rowil(at)clara.net Guest
Posted: Fri Dec 14, 2007 4:25 am Post subject: uni straps at wing root |
I've almost finished (well, apart from finishing & painting, of
course) my first wing.
I've done the UNI straps on the upper surface at the root, but when I
turned it over and started marking out to do the ones on the bottom,
I found that the aft end of the UNI overlaps the W18 flap bracket.
There's no mention of this in the manual.
I assume that it just needs the end of the longest UNI ply to be slit
and fitted each side of the W18, but I thought I'd better check first
in case something more clever is needed. However, when I phoned a few
minutes ago I found the factory has already gone off for the weekend.
Has anyone else got any factory advice about this?
regards
Rowland
| Rowland Carson PFA #16532 http://home.clara.net/rowil/aviation/
| 860 hours building Europa #435 G-ROWI e-mail <rowil(at)clara.net>
rlborger(at)mac.com Guest
Posted: Fri Dec 14, 2007 6:20 pm Post subject: uni straps at wing root |
Rowland,
That's exactly what I did. I hope it was correct...
Good building and great flying,
Bob Borger
Europa Kit #A221 N914XL, XS Mono, Intercooled 914, Airmaster C/S
http://www.europaowners.org/N914XL
(90%) tail kit done, wings closed, cockpit module installed, pitch system in, landing gear frame in, rudder system in, outrigger mod in, Fuselage Top on, lift/drag/flap pins in, wing incidence set, tie bar in, flap drive in, Mod 70 done. Baggage bay in. Flaps & Main Gear complete. Mod 72 complete. Instrument panel complete, except for testing. Rotax 914 installed (for the 3rd time). Airmaster Prop installed. Electrical complete, except for testing. Fuel system complete except for testing. Working in - 32 Tail, 34 Door Latches & 35 Doors, 37 Interior & Finishing. Airmaster arrived 29 Sep 05. Seat arrived from Oregon Aero. E04 interior kit has arrived and is being installed.
3705 Lynchburg Dr.
Corinth, TX 76208
Home: 940-497-2123
Cel: 817-992-1117
On Dec 14, 2007, at 6:22 AM, Rowland & Wilma Carson wrote:
Quote: | --> Europa-List message posted by: Rowland & Wilma Carson <rowil(at)clara.net (rowil(at)clara.net)>
I've almost finished (well, apart from finishing & painting, of course) my first wing.
I've done the UNI straps on the upper surface at the root, but when I turned it over and started marking out to do the ones on the bottom, I found that the aft end of the UNI overlaps the W18 flap bracket. There's no mention of this in the manual.
I assume that it just needs the end of the longest UNI ply to be slit and fitted each side of the W18, but I thought I'd better check first in case something more clever is needed. However, when I phoned a few minutes ago I found the factory has already gone off for the weekend.
regards
Rowland
| 860 hours building Europa #435 G-ROWI e-mail <rowil(at)clara.net (rowil(at)clara.net)>
