grantr
Posted: Tue Dec 11, 2007 11:08 am Post subject: Rony Brackets? |
I've been reading all of these post regarding rony brackets in the Challenger Aircraft being a weak link and possible cause of wing failure.
Can someone tell me what the difference is between a rony bracket and other brackets like the strutted Phantoms use and the Hartaero airplanes.
Doug from Hart stated "No "rony" brackets are used on our aircraft. All of our attach hardware are mounted in shear load in all important attach areas."
I know the Kolb has a totally different design for the strut attachment. It looks pretty beefy on my MK III.
a58r(at)verizon.net Guest
Posted: Tue Dec 11, 2007 3:22 pm Post subject: Rony Brackets? |
biglar
pj.ladd(at)btinternet.com Guest
Posted: Wed Dec 12, 2007 2:46 am Post subject: Rony Brackets? |
Lift strut attachment (rony) brackets>>
Hi,
very interesting, but it is unfair to blame the design because owners cause failure by not treating the plane right. `Tightening so that it caused deformation of the strut` is a pretty stupid thing to do. If the book says `fingertight` there is usually a good reason for it.
Cheers
Pat
