pperal(at)bsab.com Guest
Posted: Sat Dec 08, 2007 3:38 pm Post subject: Subaru for my zenairHD |
Hello to all, I present myself, my name is Antonio Beneytez and finishing of
build a Zenair 601HD in Madrid Spain, after a lot to look for engine is
almost resolved to mount a subaru Stratus 2000 and I would like to know if
you have had some problem with this motor and as solving it. I would also
like to know the benefits that he has the airplane with this motor like:
consumptions, wheight, speeds stall and of cruise that distances it travels
before the take off, etc.
That propeller is the most appropriate?
Is there some problem with the ignition?
If you consider some important fact I would also like to know it.
Thank you.
Antonio Beneytez
Madrid Spain
| | - The Matronics Stratus-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Stratus-List |
tshankland(at)sbcglobal.n Guest
Posted: Sat Dec 08, 2007 7:17 pm Post subject: Subaru for my zenairHD |
Antonio,
Some number of years ago the Stratus was very popular on this list, now
everyone is looking at a Jabiru or Corvar. Myself I bought a a Stratus
and am very happy with it. I have about 60 hours on my 601HD and have
had no engine related problems. My point was I did not want another air
cooled engine water cooling has several advantages that have been
debated on this list in the past. The most important part of a reliable
installation is a adequate cooling system. I my opinion the Zenith
system with the "diaper" radiator on the bottom is marginal at best.
Some have made it work well but I have heard of many that have had heat
problems especially on hot days. My engine runs at 190 F on any day
summer or winter, on a long climb out in the summer it might rise to 200
until I level out. People on the ground comment on how quite the plane
is. Unlike aircraft engines I have had in the past where 1 quart of oil
every 10 hours is considered normal, I use about 1/2 a quart between oil
changes of 50 hours. As far as specifics for my plane I use a Warp Drive
prop and cruise of 75% power at 105 mph with a fuel burn of 5.6 gal/hr.
My empty weight is 788 lb.( sorry everything is English measure) but I
have a full IFR panel. I have heard of some problems with the ignition
but I have not had any. Let me know if there is anything else you need
to know. As for the most important item, cooling, I think if the engine
is adequately cooled most problems don't happen.
Tim Shankland
Antonio bm wrote:
finishing of build a Zenair 601HD in Madrid Spain, after a lot to look
for engine is almost resolved to mount a subaru Stratus 2000 and I
would like to know if you have had some problem with this motor and as
solving it. I would also like to know the benefits that he has the
airplane with this motor like: consumptions, wheight, speeds stall and
of cruise that distances it travels before the take off, etc.
Thank you.
Antonio Beneytez
Madrid Spain
gkrysztopik(at)satx.rr.co Guest
Posted: Sun Dec 09, 2007 6:05 am Post subject: Subaru for my zenairHD |
Antonio,
I think it would be worth your time to read the list archives. The list
is very small and everything has been talked about in great detail.
After getting the history then you may have specific questions.
A short list might be this;
- get the dual ignition
- make sure the upper right(?) engine mount is a newer design
- ask for a "short" starter so the throttle springs can be setup to
pull-"on"
- send the heads to RAM for upgrade (stepped valve guides)
- wire a redundant battery supply for the second ignition
- relieve the secondary ignition bracket of the sharp inside corners or
it may end up cracking
- setup the belt tension for 1/4" play at the prop tips when cold
- anything else?
- a 72" Warp Drive 3-blade square tip ground adjustable has worked well
for many people.
- it consumes just under 4 gallons/hr at slow cruise, 5-6 at high cruise
- there are a lot flying and it has been a very reliable and economical
engine for most people. I have been very happy with mine.
Gary
Pelican PL
San Antonio, TX
