Lom-List Digest: 4 Msgs - 12/11/07
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Lom-List
klaus.dietrich(at)oracle.
PostPosted: Wed Dec 12, 2007 12:50 am    Post subject: Lom-List Digest: 4 Msgs - 12/11/07 Reply with quote
concerning the Buzzer maintance you have to re-adjust it properly evry 50hrs or so; best done on a bench with a Multimeter and a stabilized Voltage of 24V!
This is a bit tricky to do on the plane.
I take my buzzer out, dismount the contacts, clean them thouroughly with a file (no holes, craters etc), reassemble and then adjust the gap to the correct Amp. value (max 1,0Ah).
Take care when re-mounting the spring-contact that both contacts are 100% aligned and parallel to each other!
Adjusting the gap is done the following way:
* you need a 24V transformer (best with selective Amps) and an Multimeter to read Amp
* put +24V on contact 3 or 1 and ground on contact 2 or 4
* have your Multimeter set to measure Ah (0-5Ah) and connected into the circuit
* set your transformer to 24V and limit to max 2,0Ah!
* turn on the transformer with 24V and check the Ah (do not let it on more than 20sec, otherwise the buzzer will get too hot!)
=> the correct Ah should be 1.0Ah (+/-0.2Ah)!
* to achieve the correct 1.0 A-setting, you have to bent very slightly the moving part of the spring-contact with a small plier!
=> bending the spring in direction of the fixed contact will increase the Ah
=> bending the spring away from the fixed contact will reduce the Ah
Hope this helps!
Klaus
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} <![endif]--> vCard Klaus Dietrich Klaus Dietrich 4 2 2007-01-04T14:23:00Z 2007-01-16T12:05:00Z 1 15 88 Oracle Corporation 1 1 108 9.7616 <![endif]--> <![endif]--> <![endif]-->
Klaus Dietrich
Oracle Financing EMEA
Tel/Fax: +43 1 33 777 825
http://www.oracle.com/financing
document.write("")
Lom-List Digest Server wrote: [quote]
Today's complete Lom-List Digest can also be found in either of the
of the Lom-List Digest and can be viewed with a generic text editor
HTML Version:
[url=http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 07-12-11&Archive=Lom]http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 07-12-11&Archive=Lom[/url]
Text Version:
[url=http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 07-12-11&Archive=Lom]http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 07-12-11&Archive=Lom[/url]
Lom-List Digest Archive
Total Messages Posted Tue 12/11/07: 4
Today's Message Index:
1. 11:11 AM - Rep: SlickSTART install (luke wuest)
2. 11:33 AM - Re: Rep: SlickSTART install (Robert Feldtman)
3. 12:32 PM - Re: Rep: SlickSTART install (Dave Austin)
4. 12:54 PM - Re: Rep: SlickSTART install (Robert Feldtman)
________________________________ Message 1 _____________________________________
Time: 11:11:27 AM PST US
From: luke wuest <lukester(at)earthlink.net> (lukester(at)earthlink.net)
Subject: Rep: SlickSTART install
Hello Bob,
Sorry it took awhile for me to post. I did not have a chance to get to the airport
until today.
My SlickStart is Model# SS1001 series A. Believe it or not, it is installed exactly
like the starter vibrator. My aircraft is setup a little different than most,
I have a separate mag switch, starter switch and an ignition boost button,
just like allot of antique radial powered aircraft.
The SlickSTART has 5 connections on it, 1, 2, 3, VIN, GND. The posts marked 2
and 3 have no connections.
The VIN post receives voltage from my starter switch positive solenoid contact,
this is wired thru my ignition boost switch. Voltage into the SlickSTART should
only be applied when the starter is engaged, my install takes it a step further
and only allows voltage in when the starter is engaged and the ignition boost
button is held in.
The GND post is wired to my magneto switch external ground post.
Post #1 has 3 wires attached to it. A heavy one going to the R/H magneto P-lead,
and two light gage wires going into my Mag switch. I have to do more research
into my mag switch install. There is a connector on the back with six wires
going internally into the switch, 2 of the wires are from the SlickStart number
1 post and I don't know what any of them do. Unfortunately it is very hard to
get at, I have to stand on my head in the rear cockpit (open cockpit biplane)
and work WAY up under the panel. I will try to gather more info and post.
Unison Industries has published a service letter on the different ways to install
the SlickSTART box, it is number SL2-96 and gives some incite into the different
ignition boost systems. Th standard LOM system is very similar to the "install
to replace starting vibrators that do not include a relay" system.
________________________________ Message 2 _____________________________________
Time: 11:33:24 AM PST US
From: "Robert Feldtman" <bobf(at)feldtman.com> (bobf(at)feldtman.com)
Subject: Re: Rep: SlickSTART install
Luke - thank you very much - this is of great help. the only problem now is
that they are indefinite back order from Unisom according the A/C spruce. So
- guess I'll button her up now that I have the buzzer working and wait til
the slick start shows up and put it in with the great information you have
given me.
I'll let you know how it goes.
thanks again and Merry Christmas
bobf
On 12/11/07, luke wuest <lukester(at)earthlink.net> (lukester(at)earthlink.net) wrote:
Hello Bob,
airport until today.
installed exactly like the starter vibrator. My aircraft is setup a little
different than most, I have a separate mag switch, starter switch and an
ignition boost button, just like allot of antique radial powered aircraft.
marked 2 and 3 have no connections.
contact, this is wired thru my ignition boost switch. Voltage into the
SlickSTART should only be applied when the starter is engaged, my install
takes it a step further and only allows voltage in when the starter is
engaged and the ignition boost button is held in.
P-lead, and two light gage wires going into my Mag switch. I have to do more
research into my mag switch install. There is a connector on the back with
six wires going internally into the switch, 2 of the wires are from the
SlickStart number 1 post and I don't know what any of them do. Unfortunately
it is very hard to get at, I have to stand on my head in the rear cockpit
(open cockpit biplane) and work WAY up under the panel. I will try to gather
more info and post.
install the SlickSTART box, it is number SL2-96 and gives some incite into
the different ignition boost systems. Th standard LOM system is very similar
to the "install to replace starting vibrators that do not include a relay"
system.
________________________________ Message 3 _____________________________________
Time: 12:32:56 PM PST US
From: "Dave Austin" <daveaustin2(at)primus.ca> (daveaustin2(at)primus.ca)
Bob,
What did you find wrong with the buzzer? Just need the points cleaned?
So far, so good with mine - 40 hours plus quite a number of run-ups.
Dave Austin 601HDS - 912, Spitfire Mk VIII
________________________________ Message 4 _____________________________________
Time: 12:54:51 PM PST US
Actually, the points were clean, but must have been a couple thousandths
apart cause when I check across them, they were not contacting "at rest" -
so according to the engine manual, you just bend it slightly so it touches
the grounding post - then the ohmeter dropped to nothing. I have about 90
hrs on my LOM engine. It is part of the annual check which I had done to
clean them - I just didn't actually check the ohmeter til it was obvious
there was not spark to start it with. after adjusting, it started fine.
The slick starts will be shipping again soon according to Unisom who makes
them. Till then I will use the buzzer; but look forward to quicker starts
and less cranking.
bobf
On 12/11/07, Dave Austin <daveaustin2(at)primus.ca> (daveaustin2(at)primus.ca) wrote:
Bob,
- The Matronics Lom-List Email Forum -
http://www.matronics.com/Navigator?Lom-List
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Lom-List All times are GMT - 8 Hours
