		n277dl
		flywrights(at)yahoo.com Guest
				 Posted: Thu Dec 13, 2007 11:41 pm    Post subject: Height of Fuse stand |
				no no no. You want something low to the ground while you work on it, unless you plan to skip to the gear install first.  You're going to be climbing in and out a whole lot and leaning over a bunch before it's up on gear.  How tall are you???!
  I used two pallets fastened together with casters on the bottom, and it was still a little tall.  I put a carpet scrap between the pallets and the fuse.
  BTW, If you plan to skip to the gear install, make sure you've done any soundproofing to the subfloor and floor pans under the gear leg brackets.  I and others had to remove them to get the subfloor work done, which in itself involves a lot of bending and leaning, so you want a short stand anyway.
  Rob Wright
  #392
  buildus interruptus since May, but still here!
		LarryRosen
				 Posted: Fri Dec 14, 2007 9:22 am    Post subject: Height of Fuse stand |
				Look at William Curtis' web site.  He has some fuselage stand options
 posted.
 <http://wcurtis.nerv10.com/fusestand/index.html>
 My fuselage stand is just 2 2x4s with plywood on top, covered with
 carpet that run under the wing spar.  I then have a 2x4 running parallel
 to the fuse on each side with casters (total of 4 casters).  I support
 the tail with a plastic crate with foam on top.
 Larry Rosen
 #356
 Robert Wright wrote:
 [quote] no no no. You want something low to the ground while you work on it,
  and the fuse.
  Rob Wright
  #392
  _________________ Larry Rosen
#40356
N205EN (reserved)
<http> |
		Jim Berry
				 Posted: Fri Dec 14, 2007 11:00 am    Post subject: Re: Height of Fuse stand |
				I prefer to work standing up, rather than be kneeling or bent over. My stand was 48" x48" x 24" high, and on casters. The low point of my fuselage on the gear and wheels is 27.5" above the ground. At your height if you made a stand 28-29" high it would simplify attaching the gear and wheels, and might be a more comfortable working height.
 Jim Berry
 40482
		wcurtis(at)nerv10.com Guest
				 Posted: Fri Dec 14, 2007 11:44 am    Post subject: Height of Fuse stand |
				Doug,
 I've been through a couple iterations of the fuselage stand and you can see mine and some others here:
 My stand has two heights. Even at 6'5", I don't think you want a stand at full height to work on the fuse.  My lower height has the fuse belly 12" off the ground.  At this lower height, I still need a step to get in and work on the top. The drawing at the above link is the most update stand that I think works best.  I'll add the updated pictures shortly.
 William
		n277dl
				 Posted: Fri Dec 14, 2007 12:51 pm    Post subject: Re: Height of Fuse stand |
				Thanks for the input folks.  This helps a lot.  I'll leave it a little flexible, keep it simple and play with a couple heights and see what works for my size.
 Thanks again.  Traveling to Gatlinburg, TN this weekend and will hopefully get re-started early next week.
 Doug
  _________________ Doug
"Fools" are always more creative than process people and will always find ways to ruin a perfectly good set of processes. |
