pwmac(at)sisna.com Guest
Posted: Sun Dec 09, 2007 8:02 am Post subject: 912 EFI kit |
Interesting
From another list
Looking forward to hearing about the success of the kit and all the
changes required.
http://www.sdsefi.com/aircraft.html
You need to scroll down the page for the announcement.
I have no affiliation with these people
Regards, Paul
Gilles.Thesee(at)ac-greno Guest
Posted: Sun Dec 09, 2007 9:01 am Post subject: 912 EFI kit |
paul wilson a écrit :
Paul,
Please note that adding electronic fuel injection to an engine means
adding dependence on electricity.
| Quote: | The extra current draw of the electric fuel pump, ECU and injectors
comes to around 7-9 amps. Operation with the existing internal 20 amp
alternator will demand that other normal electrical loads don't exceed
8-10 amps
And considering the standard Rotax regulator cannot supply more than
12-14 amps continuous without tending to self destruct, there is not
much left for the ordinary appliances and battery on board.
The maximum regulator momentary output is in the vicinity of 18 amps.
Gilles Thesee
Grenoble, France
http://contrails.free.fr
Posted: Sun Dec 09, 2007 10:03 am Post subject: 912 EFI kit |
True Rotax has minimal electrical power. To bad.
The fix would be a proper alternator, then use
the Rotax one for backup with just essential
items on line. There are more than one add-on
alternator kits available for the 912. I probably will need one anyway.
The EFI does add more complexity with a required
high pressure pump or two and return line and who knows what else.
It would be nice to modernize the engine.
BTW, I read about a lot of regulator failures,
but have not read about the stator generator failures.
Paul
At 08:59 AM 12/9/2007, you wrote:
Thesee <Gilles.Thesee(at)ac-grenoble.fr>
Paul,
injection to an engine means adding dependence on electricity.
>pump, ECU and injectors comes to around 7-9
>amp alternator will demand that other normal
>electrical loads don't exceed 8-10 amps
cannot supply more than 12-14 amps continuous
Gilles Thesee
Grenoble, France
Posted: Sun Dec 09, 2007 10:39 am Post subject: 912 EFI kit |
Adding complexity is justified only for correcting some defect.
Not sure whether the 912 really is in need of fuel injection.
BTW, I read about a lot of regulator failures, but have not read
The stator itself is very robust.
It took a lot of abuse when we bench tested it :
http://contrails.free.fr/elec_ducati.php
Best regards,
Gilles
alex_01
jack.kuehn(at)gmail.com Guest
Posted: Sun Jan 06, 2008 8:06 am Post subject: 912 EFI kit |
This site is in German, which I don't read too well, unfortunately.
What is it, it looks really interesting!
On Jan 6, 2008 8:22 AM, alex_01 <zoechling(at)gmx.de> wrote:
Jack Kuehn
5565 Brady Ln
Lolo, MT USA 59847
(406)273-6801
(406)546-1086 cell
(406)273-2563 fax
alex_01
Posted: Mon Jan 07, 2008 10:45 am Post subject: Re: 912 EFI kit |
it is about a ready to go EFI system utilize the original manifold
you can choice with either one or two (as a back up) ecu boxes
what is important the system can run without battery it is self redundant.
better fuel economy in middle range, better egt with only approx 20°C differ between cylinders.
nice system but to expensive for the 100 to 200 hrs flyer per year i think
but nice and technical
l_luv2_fly(at)yahoo.com Guest
Posted: Mon Jan 07, 2008 7:19 pm Post subject: 912 EFI kit |
Hi Alex,
Would you happen to know if its still fixed timing or do the ECU's alter the timing to match different RPM's, vacuum and EGT parameters ?
