Fox5flyer Guest
				 Posted: Thu Dec 27, 2007 9:12 am    Post subject: TruTrak ADI A/H |
				Hi Dick.  It works great.  I'd been looking for an RC Allen  electric AH, but they're very expensive for an electric unit and their track  record has a pretty bad reputation for reliability.  There's also the  Chinese knockoff  (Falcon?) that is a couple hundred cheaper, but from what  I could glean, it's reliability record is even worse.  TruTrak  has no gyro so moving parts are almost zero in it.  You can buy the T/B or  A/H.  The A/H isn't a heck of a lot more and you get a better bang for  your buck.  I think the warranty was 5 years IIRC.  It fits a  standard 3.125 panel cutout.  I can't remember how the interface wiring  went that provides ground track, but it comes with the instructions.  My  advice would be to buy the optional GPS receiver and avoid all the  interfacing and extra wiring.  It's very small and sits on top of your  glare shield.  The receiver simply plugs into the back of the ADI.   That way, if you upgrade your Garmin, there would be no effect on the  interfacing.
  Deke Morisse
 Mikado Michigan
 S5/Subaru/CAP 365+ TT
 "Nothing will  ever be attempted, if all possible objections must first be overcome".- Samuel  Johnson
  [quote]      InDeke,
     How is that TruTrack ADI working out ? I am thinking about buying    that unit along with a 2 inch airspeed and replacing my3 1/4airspeed and 2    inch ball.(I have limited space on my panel.) It looks like you would get the    "most bang for the buck" with this unit.Spruce lists a Tru Trak ADI with    or without the GPS(about $15 diff).I have a Garmin 396 How does the Tru    Trak tie in with the GPS to give you heading ?
                                        Dick Maddux
                                        Fox4-1200
                                        Rotax 912UL
  |  | - The Matronics Kitfox-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
