craigb(at)onthenet.com.au Guest
Posted: Sat Dec 08, 2007 4:13 pm Post subject: Aileron Trim servo |
Can someone point me in the right direction to an article i saw (here i think) where someone had made a
composite "horse shoe" spring an attached it to the aileron push rod under the cockpit module along
with a small servo
thanks
craig
Posted: Sat Dec 08, 2007 7:23 pm Post subject: Aileron Trim servo |
Quote: | Can someone point me in the right direction to an article i saw (here
i think) where someone had made a composite "horse shoe" spring an
with a small servo
craig,
The only aileron trim servo I'm aware of is attached to a moveable trim
tab on the trailing edge of the aileron itself. One example of this
type of servo is shown here:
www.europaowners.orgmodules.php?set_albumName=album126&id=60_Aileron_tri
m&op=modload&name=gallery&file=index&include=view_photo.php
If you have trouble w/ the long link, go to europaowners Gallery, go to
Cliff Shaw's albums, namely, the one entitled, "Aileron trim tab"...5
images w/ a bit of text.
Hope this helps,
Fred
A194
believed to be clean.
aireupora(at)sbcglobal.ne Guest
Posted: Sun Dec 09, 2007 7:15 pm Post subject: Aileron Trim servo |
I remember seeing this trim setup for another airplane and decided to do the same for the Europa. I think it was on an RV-6 or 9. I tried looking through my URL that I have saved, but could not find it. I don't think it would be to hard to set it up. I'm working on the cockpit module now and will be installing the aileron push rod in the next couple of weeks. That was one of the mods I will be making. I did not like like the trim out on the aileron and covered it back up. I'll sent you some of the pictures as I start to work on it.
craig bastin <craigb(at)onthenet.com.au> wrote: [quote] [b]Can someone point me in the right direction to an article i saw (here i think) [quote][b]
Posted: Tue Dec 11, 2007 3:50 am Post subject: Aileron Trim servo |
yes i was of the same opinion that the tab ON the aileron while functional is less desirable than
a servo on the system itself, and given the size of the ailerons compared to a tab, only a millimeter
or so of adjustment should be needed to trim imbalances
craig
[quote] --
Posted: Sat Dec 15, 2007 1:34 am Post subject: Aileron Trim servo |
HOO Ray i finally found it.
The trim system i was looking at was for the cozy. but we could use it, under the seat i am guessing would be the best spot
acting on the torque tube, no steel springs to fail etc, benign failure if it does brake for some reason.
http://www.maddyhome.com/canardpages/pages/waynehicks/chapter_17_1.htm
Quote: | here is the method they are using to make the "Spring" sorry there isnt much detail here
http://www.maddyhome.com/canardpages/pages/JonDembs/Ch17.htm
and go to the bottom.
I'm sure the cozy boys wont mind sharing one of their mods with us : )
-----Original Message-----
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com]On Behalf Of Rick Stockton
Sent: Monday, 10 December 2007 1:13 PM
Subject: Re: Aileron Trim servo
craig bastin <craigb(at)onthenet.com.au> wrote: Quote: | Can someone point me in the right direction to an article i saw (here i think) Quote: | [b]
href="http://www.matronics.com/contribution">http://www.matronics.com/chref="http://www.matronics.com/Navigator?Europa-List">http://www.matronhref="http://forums.matronics.com">http://forums.matronics.com
| [/b]
Posted: Sat Dec 15, 2007 8:59 am Post subject: Aileron Trim servo |
Great, I looked for two hours yesterday, as it was to cold to work in the garage. I knew I had see it, but where? I copied both links and will be looking at doing it this month. I start vacation on the 22nd and have until the 7th off. I'm hoping I can do a lot of work on the kit.
Rick Stockton
