for the tail wires - I use
an AN-3 bolt with a drilled shank. After I install this bolt with a
wingnut, it is secured with a safety pin (or ring).
Dennis Kirby
Posted: Fri Feb 24, 2006 9:48 am Post subject: Safety Rings |
wires - I use
| Dennis Kirby
Maybe some of the experts on the List will respond to this. I know
Old Kolb and probably New Kolb send along a wing nut for attachment of
the lower wire brace. The bolt is in shear and tension. I have not
checked, but would guess the wing nut is a tension only piece of
hardware. Might be worth checking out. That is why I use a nyloc nut
on the bottom wire brace bolt.
Titus, Alabama |
Larry Cottrell
Joined: 10 Jan 2006 Posts: 35 Location: Klamath Falls, Oregon
Posted: Fri Feb 24, 2006 3:30 pm Post subject: Safety Rings |