Thanks, Paul
alex_01
Posted: Tue Jan 08, 2008 2:45 pm Post subject: Re: 912 EFI kit |
reading in on the website it says it got fuel and ign. maps
i hope this answers your question.
speaking from my experience in my normal day-job for sure the ign and fuel systems used on most airplane engine is a bit stone age but as the flying folks is a bit Conservative if it don't break don't fix it.
but carbs are ok ish as we do most of the running the engine with a constant rpm so the advantages are less but for sure the altitude compensation would bit a lot better with proper maping and therefore mixture compensation.
litesellme(at)yahoo.com Guest
Posted: Mon Jan 14, 2008 11:03 am Post subject: 912 EFI kit |
I have seen may people attempt to do fuel injection, but at www.experimentalfuelinjection.com , we do it right. First off, fuel injection requires 8-9amps no matter who is making the set up. With this in mind, the only way to properly run fuel injection is with a 55 amp external alt. Our set ups are simply the best. We offer 4 different configurations of 912's and 5 different configurations of 914's. From Intercooled direct port fuel injection, to truly redundant set ups on fuel and ignition, we have it all.
Jason
661 428-1850
alex_01 <zoechling(at)gmx.de> wrote:[quote] --> RotaxEngines-List message posted by: "alex_01"
you can choice with either one or two (as a back up) ecu [quote][b]
JOE RONCO
Joined: 04 Aug 2007 Posts: 31 Location: CENTENNIAL COLORADO
Posted: Mon Jan 14, 2008 2:07 pm Post subject: 912 EFI kit |
JASON: I am curious as to why you need a 55 Amp alternator for the EFI for the 912 ULS? Another engine manufacturer only uses a 30 Amp.
Joe Ronco
From: owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of jason Parker
Sent: Monday, January 14, 2008 12:00 PM
Subject: Re: Re: 912 EFI kit
Jason
661 428-1850
you can choice with either one or two (as a back up) ecu | Quote: | | http://www.matronics.com/Navigator?RotaxEngines-List | 0123456789
Posted: Mon Jan 14, 2008 4:47 pm Post subject: 912 EFI kit |
Joe,
I use the same alternator used on the rotax alt kit. It is a 6 pound denso alternator one wire set up. You need 9-10 amps for fuel injection. If you rely on the stock stater /gen assembly, it is only good for 14 continuous. With fuel injection pulling 10 amps, that leaves you 4 for gages, strobes, radio, ect. To answer your question, a 30 amp alt will do just fine.
Jason
Joe Ronco <joe(at)halzel.com> wrote:[quote] <![endif]--> <![endif]--> JASON: I am curious as to why you need a 55 Amp alternator for the EFI for the 912 ULS? Another engine manufacturer only uses a 30 Amp.
Joe Ronco
Jason
661 428-1850
| Quote: | | http://www.matronics.com/Navigator?RotaxEngines-List | 012345[quote][b]
Posted: Tue Jan 15, 2008 8:01 pm Post subject: 912 EFI kit |
Hi Jason,
Could you tell me how many of your engines are in flying aircraft and approximately how many hours (agregated) have been accumulaed ?
Thanks, Paul
Posted: Wed Jan 16, 2008 8:32 am Post subject: 912 EFI kit |
Paul,
all the engines I use are from the predator uav program. The military has a whole protocall for pulling engines: overspeed, overtemp, overboost, high or low oil pressure, lack of performance, or 600Hours. Most engines I receive are because of lack of performance. The military runs 100ll which fouls up the rings, builds large deposits on the cylinder heads/pistons/ valves. The average time on a engine I receive is around 400 hours.
regards
Jason
Paul McAllister <l_luv2_fly(at)yahoo.com> wrote:[quote] Hi Jason,
Thanks, Paul
rampil
Posted: Wed Jan 16, 2008 5:23 pm Post subject: Re: 912 EFI kit |
Hi Jason,
I think the question Paul was asking referred to time on engines
AFTER your conversion. Do you have any customers with flying
aircraft and your injection / turbo system that could share their opinions
or go to SnF or Oshkosh where we could see the hardware, etc.
Posted: Thu Jan 17, 2008 9:35 am Post subject: 912 EFI kit |
